Full Spec Lighting Build for this Widebody BMW E61 - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 11 Old 31st May 2016, 06:35 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
My buddy is building a crazy E61 and asked my to handle the lighting, although I HATE working on these headlights, I couldn't leave a fellow E61 owner hanging. LTMW is handling the air ride, Pandem widebody install, and paint.
Build Specs:
Morimoto MD2S Bi-Xenon projectors (black demon eye)
Morimoto xb LED corner light
Morimoto xb D2S bulbs
Valeo D1S-D2S Ignitors
OEM Hella ballasts
Angel Eye delete
Tinted Fins
Black Housing paint
LED turn signal bulbs
Blacked out tail housings + frosted LED tubes (lens will receive full red-out via LTMW)
Full lens correction + Opti-Lens
New OEM gaskets
Full service headlight removal and installation
Evan
BEFORE
LENS CORRECTION
Before
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
+ Opti Lens
After Lens Correction
Not much too much room to work with on these dynamic BMW headlights
This may not mean anything to most people but @umichchris will understand the accomplishment of opening and clearing all the oem permaseal...
I drilled some additional holes and mounted the MD2S projector with the oem hardware in the oem mounting locations! Clean! Projector also has a black demon eye.
Morimoto xb LED fogs getting paint-taped prior to mounting
Some quick setting putty to hold them in place
JB Kwik
Oem wiring was in bad shape so I trimmed and protected the exposed wires.
Soldered wiring with a PNP connection for the LED corner light.
OEM fins
After treatment
Corner lights after paint
Fitment came out super clean, really happy about the oem+ appearance
D1S-D2S ignitors mating the oem ballast and MD2S bulbs.
After paint
Prior to installing the lens
Oem output
Output after
All sealed up
Tails
Both
Install:
Before
After
2008 N54-Powered E61 M5 Wagon: ~600whp ~600wtq
- AWD-RWD Conversion, OEM M5 Drivetrain Retrofit, Manual Trans Swap, Spec 3+ Clutch, MFactory SMFW
- OEM M5 Brakes, KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC 19x9.5 19x11, Hankook V12
- Hexon RR550 Hybrid Turbos, Custom Turbo Inlets, AR DP, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC,
- BMS JB4, E85 Flash, Fuel-It Stage 2 LPFP, EOS Port Injection Manifold, Custom 3" Exhaust
- OEM M5 Front Bumper, OEM M5 Front Fenders (Vents Deleted), OEM M5 Skirts, OEM M5 Mirrors, M-Tech Rep Rear Bumper
- Quad Projector Headlights, Custom Tail Lights, Rigid SR 6" Reverse Light, Full LED Interior/Exterior Lighting
ucsbwsr is offline
post #3 of 11 Old 31st May 2016, 08:09 PM
umichchris
umichchris's Avatar
you gotta be careful... the MODs will ban/lock your threads when posting work you complete for others...they will want you to be a paid sponsor...something i learned the hard way...which is why i no longer share my crazy builds on this site :/
I do custom headlights & taillights
E46 ///M3 Vert - massive overhaul/rebuild project details here
E60 ///M5 Project #Patina
E36 ///M3 (sold) 5MT sedan
umichchris is offline
post #4 of 11 Old 31st May 2016, 08:30 PM
M5Ian
Is that not the whole point of forums like this, to share your builds and help others out?
M5Ian is offline
post #5 of 11 Old 31st May 2016, 10:17 PM
ACG
ACG's Avatar
Not unless you make a business out of doing it.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #6 of 11 Old 31st May 2016, 10:20 PM
M5Ian
Eh so if you do it for fun or to help others that's wrong but if you do it to make money that OK.... Well that's a load of **** if you ask me.
M5Ian is offline
post #7 of 11 Old 31st May 2016, 11:40 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
Yea, I totally get it. If you are capitalizing on the forum to reach an audience that you would otherwise not have I understand how they would want to be compensated that service.
However on the flip-side of that forums are all content driven so if you are scaring away potential sponsors with aggressive fees, it is possible the forum would only be hurting itself in the long run. In some extreme cases I could even see forums buying exclusive rights to a product/service, where the vendor is actually making money off the forum due to the high amount of traffic the vendor is bringing in.
Personally I think I have made it clear in my various posts the I have zero-to-barely any interest in future E6X builds and I hope the mods understand that. Of course if I am out of line hopefully they will bring it to my attention and we can resolve any issues.
I get a lot of enjoyment reading before/after and build threads; I went through the effort of sharing these headlight builds as others may find them interesting. I mean we are all car dorks at heart.
Evan
ucsbwsr is offline
post #8 of 11 Old 1st June 2016, 09:30 PM
umichchris
umichchris's Avatar
i agree with you broham.
i do a lot of lighting mods...but part time. its def not a money maker but a passion. and im def not gna put 30 man hours into some super cool creative light set-up without charging money for it lol
and if you do multiple projects, you had better protect yourself by making it a business and separate your labor from personal liability bc there are tons of scammers out here. but once you do that and share your work then you've gotta be a forum sponsor...thats the trick of it. so tread lightly but keep doing cool sh!t bro!
Evan
post #9 of 11 Old 2nd June 2016, 02:13 PM
horse86
horse86's Avatar
This is a build thread...not an advertisement. I don't see a problem what so ever. Carry on with your awesome work and pics
- Justin
/// 2008 Space Grey M5 (SMG)
2009 Triumph Speed Triple 1050
2008 Range Rover FullFat
horse86 is offline
post #10 of 11 Old 29th June 2016, 07:26 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
This wagon has been at LTMW forever, since March 2015 to be exact. I am eagerly awaiting for it to be finished and released out into the wild so I (or someone) can take some legitimate photos of the build.
Patiently waiting...
Evan
ucsbwsr is offline
Full Spec Lighting Build for this Widebody BMW E61 ucsbwsr E60 M5 and E61 M5 Touring Discussion 5 29th May 2019 01:49 AM
Full Spec Lighting Build for this Widebody BMW E61 ucsbwsr E60 M5 and E61 M5 Touring Discussion 5 7th June 2016 04:35 AM
Introducing SPEC - Dream. Build. Drive. randywei E60 M5 and E61 M5 Touring Discussion 20 28th March 2015 03:28 AM
Full Shoot!!!!!!! Wheels Boutique & Vorsteiner World's First Widebody GTRS3 E93 M3 Ca Wheelguy E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 17 17th July 2012 03:13 AM
3200lb Supercharged Widebody build thread linearstar147 E39 M5 and E52 Z8 Discussion 234 27th February 2012 08:12 PM
