Dan's Custom Headlights - Page 2 - BMW M5 Forum and M6 Forums
 9Likes
post #11 of 20 Old 2nd June 2016, 09:48 PM
m5 guy
m5 guy's Avatar
It's been 15 minutes. Where is the thread?
2016 F10 M5 Space Gray-Black
2010 E60 M5 Saphire Black-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
m5 guy is offline
post #12 of 20 Old 2nd June 2016, 10:12 PM
LeeDan00
LeeDan00's Avatar
HAHA. Still at work. I'll do this soon. =)
Dan
2007 ESS SC'd 6MT
ESS VT2-650 Supercharger with Intercooler
ESS Alpha N Tune
Vortech BOV vta to replace the stock recirculating one (OMG loud!)
Rod bearings changed 8/10/15 at 88k miles
Dinan sections 1 - 3. Straight pipe 4'' "loudest" version Dinan offers. (Sounds amazing at WOT)
Secondary cats and resonator removed
KWv3
Flat bottom steering wheel all leather with M stitching
RPi SV1 Oil Cooler in silver
RD Sway Bars
Brembo BBK 405/380mm in factory yellow
Dinan Monoballs
Hardwired V1
CF hood by Seibon. E9x style with hood bump and functional vents
CF Hamann front lip
CF rear diffuser
CF trunk lid from member Socale39
ZHP shift knob
BBS fi-r with Michelin Cup2's
Custom built headlights by Evan with fx-r projectors and Orion v2's and full blackout
Gloss black kidneys and side vents
Gloss black M5 badge
Gloss black ESS badge
LCI tails with special brake effect done by Simon aka BCD
LED front, side, and license plate
Dyno'd 598wrhp and 413tq on Dynojet 10/29/15 on stock headers
2010 Dinan S3 5.7L complete catalog car serial numbered 6MT
LeeDan00 is offline
post #13 of 20 Old 3rd June 2016, 04:23 PM
Koqui79
I would love to take on a project like this but the scariest part to me is opening up and resealing the lights. I'm afraid to mess that up.
Is there a detailed DIY or video on how to do this? Or could you share more details on that part of the project?
Sent from AutoGuide.com Free App
Koqui79 is offline
post #14 of 20 Old 3rd June 2016, 05:56 PM
Bucky
Same here, whats the easiest way to open these lights up? What do you seal them with?
Last thing I want is moisture trapped in the light.
Bucky is offline
post #15 of 20 Old 3rd June 2016, 07:05 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
This is the sort of project that it is hard to consider a "DIY" like on another forum when people ask if I am going to create a DIY for my manual transmission swap and M5 drivetrain retrofit.... sure: Bentley manual, RealOEM, and Google! That is your DIY lol
I can offer some pointers from my personal experiences, take them for what they are worth. If you are serious about doing this on your own headlights then I suggest purchasing a salvage headlight off ebay to practice on, even if all the steps and laid out with the proper tools it will come down to execution on your end so it pays to practice.
That being said, here are some tips:
- BMW permaseal is nasty stuff where some permaseals have a more plastic or silicone type consistency, the BMW stuff is like a hard rubber and sticks to plastic very well and only becomes more cooperative at higher temps 240+F.
- Some E6X headlights can be pried opened and some can not. If you are successful then you will have the pleasure (sarcasm) of clearing all the permaseal from the channels so you can use butyl to reseal. This process is long and arduous and makes you think at times it may be easier just to cut the suckers open. The benefit of prying them open and clearing the channel is you can replace the permaseal with butyl and reseal the headlight in an oem fashion.
- Cutting the headlights open is more common for E6X housings. The name of the game is remove as little material as possible, any sort of cutting wheel or router type tool will remove material is it cuts and you will have a small void to fill when resealing. A chisel based cutter like a multi tool will separate the lens without removing as much material. Whichever you choose the name of the game is removing as little material as possible.
- I think Umnitza has some tutorials on opening the E6X headlights to look those up for where to cut.
- Deburr the edges if you cut with a tool that created some.
- I like to sand/rough up the lens near where it was cut to help promote sealant adhesion.
- For sealing I have used ATV silicone and also 3M Window Weld but I find that since the lens really needs some structural rigidity so before applying the sealant I like to tack weld the lens in place with some JB Kwik, I usually do 4-5 spots per housing.
