Mysterious Misfire - BMW M5 Forum and M6 Forums
post #1 of 5 Old 5th July 2016, 12:51 AM Thread Starter
jzx28
jzx28's Avatar
Mysterious Misfire
Hi All,
So i went on Holidays for 2 weeks and when i came back i started up the car, filled it up with fuel for work the next day.
When coming home from work the next day, driving normally in P400 mode, i encountered Engine Fault with the redline coming up to 4500rpm. I limped it home after restarting the car.
Called over a mate and he coded it and it said there was misfiring in bank 1 but random cylinders, sometimes cyl 1,2,4,5 or cyl 3,5 etc.
First i thought it was the battery as it was on the to do list and maybe its finally gone crazy. (Note. Was the original 2005 Battery)
Nope no luck, then tried switching my ionic control units from bank 1 and 2, still no luck. Im just wondering if anyone has had anything like this, i know it could be a number of things but i cant see it being plugs/coils as they went suddenly and only on bank1, cant hear and weird vanos noises, nor have i got any vanos faults.
The only thing i can hear is a rattling/ticking noise from Bank 1 but im unsure if thats from the actual misfire (which i think it is), compared to the problem of the misfire.
I am thinking along the lines of o2 sensor or MAF, but i dont want to keep throwing parts at it.
I have attached some pics of what i found.
What advice do you guys have?
Thanks in advance.
ID:	714457   Click image for larger version
jzx28 is offline
post #2 of 5 Old 5th July 2016, 01:11 AM
stevezx900
stevezx900's Avatar
I had the same issues. Try switching coils packs around. See if you get a misfire somewhere else. That was my problem. One bad coil.
stevezx900 is offline
post #3 of 5 Old 5th July 2016, 06:50 AM Thread Starter
jzx28
jzx28's Avatar
1 bad coil pack caused multiple cylinders to misfire or just one coil for each cylinder?
Its a bit weird how they would go at once and all one bank 1.
jzx28 is offline
post #4 of 5 Old 5th July 2016, 10:28 AM
ror600
ror600's Avatar
Swap you air mass and check
May be it is the throttle actuator
But what is the third error?
ror600 is offline
post #5 of 5 Old 5th July 2016, 02:01 PM Thread Starter
jzx28
jzx28's Avatar
How can i check if my throttle actuator is working, isnt that when the revs will fluctuate.
Also will clean and swap MAFs over from Bank1 and 2.
3rd fault is 2796 motor emergency program activated.
jzx28 is offline
Tags
bank 1 , e60 m5 , misfire
Misfire and fuel trip codes (Was in 2002 e39 M5 - Misfire) Khane39m5 E39 M5 and E52 Z8 Discussion 34 24th April 2016 12:01 AM
First, cylinder 1 misfire; now misfire moved to cylinder 8 misfire huh?! E60 M5 and E61 M5 Touring Discussion 8 10th March 2015 05:31 AM
Mysterious Misfire and Air-fuel Adaptation Codes Tripping SES wxl1988 E39 M5 and E52 Z8 Discussion 18 17th February 2011 09:08 AM
The Mysterious Item 13.. V8 empowered E39 M5 and E52 Z8 Discussion 4 17th December 2008 10:49 PM
Mysterious Miss!!! mikeh E39 M5 and E52 Z8 Discussion 13 23rd October 2004 05:05 PM
