SMG faults - Page 2 - BMW M5 Forum and M6 Forums
 2Likes
post #11 of 20 Old 15th July 2016, 01:47 PM
B767capt
B767capt's Avatar
Originally Posted by georstan View Post
Didn't change the slave, technician didn't recommend it, he has rarely seen them fail, but at this point IDK, only had 1 error message today in heavy traffic, other than that everything else seems fine
They fail a lot and you can't tell by looking at them. Fluid starts to bypass the internal seal and the calibration can't be done after a clutch change. They have also been know to spray hyd fluid all over your new clutch and ruin it. Cheap 300.00 insurance IMO since it has rubber inside that deteriorates over time. It's a wearable part that only be changed when the transmission is out.
B767capt is offline
post #12 of 20 Old 15th July 2016, 05:24 PM
lyallf
lyallf's Avatar
Originally Posted by dr_dirtg View Post
can you elaborate on this a little? is that an external leak? will you see the trany all wet in hydraulic fluid? or internal?
Hi
I'm not mechanically savvy but from what I understood it was internal and could not see fluid anywhere.
lyallf is offline
post #13 of 20 Old 16th July 2016, 05:24 AM Thread Starter
dr_dirtg
dr_dirtg's Avatar
hmm.. i wonder how to check if there is an internal leak or not. what did your mechanics do to fix it?
dr_dirtg is offline
post #14 of 20 Old 16th July 2016, 05:37 AM
lyallf
lyallf's Avatar
They hooked it up with the diagnostic, activated the pump and monitored the pressure which dropped abnormally quick on the SMG pump. It refused to hold pressure as a good working unit normally would.
lyallf is offline
post #15 of 20 Old 18th July 2016, 05:32 AM Thread Starter
dr_dirtg
dr_dirtg's Avatar
This internal seal is that one of the orings that come with the new pump itself?
I am awaiting my new pump from ecs... hopefully my pressure dropping fast will be resolved with a new pump and seals/o rings.
I checked my pressure and it goes up to about 60bar but then goes down to about 45 within approx 2 min. I imagine this is a internal leak?
dr_dirtg is offline
post #16 of 20 Old 18th July 2016, 04:44 PM
lyallf
lyallf's Avatar
My faulty pump would hit 100bar then drop immediately every 5 seconds and hold at 40. The new one hits 100 bar or slightly more and takes a lot of time before dropping in pressure
lyallf is offline
The Following 2 Users Say Thank You to lyallf For This Useful Post:
dr_dirtg (19th July 2016)
post #17 of 20 Old 19th July 2016, 02:44 AM Thread Starter
dr_dirtg
dr_dirtg's Avatar
This is exactlly what I wanted to hear - so my pump is definetely no good. Too bad ecs just told me to wait till aug 6 for them to get it.
dr_dirtg is offline
post #18 of 20 Old 19th July 2016, 04:25 AM
5soko
5soko's Avatar
Interested where are you getting this info?
Normal pressure should be 75 bar, max is 90 bar for adaptions and such..
You can see this info in INPA.. From most cars i have seen, while engine running, the pressure drops slowly until around 50's bar where the pump starts up again to bring it back up to mid 70's again.
There is a function in DIS that you can check the hydraulic health of your unit.
SMG accumulator leak down test and SMG pump pressurization time test
5soko is offline
post #19 of 20 Old 19th July 2016, 07:00 AM
lyallf
lyallf's Avatar
Hi
Like I said I not at all mechanically handy so I'm just stating what I saw when my car was linked to a diagnostic touch screen and mechanic activated the pump and I heard it prime and could see the pressure figure and how it decreased on the screen.
lyallf is offline
post #20 of 20 Old 19th July 2016, 12:33 PM
5soko
5soko's Avatar
Hi
Gotcha, was just interested where you collected the data..
5soko is offline
New owner with some faults - help Worzel E60 M5 and E61 M5 Touring Discussion 5 6th April 2015 10:11 AM
M5 F10 Faults thunderboard E60 M5 and E61 M5 Touring Discussion 3 31st March 2012 03:40 AM
VANOS Faults turton E60 M5 and E61 M5 Touring Discussion 6 21st January 2010 01:38 AM
CPS Faults ANiMOSiTY E39 M5 and E52 Z8 Discussion 22 25th September 2009 11:46 AM
All the faults, none of the blame E60M5ATL E60 M5 and E61 M5 Touring Discussion 7 26th June 2006 08:15 AM
