**Clutch pedal became soft** 08 M5 - 6 Speed Manaul - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 17 Old 7th July 2016, 03:50 AM
wfwright2
Fluid level looks good. Check for fluid under floor mats under clutch pedal. If it was an older M6 I would suggest checking for a cracked mount or worn pedal bushing.
The slave cylinder may be failing, check for fluid under dust cover.
Was the clutch circuit get flushed when the brakes were done, chance of getting air in hydrolics if level not watched during brake fluid flush.
Next step for me would to have the clutch system flushed/bleed before replacing parts.
Sent from my SM-T337V using Tapatalk
wfwright2 is offline
post #12 of 17 Old 14th July 2016, 05:42 AM
pdquery
pdquery's Avatar
Can you take a picture of your fuse panel in the glove box? I'm trying to fix a dumb mistake and you have same year and transmission as I do. Thanks!
Sent from my SM-P900 using Tapatalk
2008 E60 M5 Silverstone with Silverstone leather and Black alcantara.
Corsa exshaust
H&R springs
UCC Short Shift Kit
pdquery is offline
post #13 of 17 Old 15th July 2016, 08:40 PM Thread Starter
Whitecracker
Will do. I'll send you a picture later on today if still needed
Whitecracker is offline
post #14 of 17 Old 16th July 2016, 01:31 AM
pdquery
pdquery's Avatar
Yes please. I am not getting anywhere playing an old time phone operator unplugging and plugging in fuses to see what magical error I get in idrive.
Corsa exshaust
H&R springs
UCC Short Shift Kit
pdquery is offline
post #15 of 17 Old 16th July 2016, 01:33 AM
pdquery
pdquery's Avatar
If you are in north metro ATL, I'll buy you a beer for your trouble
Corsa exshaust
H&R springs
UCC Short Shift Kit
pdquery is offline
post #16 of 17 Old 16th July 2016, 07:18 PM Thread Starter
Whitecracker
[QUOTE=pdquery;6756266]Yes please. I am not getting anywhere playing an old time phone operator unplugging and plugging in fuses to see what magical error I get in idrive.
post #17 of 17 Old 17th July 2016, 02:07 AM
ssclassa80
This symptom occurred in my miata race car when the master cyl started to leak and air got in the lines. Slave cyl and clutck line was replaced at the same time bit I think it was the master that was the cause.
ssclassa80 is offline
Is the M5's brake pedal just soft? 01 E39 M5 and E52 Z8 Discussion 15 24th January 2016 09:16 PM
Soft Clutch Pedal - sits halfway down to floorboard at rest - 2002 BMW M5 rinfantino E39 M5 and E52 Z8 Discussion 5 26th March 2015 04:37 PM
Continuing saga of soft brake pedal mitchiehoney E39 M5 and E52 Z8 Discussion 9 19th January 2013 05:27 PM
Brake pedal gone soft Dan Kelly E39 M5 and E52 Z8 Discussion 5 21st August 2011 05:03 AM
soft brake pedal, std system Timbo69 E39 M5 and E52 Z8 Discussion 2 17th February 2011 09:05 AM
