125,000 mile update on rod bearings replaced 41,000 miles ago - BMW M5 Forum and M6 Forums
 20Likes
  • 11 Post By Fiftytwoeighty
  • 1 Post By 5soko
  • 1 Post By ticat928
  • 1 Post By Texasgrego
  • 1 Post By Hasan Shaikh
  • 1 Post By Elie Malak
  • 4 Post By Fiftytwoeighty
post #1 of 10 Old 8th July 2016, 12:11 PM Thread Starter
Fiftytwoeighty
Fiftytwoeighty's Avatar
125,000 mile update on rod bearings replaced 41,000 miles ago at 84,000 miles. Today, I'm at 126,000 miles.
I'm still tacking on the miles, but not as much as before -- only about 11,000 miles this past year. Lately, I'm tacking more miles on my LandCrusier and A3 Quattro.
I also fly about 100,000 miles a year, and I work from home many of the days I'm not flying. Needless to say, when the e60 gets driven, she still gets driven. As many know, she's my long distance commuter: The Bay Area, Phoenix, Las Vegas, Denver. Often times, I'll take the long way because it's more fun!
My start up sequence, driving habits, and maintenance remains unchanged.
Oil: Motul 7100 10w60 (yes, I know, it's motorcycle oil)
Tune: FAMS JColley tune, just loaded.
Headers: Catless race headers
Boring stuff really, in the last year. No major maintenance.
OMS sent in my Blackstone, so my old reports are not showing.
My previous updates:
https://www.m5board.com/vbulletin/e60...000-miles.html
https://www.m5board.com/vbulletin/e60...miles-ago.html
Get out and DRIVE these cars! They NEED/BEG/DESERVE to be driven.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
The Following 2 Users Say Thank You to Fiftytwoeighty For This Useful Post:
Elie Malak (10th July 2016), Hasan Shaikh (10th July 2016)
post #2 of 10 Old 8th July 2016, 01:29 PM
5soko
5soko's Avatar
5soko is offline
post #3 of 10 Old 8th July 2016, 09:57 PM
seankim
My oil report shows high levels of copper and lead and I am going to replace the bearings. When I see OP's initial report, he had low copper and extremely high lead level at 65 ppm. Mine shows evenly high readings on copper and lead, both are in mid 30 range. Does this mean my bearings are in worse condition than OP's and my crankshaft might be scored? I am so scared...
seankim is offline
post #4 of 10 Old 8th July 2016, 10:59 PM Thread Starter
Fiftytwoeighty
You're already thinking in the correct direction with replacing your rod bearings.
The reality is, you won't know the condition of the crank (or the rod bearings) until you open her up. My crankshaft was not scored; the softer bearing took the wear.
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #5 of 10 Old 8th July 2016, 11:23 PM
ticat928
ticat928's Avatar
Concentration (PPM) increases with mileage on the oil thus need to have samples of equal mileage in order to make an apples to apples comparison.
The original bearings were tri-metal with lead overlay on copper thus once lead is worn away copper ppm increases while lead decreases.
ticat928 is offline
post #6 of 10 Old 9th July 2016, 08:49 PM
Texasgrego
Texasgrego's Avatar
Thanks for the updates as always, Woody.
Thanks. What do we need to look for in ver 2. + bearing wear ?
Texasgrego is offline
The Following 2 Users Say Thank You to Texasgrego For This Useful Post:
Fiftytwoeighty (9th July 2016)
post #7 of 10 Old 9th July 2016, 11:01 PM
ticat928
ticat928's Avatar
ticat928 is offline
post #8 of 10 Old 10th July 2016, 07:33 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Hasan Shaikh is offline
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
Fiftytwoeighty (12th July 2016)
post #9 of 10 Old 10th July 2016, 07:51 AM
Elie Malak
Elie Malak's Avatar
great write up and thank woody its because of your thread that made me aware about the issue and its been around 1000 miles since my rod bearings change
btw if you get the chance to do a small review on jims tune (differences at p400 and 500, etc) i'll be gratefull since ill be getting it soon
2008 Alpine White ///M6
Driven Twice A Week
A Sheer Driving Pleasure
Instagram: @elie_malak
Facebook: Elie Malak
Mods: (List Will Grow with time)
-Matt Black Grills
-Matt Back Side Grills
-CF VRS Front Lip
-CF VRS Diffuser
-VF VRS Trunk Lip
-Eisenmann Race Exhaust
-Charcoal Filter Delete
-K&N Drop In Air Filters
-Agency Power Pulley
-Eibach Lowering Springs
-VRSF Spacers 10mm Front / 12mm Rear
-FAMS Tune
-Supersprint Primary Cat Delete Bypass
-RTD Short Shifter Kit
Previous Cars:
-E60 2006 530i :'( SOLD
Elie Malak is offline
The Following 2 Users Say Thank You to Elie Malak For This Useful Post:
post #10 of 10 Old 12th July 2016, 04:59 PM Thread Starter
Fiftytwoeighty
What is this "p400" mode you speak of???
Seriously, the only time I'm in p400 is when I start the car. We paid for all the HP, so why not use it all the time?
Quick, seat of my pants, review of my FAMS compared to my old Dinan Stage I tune after about 500 miles:
Feels like I'm running 100 octane, instead of the 91 octane we get at the pump.
I'm not downshifting on the freeway as much to overtake.
Power band moved down to 3000.
4th gear @3000 feels like 3rd @4000.
2nd and 3rd gear at @4000 is like crack.
Throttle response feels sharper/instant @3000 -- like an old school throttle wire.
~Woody
~I FRACKING!
~Viva La Wolfpack!
The Following 4 Users Say Thank You to Fiftytwoeighty For This Useful Post:
Elie Malak (12th July 2016), Hasan Shaikh (13th July 2016), REX318 (13th July 2016)
Rod [email protected],000 miles WallyM5 E60 M5 and E61 M5 Touring Discussion 116 5th January 2017 10:26 PM
114,000 mile update on rod bearings replaced 30,000 miles ago Fiftytwoeighty E60 M5 and E61 M5 Touring Discussion 17 22nd June 2015 08:28 AM
101,000 mile update on rod bearings replaced 17,000 miles ago. Fiftytwoeighty E60 M5 and E61 M5 Touring Discussion 22 22nd August 2014 04:52 AM
Rod bearings at 84,000 miles Fiftytwoeighty E60 M5 and E61 M5 Touring Discussion 87 4th October 2013 03:30 AM
Pics of Rod Bearings after 173,000 miles tranck E39 M5 and E52 Z8 Discussion 15 22nd October 2011 08:55 PM
