Dinan Exhaust confusion - BMW M5 Forum and M6 Forums
 6Likes
  • 3 Post By Fiftytwoeighty
  • 1 Post By lexustbs
  • 1 Post By Fiftytwoeighty
post #1 of 8 Old 22nd June 2016, 01:47 AM Thread Starter
lexustbs
lexustbs's Avatar
So I was getting to pull the trigger on a Corsa exhaust today when some pictures of other members systems got me confused. My exhaust had a clamp already between "section 2" and 3. So I look further and the midsection pipes are also not stock.
So long story short, I can verify I have a Dinan section 2 and the previous owner removed the section 3 before selling. Question now is, am I losing power because of a modified section 2 and stock section 3? Also how can I identify if I have a Dinan section 1? Thanks!
Sent from my XT1254 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #2 of 8 Old 22nd June 2016, 02:27 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Dinan 1 replaces stock secondary cats
Dinan 2 replaces stock combination H-pipe/resonator
Dinan 3 replaces stock mufflers
Dinan 1 can be in three configurations:
1) no resonator, track pipe (loudest),
2) 3.5" resonator (not quite as loud as the loudest),
3) 4.0" resonator (slightly louder than stock, but quieter than 3.5" resonator)
Dinan 2 is the X-pipe.
Post a picture if youre confused.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
The Following User Says Thank You to Fiftytwoeighty For This Useful Post:
Hasan Shaikh (22nd June 2016)
post #3 of 8 Old 22nd June 2016, 03:25 AM Thread Starter
lexustbs
lexustbs's Avatar
Judging by your info I assume that I just have section 2 currently then the OEM section 3. Do you think there is a sound increase with a section 2 only? Now I guess my only exhaust choice is Dinan. Juat have to wait for a good used one.
2009 BMW M5 STOCK
lexustbs is offline
post #4 of 8 Old 22nd June 2016, 04:42 AM
Fiftytwoeighty
This should help or confuse you more!
https://www.m5board.com/vbulletin/e60...esonators.html
https://www.m5board.com/vbulletin/e60...resonator.html
https://www.m5board.com/vbulletin/e60...our-clips.html
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #5 of 8 Old 22nd June 2016, 04:46 AM
Fiftytwoeighty
Looks like only a Dinan 2, connected to the stock secondary cats. You will get a little more bark and a tiny bit of bite.
~Woody
~I FRACKING!
~Viva La Wolfpack!
The Following 2 Users Say Thank You to Fiftytwoeighty For This Useful Post:
post #6 of 8 Old 22nd June 2016, 08:44 AM
Hasan Shaikh
Hasan Shaikh's Avatar
The exhaust sections are pretty standard for most manufacturers. I was using Miestershaft Section 1 with Tubi Sections 2 and 3 and they mated perfectly.
IMHO! You can use any section 3. If there is a slight difference in length, it can be fixed easily.
Good Luck!
Hasan Shaikh is offline
post #7 of 8 Old 23rd June 2016, 03:43 AM Thread Starter
lexustbs
lexustbs's Avatar
Thank you for all the good responses.
My hope is somebody reads this and wants to remove their Dinan and go back to stock. I could send them my exhaust already cut at the right spot to reinstall and they could send me theirs...... takers? Takers?
2009 BMW M5 STOCK
lexustbs is offline
post #8 of 8 Old 23rd June 2016, 07:46 AM
Th0nor
Th0nor's Avatar
Why do you want to replace the section 2, you've not lost your secondary cats, I can see them in the photos and unless the previous owner swapped out the headers for longtube or decat option, you'll have your primary cats. So your emission tests will be OK.
The dinan section 2 looks to be an xpipe. This vs the stock H pipe equates to a slight increase in noise levels (it'll sound sportier), you might get a tiny bit of drone, but I doubt you'll hear any, I don't on mine.
I'd keep it, not worth the hassle of swapping it out. Then you should replace the mufflers with Tubi or Eisenmann, stock really suppresses that V10. It's like your driving around with 2 pillows for back boxes.
Sent from my ONE A2003 using Tapatalk
2007 LCI Interlagos Blue ///M5 e60
Performance
Evolve (SS) Long Tube Headers [Feb'16]
Evolve Stage 3 Tune for Catless Headers [Feb'16]
Tubi Style Sport Mufflers [Jun'16]
Tubi Style X-Pipe [Jun'16]
Eventuri Intakes [Nov'16]
Th0nor is offline
Exhaust Confusion.. rxpwhistler1 E39 M5 and E52 Z8 Discussion 6 4th September 2009 02:20 PM
Dinan software confusion at dealer? help AlpineMsix E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 27th January 2009 01:33 AM
Exhaust confusion 3rd One E39 M5 and E52 Z8 Discussion 15 7th October 2005 06:01 AM
Exhaust confusion Bader E34 M5 Discussion 6 10th June 2004 10:41 PM
exhaust comparison confusion m5rud E39 M5 and E52 Z8 Discussion 28 12th June 2003 04:41 PM
