Road Trip Complete! Cooling question... - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By Hasan Shaikh
  • 1 Post By Racer14sl
post #1 of 8 Old 9th July 2016, 03:25 PM Thread Starter
Racer14sl
Racer14sl's Avatar
Just returned from a 1500 mile round trip to the beach for a week. At first, I was nervous about driving my E60 M5 on this trip. I've never had any issues thus far with my car, nor taken it on any long road trip away from home. But some of the horror stories I read on this forum about SMG issues, Vanos, and rod bearings...I felt like I was taking a chance. Before this vacation trip, the longest round trip I've taken with the M5 was around 200 miles and put approx. 2000 miles on it since purchase last summer. The car ran very well, set cruise at 75mph and averaged 20.5mpg.
Maintenance before trip;
- Replaced SMG motor relay and Transmission Oil Pump relay
- Checked SMG hydraulic fluid level, didn't even need topped off.
- Bled Slave Cylinder and SMG pump block. (shifts much faster)
- Engine oil changed less than 500 miles before trip
- Replaced fuel filter (just PM and piece of mind)
- Re-Balanced all wheels / tires, set pressures at 40psi.
- Checked coolant and brake fluid levels, both were fine.
Based of suggestions from members, I packed a spare tire, 2 litres of TWS 10-60 oil, small tool kit, small jack, jumper cables, and portable 12v air compressor. Thankfully I didn't need to use any of these items, in fact, when I departed, my engine oil level was at 1.0, when I returned, its shows 0.9L after checking. Glad to see my engine is not consuming oil!
Now, since cooling temperature has become a topic in the past week, the only thing that concerned me during the trip was the water temp got just a little past 210 deg F when driving down the interstate with AC on. I'd say 215-220 max. When I turned the AC off, the water temp dropped just below 210. Ambient temperature was 90 - 95 deg. F. After driving 100 miles or so with temperature around 215, I was no longer concerned and kept the AC on. I know the engine has to work slightly harder to run the AC compressor, so I assumed this was all. Coolant level is spot on and cooling fan is working normal, cycling through all the speeds.
Typically, I've never seen water temp rise past 210, yet again, this is the first time I've driven non stop on a tank of gas in 90+ deg weather. Hopefully this is not abnormal.
Racer14sl is offline
post #2 of 8 Old 9th July 2016, 04:37 PM
gmak
Are you talking about water temp or oil temp. The gauge in the car is for oil. You need to get into the hidden menu to see coolant temp (#7 = KTMP)
gmak is offline
post #3 of 8 Old 9th July 2016, 09:10 PM
LeeDan00
LeeDan00's Avatar
Wait, what's your question? Your scenario above looks to be normal in terms of temps. Nothing to really be concerned about but seems like your car did well.
Dan
2007 ESS SC'd 6MT
ESS VT2-650 Supercharger with Intercooler
ESS Alpha N Tune
Vortech BOV vta to replace the stock recirculating one (OMG loud!)
Rod bearings changed 8/10/15 at 88k miles
Dinan sections 1 - 3. Straight pipe 4'' "loudest" version Dinan offers. (Sounds amazing at WOT)
Secondary cats and resonator removed
KWv3
Flat bottom steering wheel all leather with M stitching
RPi SV1 Oil Cooler in silver
RD Sway Bars
Brembo BBK 405/380mm in factory yellow
Dinan Monoballs
Hardwired V1
CF hood by Seibon. E9x style with hood bump and functional vents
CF Hamann front lip
CF rear diffuser
CF trunk lid from member Socale39
ZHP shift knob
BBS fi-r with Michelin Cup2's
Custom built headlights by Evan with fx-r projectors and Orion v2's and full blackout
Gloss black kidneys and side vents
Gloss black M5 badge
Gloss black ESS badge
LCI tails with special brake effect done by Simon aka BCD
LED front, side, and license plate
Dyno'd 598wrhp and 413tq on Dynojet 10/29/15 on stock headers
2010 Dinan S3 5.7L complete catalog car serial numbered 6MT
LeeDan00 is offline
post #4 of 8 Old 10th July 2016, 06:44 AM Thread Starter
Racer14sl
Racer14sl's Avatar
Sorry, I guess this is oil temp?? First car I've seen oil temp instead of coolant...learn something new every day about this beast! Generally 210 Deg. F is the center for water temp. The oil symbol should have gave it away...my bad!
What do I need to do to get into the hidden menu for coolant temp?
I'm sure everything is normal, just was my first time seeing the oil temp rise over 210.
post #5 of 8 Old 10th July 2016, 07:29 AM
Hasan Shaikh
Hasan Shaikh's Avatar
The oil temp going above 210 is nothing to worry about. You have the oil cooler to take care of that.
May I suggest that you don't let your fuel level drop below the last quarter. It will prolong the life of your fuel pump.
Hasan Shaikh is offline
post #6 of 8 Old 10th July 2016, 08:10 AM
Hasan Shaikh
In addition, let me assure you that these cars have no overheating issues.
If everything is working, it is quite difficult to get the overheat message even if you try to get it deliberately.
I got the message only once, and it took drifting in 1st gear for about 30 mins in 100f ambient temperature to get there. So it will only overheat if something is not working.
Just enjoy the car. Take care of it, and it will take care of you.
post #7 of 8 Old 10th July 2016, 01:27 PM Thread Starter
Racer14sl
Racer14sl's Avatar
Absolutely!
post #8 of 8 Old 10th July 2016, 01:30 PM Thread Starter
Racer14sl
Racer14sl's Avatar
Thank you. I'm big on preventive maintenance. It was a joy to drive for 11hrs, definitely a car worth taking on long boring road trips!
The Following User Says Thank You to Racer14sl For This Useful Post:
Hasan Shaikh (10th July 2016)
M5 road trip. x5alpine E39 M5 and E52 Z8 Discussion 26 16th June 2015 07:23 PM
First Road Trip : ) Wulffza E60 M5 and E61 M5 Touring Discussion 8 15th November 2011 06:21 PM
Road Trip HansE60 E60 M5 and E61 M5 Touring Discussion 2 25th October 2011 11:55 PM
Road Trip!! Chemikill E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 28th June 2009 07:01 PM
Road trip PennsM5 E60 M5 and E61 M5 Touring Discussion 10 18th April 2008 09:14 AM
