AUX Plug not there on e60 M5? - BMW M5 Forum and M6 Forums
post #1 of 4 Old 17th June 2016, 05:01 AM Thread Starter
epiphanyray
epiphanyray's Avatar
Hey guys, so I am helping a friend setup his car to have an Auxiliary Option for music... I personally have a 2004 525i, and was able to do it without a problem. Programmed the car with NCS Expert, and added AUX in the entertainment options. I then made a 3 wire cable, left channel, right channel and ground. I then proceeded to remove my center trim panel, and simply removed the CD PLAYER Plug. Behind the plug, i hooked up my cable to pin 2, 7 and 8. Worked perfectly.
So, I went to do this same operation on my friend's e60 M5. I programmed it first using NCS expert, and AUX came on the entertainment menu without a problem. I then proceeded to remove center dash console trim and removed CD Player plug. To my surprise, the 12 pin plug that was on my 2004, was not there. I simply could not hook it up.
Take a look at the video please:
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Please help! can I not add AUX to this car? By the way, it is a NOVEMBER 2005 Built car.
epiphanyray is offline
post #2 of 4 Old 17th June 2016, 05:31 AM
wojcikd
You probably know this but my 04/06 build has an AUX by the rear went in the center console.
wojcikd is offline
post #3 of 4 Old 17th June 2016, 02:14 PM Thread Starter
epiphanyray
Thanks. I know many of them have them in the center console. But this one doesnt. Already checked.
This is a euro version.
Anyone?
2003 Imola Red M5
post #4 of 4 Old 18th June 2016, 05:40 PM Thread Starter
epiphanyray
07 E60 Aux Input only 1 channel jmeyer216 E60 M5 and E61 M5 Touring Discussion 3 17th August 2018 08:17 PM
Aux Option w/DSP for pre-factory-aux cars. dookateh E39 M5 and E52 Z8 Discussion 8 13th April 2013 06:59 PM
E60 2006 M5 just wondering any AUX cjjk336 E60 M5 and E61 M5 Touring Discussion 7 18th November 2011 10:21 AM
E39 Want to buy: Want 2000 E39 M5 Oil Pan with Non Stripped Drain Plug Hole and Plug blks4 Parts / Other For Sale or Wanted 0 15th August 2011 06:25 PM
Aux / USB plug DooRow_88 E60 M5 and E61 M5 Touring Discussion 16 10th May 2011 10:51 PM
