Full Spec Lighting Build for this Widebody BMW E61 - BMW M5 Forum and M6 Forums
 3Likes
  • 2 Post By ucsbwsr
  • 1 Post By Slamfire
post #1 of 6 Old 31st May 2016, 06:35 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
My buddy is building a crazy E61 and asked my to handle the lighting, although I HATE working on these headlights, I couldn't leave a fellow E61 owner hanging. LTMW is handling the air ride, Pandem widebody install, and paint.
Build Specs:
Morimoto MD2S Bi-Xenon projectors (black demon eye)
Morimoto xb LED corner light
Morimoto xb D2S bulbs
Valeo D1S-D2S Ignitors
OEM Hella ballasts
Angel Eye delete
Tinted Fins
Black Housing paint
LED turn signal bulbs
Blacked out tail housings + frosted LED tubes (lens will receive full red-out via LTMW)
Full lens correction + Opti-Lens
New OEM gaskets
Full service headlight removal and installation
Evan
BEFORE
LENS CORRECTION
Before
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
+ Opti Lens
After Lens Correction
Not much too much room to work with on these dynamic BMW headlights
This may not mean anything to most people but @umichchris will understand the accomplishment of opening and clearing all the oem permaseal...
I drilled some additional holes and mounted the MD2S projector with the oem hardware in the oem mounting locations! Clean! Projector also has a black demon eye.
Morimoto xb LED fogs getting paint-taped prior to mounting
Some quick setting putty to hold them in place
JB Kwik
Oem wiring was in bad shape so I trimmed and protected the exposed wires.
Soldered wiring with a PNP connection for the LED corner light.
OEM fins
After treatment
Corner lights after paint
Fitment came out super clean, really happy about the oem+ appearance
D1S-D2S ignitors mating the oem ballast and MD2S bulbs.
After paint
Prior to installing the lens
Oem output
Output after
All sealed up
Tails
Both
Install:
Before
After
2008 N54-Powered E61 M5 Wagon: ~600whp ~600wtq
- AWD-RWD Conversion, OEM M5 Drivetrain Retrofit, Manual Trans Swap, Spec 3+ Clutch, MFactory SMFW
- OEM M5 Brakes, KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC 19x9.5 19x11, Hankook V12
- Hexon RR550 Hybrid Turbos, Custom Turbo Inlets, AR DP, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC,
- BMS JB4, E85 Flash, Fuel-It Stage 2 LPFP, EOS Port Injection Manifold, Custom 3" Exhaust
- OEM M5 Front Bumper, OEM M5 Front Fenders (Vents Deleted), OEM M5 Skirts, OEM M5 Mirrors, M-Tech Rep Rear Bumper
- Quad Projector Headlights, Custom Tail Lights, Rigid SR 6" Reverse Light, Full LED Interior/Exterior Lighting
ucsbwsr is offline
post #2 of 6 Old 19th May 2019, 02:14 PM
Sebastian Andersson
Sebastian Andersson is offline
post #3 of 6 Old 19th May 2019, 03:36 PM
pmalik
I think this is the second or third headlight seat I've seen you do - outstanding work! Quick question - will LCI fins into pre-LCI headlights? I actually have a set of fins, but it looks like the pre-lci shrouds are a bit different? Also any tips of opening the lenses without cutting?
pmalik is offline
post #4 of 6 Old 20th May 2019, 09:39 PM
Slamfire
Slamfire's Avatar
A left hand drive E61 M with a manual swap would be my keep forever dream car.
Also those lights look great.
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
post #5 of 6 Old 21st May 2019, 04:36 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
Originally Posted by Sebastian Andersson View Post
Do you have more pictures of your friends bmw or does he have a instagram?
He does but that wagon AFAIK is still sitting at LTMW where I installed the lights. lol
LCI fins won't work in pre-LCI unless you create a custom solution. As for opening the lights: patience, heat cycles, good expanding pliers, and some sharp chisels to clear the channels.
ucsbwsr is offline
post #6 of 6 Old 29th May 2019, 01:49 AM
umichchris
umichchris's Avatar
nice build. ive done a couple of these types of upgrades in the past...albeit with different items that were on the market a couple years ago. its such a huge improvement over the OEM set-up or even a lot of current gen OEM set-ups.
I do custom headlights & taillights
E46 ///M3 Vert - massive overhaul/rebuild project details here
E60 ///M5 Project #Patina
E36 ///M3 (sold) 5MT sedan
umichchris is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gnne60
Introducing SPEC - Dream. Build. Drive. randywei E60 M5 and E61 M5 Touring Discussion 20 28th March 2015 03:28 AM
Evan's E61: Upgraded Exterior Lighting, LED AE, LED Reverse, 55w D2S, Comparison HID Bulb Pictures ucsbwsr E60 M5 and E61 M5 Touring Discussion 3 28th March 2014 10:54 PM
Full Shoot!!!!!!! Wheels Boutique & Vorsteiner World's First Widebody GTRS3 E93 M3 Ca Wheelguy E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 17 17th July 2012 03:13 AM
And It All Starts With The First Mod (Full Build 08 M6) VGM6 E60 M5 and E61 M5 Touring Discussion 2 13th July 2012 12:11 AM
3200lb Supercharged Widebody build thread linearstar147 E39 M5 and E52 Z8 Discussion 234 27th February 2012 08:12 PM
