e60 m5 Thrust Arms (clicking noise) - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By Fiftytwoeighty
  • 1 Post By Texasgrego
post #1 of 8 Old 4th July 2016, 06:05 PM Thread Starter
IlyaG
Hello,
I have replaced the thrust arms a total of 4 times over the past year.
The first time was from oem so that was fine. The 2nd time was because i havent quite broken them in and spun out in the rain so that shot the rubber and they bled out. 3rd time i had the thrust arms on for 5 months and i thin this was purely the result of tight city driving ( mainly those parking lots) Now the car is sitting on a fresh set of thrust arms bushings and all every other front suspension component looks okay.
Here is the issue ( if you can call it that) The car makes a little clicking noise when in parking lots if i turn the wheel into the locking position (either way) now incase you are wonder what that clicking noise is it is the thrust arm bushing the bushing is rubber filled with "lube" but outside the rubber there is a plastic gasket. Now could someone please explain to me why this plastic gasket always breaks. i have installed the arms 1 time without the plastic gasket no clicking noise. But my shop says that the gasket is their because its an m5 and it makes things tighter. . . Id begg the differ so to speak.
anyway if anyone has more insight into these things please let me know.
My next set will be a new thrust arms on dinan bushing as my shop could not fit a polyurethane bushing. (idiots?)
here is the link to the part- BMW Control Arm - Front Driver Side Upper - eEuro Preferred 31126774825A - Free Shipping Available
here is close up pick of the said gasket
that small black lining actually pops out its not glued to the rubber and its a hard plastic with a metal ring. i have 2 old thrust arms i can get better picks of this said gasket.
at the dealership the people really dont know what it is they just stick it in. on average i notice once you replace the thrust arms and bushing the car rides okay for 12k miles and then they are shot again. my BMW adviser says this is due to the car being an M car and once you touch the suspension its hard to make it the same ( i agree although dinan or polyurethane should be a better alternative. )
IlyaG is offline
post #2 of 8 Old 4th July 2016, 06:27 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Time to step up and get a set of balls.
I used to blow through mine as well:
https://www.m5board.com/vbulletin/e60...han-yours.html
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #3 of 8 Old 5th July 2016, 04:46 AM Thread Starter
IlyaG
HAHAAH
the 4th time when i was ordering the arms i went and started my order with dinan but i called them up and they told me it be at-least a week i was in a hurry and wen with oem but believe me on 5th time it will be monoballs.
IlyaG is offline
post #4 of 8 Old 5th July 2016, 05:12 AM
Texasgrego
Texasgrego's Avatar
Everyone who has felt my balls has really liked them
They have turned red. GAS Man products
Texasgrego is offline
post #5 of 8 Old 5th July 2016, 05:23 AM Thread Starter
IlyaG
ohh man those are some really nice balls,
Id love to see a pov shot as you press them in
IlyaG is offline
post #6 of 8 Old 5th July 2016, 05:48 AM
Texasgrego
Texasgrego's Avatar
post #7 of 8 Old 5th July 2016, 06:13 AM
Texasgrego
Texasgrego's Avatar
The Following User Says Thank You to Texasgrego For This Useful Post:
theraj (7th December 2016)
post #8 of 8 Old 5th July 2016, 07:46 AM
Fiftytwoeighty
Back in the day, Dinan was the only option.
It's good to see GAS offer up some good competition and an outstanding alternative.
~Woody
~I FRACKING!
~Viva La Wolfpack!
Clunking/clicking noise on gear change E60 M5 phillipe124 E60 M5 and E61 M5 Touring Discussion 36 8th March 2018 06:02 PM
Thrust Arms rosakirk12 E39 M5 and E52 Z8 Discussion 2 28th November 2015 12:41 AM
M5 e60 Thrust arms (upper control arm) IlyaG E60 M5 and E61 M5 Touring Discussion 2 18th October 2015 01:49 PM
Thrust arms MugenITR E34 M5 Discussion 48 22nd June 2012 02:00 PM
Vines Thrust Arms and OE Control Arms Installed Today BKH E39 M5 and E52 Z8 Discussion 8 12th August 2006 06:09 PM
