Piston coolers (oil nozzles): how difficult to change? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By B767capt
post #1 of 3 Old 12th July 2016, 01:12 AM Thread Starter
Minimization
Minimization's Avatar
Hi guys,
I am thinking of doing the updated oil spray nozzles that cool the piston bottoms. Can these be changed relatively easily while the connecting rod bearings are changed using the "simplified method" (take front suspension apart, remove oil pan, leave engine in car, etc.)
Also, would this be a great time to change a TBA as well? Not sure what needs to come off the top of the engine, if anything, during a rod bearing swap.
Thanks!
2006 BMW M5 Sedan
SMG III/Silverstone Metallic/Black Perforated Merino/Aluminum/Anthracite Alcantara
X2/4MA/610/322/453/655/416/465/261/496
Dynamic Performance Engineering Monoblock ST7 Brushed Aluminum; 20 x 9.0", 20 x 11.0"
Michelin Pilot Super Sport; 265/35ZR-20, 295/30ZR-20 | H&R Trak+ 12 mm, 5 mm
Pirelli Winter 240 Sottozero;
255/40VR-19, 285/35VR-19
Thule K-Summit K44|LED 5 W 6,000 K 350 lm angel eyes|LED license plate lights
Valentine 1 hard-wired with Remote Display
Minimization is offline
post #2 of 3 Old 12th July 2016, 01:21 AM
gmak
for the oil spray nozzles, see #53 in this DIY.
JColley says that you don't have to take off the top part (intake manifold, coils, spark plugs) because you're not really cranking the engine around by hand. He says that it saves 2 hours. If you do take it off, the TAs are right there to be swapped out.
gmak is offline
post #3 of 3 Old 12th July 2016, 01:12 PM
B767capt
B767capt's Avatar
Yes the oil squirters are easy to replace while doing rod bearings. Use a long 1/4 drive extension. I remove the spark plugs because I usually do a compression test first, but mainly I remove them so that I can prime the oil system using the starter. I like having the the piston/connecting rods unloaded (no compression) while I'm waiting for the oil to get circulated through the crank since I had the oil pump off. Usually takes (5) 20 second cycles before I see the oil pressure start to register. That's just me though. The L plenum has to be off anyway with the type of engine support I use. I usually put new plugs in too since I had them out.
B767capt is offline
E60 Oil Coolers shawn.ahern E60 M5 and E61 M5 Touring Discussion 1 28th April 2013 11:46 PM
Supercharged guys, oil coolers? thelegacy E39 M5 and E52 Z8 Discussion 27 27th September 2012 09:21 PM
Mother of All Oil Coolers install thread tacoma330ci E39 M5 and E52 Z8 Discussion 44 18th January 2012 11:47 PM
Feedback on RPI oil coolers in hot areas M-POWER 77 E60 M5 and E61 M5 Touring Discussion 22 12th March 2010 12:47 AM
Feedback on Oil Coolers r tuned E60 M5 and E61 M5 Touring Discussion 0 10th June 2007 04:59 PM
