Smg jerking and bucking from faulty throttle actuators? - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 16 Old 9th July 2016, 12:02 PM Thread Starter
NeedaM5
Just about 80,000. I bought the car about 6 months ago and the dealer told me it had a clutch done recently but had no documentation and was kinda shady it turns out so I don't believe him.
NeedaM5 is offline
post #12 of 16 Old 9th July 2016, 12:15 PM
rt7085
rt7085's Avatar
rt7085 is offline
post #13 of 16 Old 9th July 2016, 02:17 PM
JGINWS
JGINWS's Avatar
I just picked my car back up yesterday and had almost everything changed out - prior to my clutch starting to fail - which basically only had half of the material on one side left - it smelled like burning clutch when I got on her with a lot of WOT this started on Saturday - I got a small amount of shutter on take off and stop this started on Sunday, did SMG reset - Monday M completely stalled out stopping at light and began slipping between 3000 and 5000 RPMS if I applied anything other than slow gradual throttle - I already decided that a new clutch was immediately needed Sunday. Did the SMG reset several times and it really didn't seem to help and had to knock the car out of car coming to a stop so I didn't stall - ordered all the parts below - did SMG reset several times but it didn't really seem to have an effect until I did it at about 80MPH down a long steep hill on one of the roads going home. I just did it several times and it madge a HUGE difference almost no shudder at take off - none at slowdown - shifting was good but if anything other than gradual throttle above 3000 RPM was applied the clutch slipped. Have more pictures but this is what the original clutch looked like - see below - I picked the car back up yesterday and have put 125 miles on her getting her back home - the SMG has never felt like this - smooth - easy shifts - I am amazed - I'm no expert by any means but I would be suspicious of the clutch - I bought my car with 59K the clutch started doing this at 94K - it sounds like what I was experiencing which I posted about in another thread https://www.m5board.com/vbulletin/e60...ming-stop.html
OEM Parts
1. Clutch fork lever
2. OEM Clutch Kit (clutch disk, pressure plate and throwout bearing)
3. 9 sprocket bolt
4. 1 rear crankshaft seal
5. 4 Torx bolts
6. 2 exhaust gasket rings
7. 4 header to exhaust nuts
8. 1 spring clip
9. 2 transmission mounts
10. 1 shaft seal
11. 1 universal flex disc "guibo"
12. driveshaft center support bearing
13. dual-mass flywheel
14. Throwout bearing guide tube
15. Slave Cylinder
Non OEM
1. ECS performance clutch fork pivot pin (Brass)
2. Vaico driveshaft center sleeve
JGINWS is offline
The Following User Says Thank You to JGINWS For This Useful Post:
NeedaM5 (11th July 2016)
post #14 of 16 Old 11th July 2016, 12:51 AM Thread Starter
NeedaM5
^^ thanks for the detailed reply. I was experiencing similar things to you. I don't see what else it could be. There are no codes and no check engine light so the clutch would make the most sense.
NeedaM5 is offline
post #15 of 16 Old 11th July 2016, 01:01 AM
JGINWS
JGINWS's Avatar
Yeah - it's pricey I just replaced my Throttle body actuators and idle control actuators as well less than 30 days ago - in my opinion the throttle body actuators would not do what you are experiencing. Plus if they were failing you would be getting reduced power and lots of faults.
The labor is pretty intensive and I would highly recommend changing everything out while they are in there. I can't tell you how much of an improvement it is - honestly, it's like a different car.
Hope you get your baby fixed soon Good Luck
JGINWS is offline
NeedaM5 (12th July 2016)
post #16 of 16 Old 14th July 2016, 06:19 AM
M5 Jed
M5 Jed's Avatar
The jerkiness and slamming into gears is due to a sticky clutch release bearing. Well known failure point on the smg. You need a new clutch kit.
M5 Jed
2000 Dinan S4 E39 M5 Touring Anthracite Metallic / Black Extended - The original and one and only...Unicorn!!!
2006 Dinan S2 M5 Silverstone II / Indianapolis Red - The Garage Queen
SOLD - 1993 M5 Schwarz / Black - The Ronin Car!
SOLD - 2001 Dinan S2 540iT M Sport Orient Blue / Sand Beige
SOLD -1995 Dinan 540i M Sport Cosmos Black / Black Leather - #20 of 200 pcs.
PARTED OUT - 2001 BMW M5 Anthracite Metallic / 2-tone Silverstone Extended (R.I.P)
PARTED OUT - 2001 BMW M5 Anthracite Metallic / Carmel Extended (R.I.P.)
SOLD - 1993 BMW Euro M5 3.8 Touring Diamond Schwarz Metallic / Alcantara Suede - Oh how I miss u.
SOLD - 1988 BMW US Spec M5 Schwarz / Natur w/ 77k miles - complete Euro conversion - The Museum Piece.
Viva La Wolfpack!
M5 Jed is offline
E60 For Sale: 2006 M5 64k CIC upgrade/LCI lights. New SMG clutch/Flywheel, Alternator/Volt Regulator, Throttle Actuators, Battery, MAF sensors, etc flyfishing Cars For Sale or Wanted 0 7th February 2016 10:10 PM
Throttle actuators again Bucky E60 M5 and E61 M5 Touring Discussion 0 14th October 2014 01:27 AM
E60 For Sale: throttle actuators Tho///a5 Parts / Other For Sale or Wanted 5 31st January 2014 09:33 AM
2007 B7 light bucking at close to neutral throttle. phillym5 ALPINABoard.com | BMW Alpina Discussion 14 19th April 2013 02:41 AM
E60 For Sale: M5/M6 Throttle actuators X2 gjs Parts / Other For Sale or Wanted 0 3rd December 2012 12:05 AM