- For sealing I then fill the void between the lens (created from removing material during cutting), and when that is dried, add another layer on top. I recommend doing small applications and multiple layers as opposed to dumping a huge amount of sealant on it at once. If you have too much external material on the housings the gaskets will no fit properly.
- Make sure to take the front bumper off for removal and install, it is possible to get the headlights out and in with the bumper but NOT recommended. Take special care that the headlights are properly aligned in the brackets and are seated in an oem fashion (lining up with fender, hood, bumper etc.) If the headlights are installed crooked there can be pressure applied to the lens and the seal will be more likely to fail if unnecessary pressure is applied to to misinstallation.
- Practice, practice, practice
2008 N54-Powered E61 M5 Wagon: ~600whp ~600wtq
- AWD-RWD Conversion, OEM M5 Drivetrain Retrofit, Manual Trans Swap, Spec 3+ Clutch, MFactory SMFW
- OEM M5 Brakes, KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC 19x9.5 19x11, Hankook V12
- Hexon RR550 Hybrid Turbos, Custom Turbo Inlets, AR DP, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC,
- BMS JB4, E85 Flash, Fuel-It Stage 2 LPFP, EOS Port Injection Manifold, Custom 3" Exhaust
- OEM M5 Front Bumper, OEM M5 Front Fenders (Vents Deleted), OEM M5 Skirts, OEM M5 Mirrors, M-Tech Rep Rear Bumper
- Quad Projector Headlights, Custom Tail Lights, Rigid SR 6" Reverse Light, Full LED Interior/Exterior Lighting
ucsbwsr is offline
post #16 of 20 Old 3rd June 2016, 07:26 PM
horse86
horse86's Avatar
Originally Posted by TheShafro View Post
They look great! How did you "frost" parts?
good post. While its a bit of a PITA, I've removed my headlights without taking the bumper off. You have to pull the bumper away in certain spots/areas to get clearance but as long as you are careful you wont splinter the stock paint. I was 100% successful.
How do you know by looking at the e60 lamp if it can be pried apart with heat or has to be cut? Any tell tale signs?
- Justin
/// 2008 Space Grey M5 (SMG)
2009 Triumph Speed Triple 1050
2008 Range Rover FullFat
horse86 is offline
post #17 of 20 Old 3rd June 2016, 09:05 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
As I said, possible but not recommended. It takes about 90 seconds to remove the front bumper so it seems silly to make the process unnecessarily hard, not to mention possibly damaging the paint on the bumper or fenders but to each their own.
I have noticed no trends amongst the E6X lights I have opened. Personally I have successfully opened a pre-LCI halogen and LCI HID, I have also failed on a preLCI HID and LCI HID.
Sealants have some variation form the factory, even units from the same build-year, there may be no rhyme or reason for the differences. Some sealants can be softened/weakened depending on the climate the car lives in and the amount of exposure it gets, so that can play into it too.
The E6X headlights are commonly regarded as a cut-to-open headlight so my success with opening more than one is a little unique, chalk that up to variables out of my control and a bit of skill/technique. Even if the housing could potentially be opened in the right hands with the right tools, the process still needs to be well executed to be successful so it is really hard to predict with all the variables.
Evan
ucsbwsr is offline
post #18 of 20 Old 23rd February 2019, 02:42 AM
Wilbur06
Wilbur06's Avatar
Wilbur06 is offline
post #19 of 20 Old 23rd February 2019, 02:42 AM
Wilbur06
Wilbur06's Avatar
Wilbur06 is offline
post #20 of 20 Old 27th March 2019, 02:59 AM
garrick
Hey Evan do you still know how to chrome delete the headlight of the Tesla Model S?
Evan
garrick is offline
Custom LCI headlights georgefu E60 M5 and E61 M5 Touring Discussion 30 25th November 2015 08:37 AM
Looking for Custom Headlights Mod KEEP IT REAL E60 M5 and E61 M5 Touring Discussion 11 21st May 2015 08:41 PM
Custom Headlights - LED Angel Eyes & More Finesta101 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 1st February 2015 02:58 AM
Custom Pre-LCI Headlights Project douglas_ngo E60 M5 and E61 M5 Touring Discussion 40 25th March 2013 09:26 PM
Custom Headlights for 2000MY owners Nadir(Detroit) E39 M5 and E52 Z8 Discussion 6 5th October 2007 04:46 AM
