All 10 cylinders misfiring - Engine malfunction - reduced power - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By lexustbs
post #1 of 9 Old 20th June 2016, 10:31 PM Thread Starter
the7thson
Question All 10 cylinders misfiring - Engine malfunction - reduced power
Hey guys,
I left my garage and got about 1 mile from the house, was driving in traffic at about 35mph in 3rd gear and all of a sudden - the car felt like it buckled in the front and I got the message saying "Engine Malfunction - Reduced Power". All the assists shut down completely including power steering, I was barely able to turn on to a side street to pull off and had to push the car off to the side of the street.
I tried to restart the car a couple times, but to no avail. It would start to turn over but the engine never turned on. I waited 20 minutes and tried again, it restarted and then I got the "Increased Emissions" message, which hasn't gone away. The car drove ok after that but I kept it below 3k revs, it wasn't in limp mode or anything. I drove it to the service shop where it currently sits.
Here are all the error codes pulled, a total of 16:
  1. 27A4 - Tank Ventilation Function Test Bank 1
  2. 2B35 - Combustion misfire with Cut-Out Cylinder 1
  3. 2B36 - Combustion misfire with Cut-Out Cylinder 2
  4. 2B37 - Combustion misfire with Cut-Out Cylinder 3
  5. 2B38 - Combustion misfire with Cut-Out Cylinder 4
  6. 2B39 - Combustion misfire with Cut-Out Cylinder 5
  7. 2B3A - Combustion misfire with Cut-Out Cylinder 6
  8. 2B3B - Combustion misfire with Cut-Out Cylinder 7
  9. 2B3C - Combustion misfire with Cut-Out Cylinder 8
  10. 2B3D - Combustion misfire with Cut-Out Cylinder 9
  11. 2B3E - Combustion misfire with Cut-Out Cylinder 10
  12. 2B41 - Combustion misfire with Cut-Out Several Cylinders
  13. 2B57 - Safety Concept Manager Action
  14. 2B96 - Safety Concept Manager Action
  15. 27CF - Building up of Fuel Pressure Sensor Fuel Pump Feed
  16. 2722 - Fuel Pressure Sensor Signal
Any idea what the underlying issue might or what to expect? I imagine the cylinders misfiring is a symptom rather than a cause. Could this due to some type of fuel pressure related issue? Anyone have any similar experiences?
Thank you in advance.
the7thson is offline
post #2 of 9 Old 21st June 2016, 01:15 AM
gmak
gmak is offline
post #3 of 9 Old 21st June 2016, 03:16 AM
lexustbs
lexustbs's Avatar
I got these same codes when I was messing with my fuel pump. I would suggest you check fuel pressure at the motor. If the pressure is good then my next move would be to see what the indicated pressure is via diag computer. If these values are different then it's a sensor issue. If the values match, then it's time to go into the tank and replace the pump or clogged filter.
Also, when you say the car would not start was it just cranking for 15 seconds or kinda sputter and die?
Sent from my XT1254 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #4 of 9 Old 21st June 2016, 05:20 AM Thread Starter
the7thson
Originally Posted by gmak View Post
Looks like you have a problem with your fuel pump.
That's what I would guess, currently awaiting word from the shop tomorrow.
Thanks for the detailed reply! The car is in the shop so hopefully they should have a diagnosis tomorrow. When the car wasn't starting, it would crank for 2-3 seconds, then sputter and die a second later. The rev counter would limp getting to maybe 600 revs or so before it died. This happened 4-5 times before I gave up and decided to wait 20 minutes
post #5 of 9 Old 21st June 2016, 11:36 AM
lexustbs
lexustbs's Avatar
Fuel pressure sensor would be my guess. Car thinks it has no pressure so it's dumping fuel into the cylinders this flooding out the motor. About a $175 part that is stupid simple to replace.
2009 BMW M5 STOCK
lexustbs is offline
post #6 of 9 Old 21st June 2016, 07:21 PM Thread Starter
the7thson
Yep, they just said that the fuel sensor is faulty so they're replacing that first before doing further diagnostics. I'll post back with results, thanks!
post #7 of 9 Old 23rd June 2016, 02:55 AM
lexustbs
lexustbs's Avatar
Any update on the situation?
2009 BMW M5 STOCK
lexustbs is offline
post #8 of 9 Old 23rd June 2016, 05:46 AM Thread Starter
the7thson
Yep, they have to wait to get a new fuel sensor, should be in tomorrow. They said they'll replace it and then run further diagnostics in case there are any other issues. I'll definitely post back with results.
post #9 of 9 Old 1st July 2016, 11:34 PM Thread Starter
the7thson
I just realized that I never posted back with the final result. Replacing the fuel sensor seems to have been the only cure needed. It was <$250 including parts and labor, all covered by insurance. I've had the car back for several days, everything seems to be in great shape. So far so good, thanks everyone.
Engine Malfunction - Reduced Power Ogjohnsmith E60 M5 and E61 M5 Touring Discussion 8 26th June 2016 03:15 AM
Engine Fault! reduced power - 2008 e61 m5 touring - misfiring SGE60 E60 M5 and E61 M5 Touring Discussion 14 21st May 2015 02:56 AM
Engine fault. Reduced power. All cylinders misfired... JVP E60 M5 and E61 M5 Touring Discussion 8 27th October 2014 06:03 AM
2007 BMW M6 Engine Malfunction! Reduced Power! DSC Malfunction scp624 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 26th August 2014 11:22 PM
Engine Malfunction, reduced power! Jackson1019 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 170 22nd July 2013 11:50 PM
