Opinions needed on this rod bearing kit - BMW M5 Forum and M6 Forums
post #1 of 4 Old 16th June 2016, 01:33 AM Thread Starter
SliM5
SliM5's Avatar
As title states, I'm looking for opinions on this kit from ECS tuning.
https://www.ecstuning.com/ES2981592/
I will be purchasing the BE bearings, but just wanted expert opinions on this kit and how it compares.
Thanks in advance.
SliM5 is offline
post #2 of 4 Old 16th June 2016, 10:18 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Hasan Shaikh is offline
post #3 of 4 Old 16th June 2016, 12:07 PM
Th0nor
Th0nor's Avatar
The problem with oem bearings with coatings is the clearance is even less... Since is the oem bearing with an additional layering.
The BE bearings are made with the same materials (lead/copper) and manufactured by the OE supplier of the stock ones. They have made them slightly smaller to increase the clearance between the bearing and crankshaft to alleviate the problem of bearings failing apparently due to not enough oil getting into the clearance when it's cooler and thicker.
I'll be buying them when I do my rod bearings. There's not meaningful data on them yet as I don't think anyone has run them for say over 100k miles yet...
The other thing to consider is if you have an per LCI model, 05/06, you don't have 2 sumps plugs. Another probable cause or contributing factor to rod bearing failure can be the dirty degraded oil in the front sump that's never drained, this has been shown to be over 2 litres! Not good. If you do have an 05/06 I would think about drilling a sump hole into the front sump.
Sent from my ONE A2003 using Tapatalk
2007 LCI Interlagos Blue ///M5 e60
Performance
Evolve (SS) Long Tube Headers [Feb'16]
Evolve Stage 3 Tune for Catless Headers [Feb'16]
Tubi Style Sport Mufflers [Jun'16]
Tubi Style X-Pipe [Jun'16]
Eventuri Intakes [Nov'16]
Th0nor is offline
post #4 of 4 Old 16th June 2016, 07:05 PM Thread Starter
SliM5
SliM5's Avatar
According to my latest oil report, I should get to it on ordering my BE bearings. The Lab report date is 06/15/2016.
Thanks for the input.
I'm also considering shipping my car to Boston for the work, as I have yet to find a quality indy in the Houston area that can tackle this for me.
SliM5 is offline
Another rod bearing question. StevesM5 E39 M5 and E52 Z8 Discussion 28 31st May 2016 03:25 AM
Parts needed for Rod Bearing change? DaveM6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 25th September 2014 12:36 AM
rod bearing messier781 E39 M5 and E52 Z8 Discussion 9 24th March 2014 05:49 AM
Rod bearing ?'s HuziM6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 24 26th January 2014 12:03 AM
Rod Bearing Tolerance? Rod Bearing Advice? lefebv19 E39 M5 and E52 Z8 Discussion 21 17th August 2011 04:36 AM
