Soft close not latching - BMW M5 Forum and M6 Forums
post #1 of 4 Old 3rd June 2016, 10:22 PM Thread Starter
nsxlife
Rest of my doors work fine but on driver's door the soft close pulls in momentarily, doesn't quite latch, then goes back out to the unclosed position. Normally I would think replace the actuator, however it IS working almost, or at least has power and some function.
Is there a cable adjustment or something I can check? Looking at the parts diagram is a bit confusing as to how it actually works.
nsxlife is offline
post #2 of 4 Old 4th June 2016, 01:05 PM
rt7085
rt7085's Avatar
If it is not obviously broken or obviously obstructed from closing, I think the actuator sees excessive current draw and back off thinking that it could be limb or so. Automatic windows and sunroofs work like that too. They go up and if they get blocked from closing, it is the excessive current measurement on the riser motor that gets sensed. When to too high, it opens again. Did you change/repair anything recently, like door rubbers, or the like? Something must have changed if it was working right before.
When I changed my sunroof seal with new rubber, I had a similar issue. The stiffer rubber tripped the detection and the sunroof would not close. INPA has a calibration procedure to adjust for such a change. I bet that the soft closing doors have something similar. Use INPA, DIS or ISTA/D. I do not have soft closing doors, so I cannot check. Who needs this hoopla anyways :-)
You have to make sure that there is truly no obstruction! Because the sensor is ignored during the calibration measurement, so the motor is going to try as hard as it can to close. It measures the current in that process and then sets a new trip limit.
rt7085 is offline
The Following User Says Thank You to rt7085 For This Useful Post:
nsxlife (23rd June 2016)
post #3 of 4 Old 23rd June 2016, 05:22 PM Thread Starter
nsxlife
This is probably why I am getting increased battery discharge message too.
nsxlife is offline
post #4 of 4 Old 25th June 2016, 12:32 PM
rt7085
rt7085's Avatar
Not necessarily true. If it sees and obstruction it will try to close it until the overcorrect trips. After that it should go dormant current wise. Of course, if it is electrically broken, that may be true. But it it is not, it may be something else in the the car. Door handle electronics have been found to be battery dischargers in a few other posts. Get the car to a heathy charge by driving it. Then disconnect the handle electronics after parking and wait the same amount of parking time it takes you for the discharge error to show up. (Or simply measure the sleep current.)
rt7085 is offline
Soft close doors fangster E60 M5 and E61 M5 Touring Discussion 0 5th November 2006 05:10 AM
SOFT CLOSE DOORS rsinha E60 M5 and E61 M5 Touring Discussion 17 25th May 2006 06:21 AM
Soft close doors? TestnDoc E60 M5 and E61 M5 Touring Discussion 6 20th November 2005 07:16 PM
Soft close doors? test E60 M5 and E61 M5 Touring Discussion 9 13th November 2005 06:50 PM
Soft Close - when and will you wait for it? WilliamCheung E60 M5 and E61 M5 Touring Discussion 17 7th October 2005 11:19 AM
