Still having misfire on cylinder #5 - BMW M5 Forum and M6 Forums
post #1 of 4 Old 4th June 2016, 08:20 PM Thread Starter
andrei_g17
Hi guys!
Decided to take the beast out for a spin a few days ago, and noticed that the engine was running a little rough but no codes came up (Max speed was around 50mph). I took it out again and was driving on the freeway (Max speed was 65-70) and then I received "Service Engine, Reduce Power" Code. I plugged in a scanner and got a P305 Cylinder 5 misfire.
I replaced all 10 plugs about 3k miles ago, plus 2 new coil packs (including #5). I swapped coil packs was still getting a misfire on #5. I swapped the Ionic Modules, still the same misfire. What else is left for me to check? I take the car out every 2 weeks, currently sitting with 95k miles. I'd appreciate any help thank you!
andrei_g17 is offline
post #2 of 4 Old 4th June 2016, 09:59 PM
alexbigojin
alexbigojin's Avatar
alexbigojin is offline
post #3 of 4 Old 22nd June 2016, 03:30 AM
Pickman
Pickman's Avatar
Clean or replace the MAFS. I had same issue after a few runs at HPDE days at Mid Ohio. Hot days and hard driving. I changed plugs, coils and injectors. did it again last week. Always reads misfire in #5. M5 boards suggest looking into your MAFS.
Pickman is offline
post #4 of 4 Old 7th July 2016, 05:53 AM
dr_dirtg
dr_dirtg's Avatar
dr_dirtg is offline
Tags
cylinder , misfire
Cylinder 3 misfire fitabe E60 M5 and E61 M5 Touring Discussion 6 1st October 2015 02:23 AM
First, cylinder 1 misfire; now misfire moved to cylinder 8 misfire huh?! E60 M5 and E61 M5 Touring Discussion 8 10th March 2015 05:31 AM
Misfire Cylinder 3 M5 Junky E60 M5 and E61 M5 Touring Discussion 19 14th March 2014 07:48 PM
Cylinder misfire! IMOLA_RED///M5 E39 M5 and E52 Z8 Discussion 1 25th February 2012 08:30 PM
Whats the likely cause of "199 Cylinder #4 misfire + cylinder cutoff"? aaronmiles E39 M5 and E52 Z8 Discussion 7 24th August 2007 08:18 PM
