Rear differential oil alternatives? - BMW M5 Forum and M6 Forums
 3Likes
  • 1 Post By Fiftytwoeighty
  • 1 Post By ticat928
post #1 of 10 Old 11th July 2016, 08:07 PM Thread Starter
dr_dirtg
dr_dirtg's Avatar
Hey guys, have you tried to use any of the other and much cheaper oils for your differential?
Motul, Redline, Royal Purple?
What about LiqiMoly?
Does this product have FM booster:
It says it has BMW Hinterachsgetriebeöl whatever that may be?
LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Fully Synthetic Hypoid Gear Oil (GL5) LS SAE 75W-140
https://pim.liqui-moly.de/pidoc/P000...40-10.0-us.pdf
The spec sheet says it fullfills BMW requirements, but I would like to hear the expert's opinions on this forum.
Thanks!
dr_dirtg is offline
post #2 of 10 Old 11th July 2016, 08:50 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
I use Redline ShockProof Lightweight in my custom Performance Gearing 3.91 diff.
Red Line Synthetic Oil - ShockProof® Gear Oils - Lightweight ShockProof®
I made with switch in 2014 after my old Dinan 3.91 blew up on me:
https://www.m5board.com/vbulletin/e60...my-3-91-a.html
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
The Following User Says Thank You to Fiftytwoeighty For This Useful Post:
Hasan Shaikh (12th July 2016)
post #3 of 10 Old 11th July 2016, 09:36 PM
ticat928
ticat928's Avatar
I like this oil since it has a Group 4 base will try next.
aFe Power Pro Guard D2 is a full synthetic limited slip gear oil in 75-140 grade. This competition proven formulation utilizes a group IV synthetic base
recommended by Turner
https://www.turnermotorsport.com/p-2...tial-gear-oil/
I bought Red Line as recommended by ECS this time around.
Will change often after track events based on observed degradation
ticat928 is offline
post #4 of 10 Old 11th July 2016, 09:51 PM
ticat928
ticat928's Avatar
Per Redline: "Fully-synthetic formulas created from polyol ester base stocks, offer excellent lubrication under extreme conditions"
Red Line Synthetic Oil - Gear Oil for Differentials - 75W140 GL-5 Gear Oil
This is a quality product that may exceed the BMW oil depending on base stock it uses.
As evidenced by:
"Polyol esters can extend the high temperature operating range of a lubricant by as much as 50 – 100°C due to their superior stability and low volatility. They are also renowned for their film strength and increased lubricity which is useful in reducing energy consumption in many applications. The only downside of polyol esters compared to diesters is their higher price tag, generally 20 – 70+% higher on a wholesale basis."
"In general, polyol esters represent the highest performance level available for high temperature applications at a reasonable price. Although they cost more than many other types of synthetics, the benefits often combine to make this chemistry the most cost effective in severe environment applications. The primary benefits include extended life, higher temperature operation, reduced maintenance and downtime, lower energy consumption, reduced smoke and disposal, and biodegradability."
Esters In Synthetic Lubricants - Bob is the Oil Guy
ticat928 is offline
post #5 of 10 Old 11th July 2016, 09:55 PM
ticat928
ticat928's Avatar
Woody
Per your Sig:
" FastAttack Tune, w/Kung Fu grip!"
Where can I buy me some Kung Fu Grip?
LOL
ticat928 is offline
post #6 of 10 Old 11th July 2016, 10:17 PM
ticat928
ticat928's Avatar
ticat928 is offline
post #7 of 10 Old 11th July 2016, 10:43 PM
texsn95
I used the Royal Purple 75-140 with the FM additive, and still had some chattering driving through the sharp turns in the parking garage. Added 3-4 oz of some Ford friction modifier I had and it's all good.
texsn95 is offline
post #8 of 10 Old 11th July 2016, 11:27 PM
BadSeed
Thanks!
I used Liqui Moly for 500 miles but the chatter never went away. Replaced with OEM, no more chatter. LM does not have FM booster or at least the one that I used.
BadSeed is offline
post #9 of 10 Old 11th July 2016, 11:31 PM Thread Starter
dr_dirtg
dr_dirtg's Avatar
wow thanks for all the responses, lots of good info in short amount of time.
So the liquimoly brand is available locally, however they want $40 for a 1L bottle.
I also called the dealer here, which i try to avoid at all costs, and they only have huge jugs. But he said I would have to bring in a small container and they would fill it up for $35 per liter.
This so far sounds like the best option for me ( i dont race/track, i just punch it every other now and then)
dr_dirtg is offline
post #10 of 10 Old 11th July 2016, 11:46 PM
JohnAnthony
JohnAnthony's Avatar
Mercedes sells the Castrol SAF-XJ 75W140 in 500ml bottles
mercedes part number: 001989520310
edit:
pelican parts seems to have a pretty good deal on it, at $30/Liter before shipping
JohnAnthony is online now
Questions related to lower oil pan and rear differential zaid E39 M5 and E52 Z8 Discussion 2 4th July 2016 03:11 PM
B12 5,7 E31 Rear differential Oil type carmel ALPINABoard.com | BMW Alpina Discussion 0 20th September 2014 11:11 PM
B10 BiTurbo rear differential oil cooler Erneland ALPINABoard.com | BMW Alpina Discussion 1 3rd March 2014 06:47 PM
what oil for the tranny with the UUC V12 setup, and what oil for the differential? razahyde E39 M5 and E52 Z8 Discussion 8 7th August 2009 09:21 PM
Rear Differential Oil change AGIL E34 M5 Discussion 16 24th February 2006 05:41 PM
