Exhaust manifold temp sensor. - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By jcolley
post #1 of 9 Old 20th April 2016, 03:07 AM Thread Starter
sunilshivaram
This is part no. 11 in the diagrams. My 2008 M5 doesn't have this part. It has a cap on it. Any idea why this was done ? Its a new car I bought from someone (and fails with Increased emission check engine). I am going through each part and figuring out whats missing and whats wrong.
sunilshivaram is offline
post #2 of 9 Old 20th April 2016, 03:14 AM
robertstrendell
robertstrendell's Avatar
robertstrendell is offline
post #3 of 9 Old 20th April 2016, 03:17 AM Thread Starter
sunilshivaram
post #4 of 9 Old 20th April 2016, 03:18 AM
robertstrendell
Don't think that's missing or your problem because mines is the same way 2006 m6 capped off as well
post #5 of 9 Old 20th April 2016, 04:44 AM
jcolley
jcolley's Avatar
DME software change in very early versions changed to a modeled cat temperature and abandoned the EGT sensors.
jcolley is offline
post #6 of 9 Old 20th April 2016, 05:02 AM Thread Starter
sunilshivaram
I am looking at a picture of the exhaust manifold that was taken out of a 2007 M5. It has the temperature sensor, along with the O2 pre-cat and post-cat sensors. Mine is a 2008, and OBD2 scan (with Torque Pro and BT connection to OBD2 scanner) shows my Cat temperatures rise in increments of 15C every 5 seconds when I graph it while driving the car from a cold start. If the temperature of the cats can be a predictable behavior most of the times, it makes sense to model them into the software and get rid of the extra sensor.
I think what you meant was: the sensors were in the earlier (2006-2007) models and were removed in 2008 on wards (?).
post #7 of 9 Old 20th April 2016, 05:27 AM
jcolley
jcolley's Avatar
The software was all that changed on the 06-07 cars, the sensors were left in place and not monitored. On vehicles produced after that, they stopped installing them. Unless your DME version is older than 140E, they aren't being actively monitored.
jcolley is offline
post #8 of 9 Old 20th April 2016, 08:07 AM
dr_dirtg
dr_dirtg's Avatar
Does any one know why they changed the software to ignore the sensors?
What problems were people having before the software change to ignore the sensors?
dr_dirtg is offline
post #9 of 9 Old 20th April 2016, 01:29 PM Thread Starter
sunilshivaram
I think the catalytic converter temperature can be easily derived from the engine speed(fuel burned, and outside air temperature etc.), and would not have lot of variations, and predictable via computer software models. Its one less part I think.
Manifold Pressure Sensor rosakirk12 E39 M5 and E52 Z8 Discussion 3 2nd February 2016 03:40 AM
Oil temp/level sensor failure - possible to fix the sensor? JoeFromPA E39 M5 and E52 Z8 Discussion 3 1st April 2013 03:36 AM
exhaust temp sensor shaunmal E39 M5 and E52 Z8 Discussion 5 16th October 2012 04:49 PM
Replacement/removal of exhaust temp sensor (EGT) Johannesp E39 M5 and E52 Z8 Discussion 1 21st June 2006 07:56 PM
TEMP SWITCH AND TEMP SENSOR imolaman E39 M5 and E52 Z8 Discussion 3 10th June 2006 11:38 PM
