My adventure with M5 E61 so far. - BMW M5 Forum and M6 Forums
LinkBack Thread Tools Rate Thread
Old 22nd June 2016, 02:17 PM Thread Starter
Kolega1982
Kolega1982's Avatar
Hi
Since January 2016 owner of M5 E61 Interlagos Blue. Bought mine M with 68k mls on clock.
Before owner of 530d e61. so e61 model in shape and some other aspects is known to me.
Impressed with with gearbox slamming through every gear change and proper kick in mine spine through every gear up to no 7 on the dash. Very nice !
In April , Throttle Actuator Bank 2 failed ( from this forum learned , what to do ) Found ppl who could revamp gears on actuator for me , and on the 230 mls trip to them clutch have started slipping between 3-4 gear
Re con TA 500£ - for both. Clutch Sachs flywheell LUK 850£ + fitting 500£ . Week after oil cooler , oil leak 279£.
TA - end up of buying new actuator 399£ VDO for Bank 2 as is been failing every 2 weeks - got fitted now for a week and is fine. Replaced my self - ( not that hard , just a lot of stripping needs to be done - recommended to all owners - do it your self to build up relationship with your beasts. adaptation - calibration after been fit is been done as well - many different opinions do the need or no , i have calibrated mines.
Clutch - break in process with few problems , as man who have installed for mee had problem with his GT1 and first 100 miles done without adaptation ( jerky like hell ) first 500 mls done with more care if fast drive , always foot of the accelerator , now done about 2k mls on this clutch and overall its fine , sometimes some clunks coming from diff when engaging to 1st , or down shifting it self on traffic lights from 3rd to second on low revs.
1. Something have changed aver all this - but unsure , is this the clutch - or actuators - M is not slamming through the gears like before with every gear change especially from 2nd to 3rd or from 3rd to 4th - they are smoother changes definitely then before like there is not that much power as it was before As anyone have experienced something similar ? No codes throwing out. Very strange. Is the clutch still breaking in ? Or what ?
2. What it should be coolant temp ? Mine is between 79C and 84C . Oil temp when hot is just before 100C sometimes when kicking just above 100C.
In July 2600 mls trip is awaiting for me in mine much loved M5 , dont want any surprises.
Thanks for your toughs.
Kolega1982 is offline
Old 22nd June 2016, 02:22 PM
gmak
Originally Posted by Kolega1982 View Post
Hi
TA calibration after been fit is been done as well - many different opinions do the need or no , i have calibrated mines.
Thanks for your thoughts
How did you calibrate the TAs? There is nothing in ISTA for this. There are tests, but no calibration. I believe that happens when you put the key in 2nd position without starting the car.
For your SMG: Did you reset adaptations? If so, it will be a while until the tranny learns how you want to drive and "slams" you with the shifts, no? I'm sure that there are experts here who can confirm or contradict this.
gmak is offline
Old 22nd June 2016, 02:42 PM Thread Starter
Kolega1982
Kolega1982's Avatar
TA- not sure as mine indy is got GT1 and he said there is option to tell that new one have been installed. No any magic just confirmation of new item is been installed. That pretty much his words.
Reset adaptations ?
After clutch is being fitted , adaptation is been required to tell car is got new clutch and there is new position of the clutch surface if i understand correctly. After this adaptation is been done now break in process and while this is like ZF model gearboxes which is learning style your driving ?
Old 22nd June 2016, 02:49 PM
gmak
I think all he did was clear the fault codes. There is nothing to say new TAs are installed. Yes - like ZF. It learns your style of driving. Also, (I don't know where you are located), but the previous owner may have loaded the SMG Euro tune - which is generally smoother shifting, and the adaptation put back the old SMG software (? just guessing).
gmak is offline
Old 22nd June 2016, 02:54 PM Thread Starter
Kolega1982
Kolega1982's Avatar
For fault codes i have mine Wi Fii Carista.
What is your coolant temp , to me mine seems quiet low :/
BTW - From UK
Old 22nd June 2016, 03:01 PM
gmak
I have no idea about coolant temperature. That's the least of my worries. I'm still trying to resolve the TA problem, so I'm not driving the car.
gmak is offline
Rate This Thread
M5 a new adventure bulletbikeguy E39 M5 and E52 Z8 Discussion 24 24th June 2016 11:52 PM
snow adventure Night Train E39 M5 and E52 Z8 Discussion 12 5th April 2013 03:56 PM
My M5 Adventure DryHeatPanzer E60 M5 and E61 M5 Touring Discussion 20 1st December 2010 07:41 AM
European Adventure in an M5 dscam E34 M5 Discussion 23 3rd May 2010 10:10 PM
m5 adventure videos 18790775 E39 M5 and E52 Z8 Discussion 6 27th November 2001 02:50 AM
