Tires rubbing bad need a solution ASAP - Page 2 - BMW M5 Forum and M6 Forums
 3Likes
post #11 of 33 Old 13th April 2016, 01:57 AM Thread Starter
desakatao
here are some pictures tell me what you think...
here are the pics...
ID:	691682   Click image for larger version
ID:	691690   Click image for larger version
ID:	691698   Click image for larger version
ID:	691706   Click image for larger version
ID:	691722   Click image for larger version
desakatao is offline
post #12 of 33 Old 13th April 2016, 02:01 AM Thread Starter
desakatao
This is a more recent pic i just added the tubi exhaust..
ID:	691738   Click image for larger version
post #13 of 33 Old 13th April 2016, 01:52 PM
AmstaffM5
Assume it is only rubbing in the back?
Verify the offset of the wheel and determine if taking off the spacers will address the problem. If so - bye bye spacers....
AmstaffM5 is offline
post #14 of 33 Old 13th April 2016, 04:32 PM
Dacan23
Dacan23's Avatar
There should be markings on the inside of the wheel to tell if they are BMW or replicas, also the offest of them is marked there too. I have an aftermarket set where I run spacers in the front but not the rear.
Originally Posted by desakatao View Post
i have no idea when i bought the car those were the wheels it had on. if they only come in 20's then i guess its a replica set then. i got the wheels power coated and they look amazing but is just the rubbing thats bothering me. but i will removed the spacers and see if that helps.
2008 M5 6 Speed - Black on Black
RPI GTS Exhaust (Sec 1+2+3), Eurocharged, TMS 12.5mm Spacers, AFE Pro Dry S Drop in Filters, RPI Like Air Scoops, Black Side Vents, Smoke Side Markers, Color Matched Bumper Reflectors, Black Kidneys, Black Aluminum Pedals, Stock Wheels (Until Spring) & M6 Replicas for Winters.
2017 X5 35d MSport - Loaded no more 3rd row
2013 135i Cabrio MSport & DCT
1995 540 6 Speed
2017 i3 REX
Past Cars
2012 X5 35d Sport - Loaded
2000 Z3 2.8 Roadster M Sport 5 Speed
2011 X3 2.8i M Sport - Alpine White on Black
1995 530i Auto
1986 635CSi 5 Speed
1998 323is 5 Speed
1992 535 5 Speed
Dacan23 is offline
post #15 of 33 Old 13th April 2016, 04:56 PM
kplay
kplay is offline
post #16 of 33 Old 13th April 2016, 05:33 PM
wojcikd
I suggest getting your alignment done first, if the rubbing continues, delete the spacers - assuming the tires rub the fender and not the inner spring.
wojcikd is offline
post #17 of 33 Old 13th April 2016, 09:49 PM Thread Starter
desakatao
I already did the alignment when i first mounted the wheels after getting them painted @wojcikd . i guess i will removed the rear spacers this weekend and see if that helps..
post #18 of 33 Old 14th April 2016, 04:10 AM
BadSeed
When you remove the spacers, stick your head inside & look at where the rear bumper connects to the fender. That's where mine rubbed the most as you can see from these pics. Up to you to start cutting & grinding or just remove spacers.
My setup:
Eibach springs > alignment set for even tire wear > PZERO 295/30/20 > 20x11 offset 25 > rim is roughly 1mm - 2mm from the string
ID:	692026   Click image for larger version
Name:	Fender liner.jpg
ID:	692034   Click image for larger version
ID:	692042   Click image for larger version
BadSeed is offline
post #19 of 33 Old 14th April 2016, 01:56 PM
rt7085
rt7085's Avatar
rt7085 is offline
post #20 of 33 Old 14th April 2016, 04:29 PM Thread Starter
desakatao
Thanks @ IGNANT and rt7085. i will get that done on Saturday and see where is rubbing and go from there..
Are my tires rubbing? bdsmitty88 E39 M5 and E52 Z8 Discussion 26 1st May 2012 03:36 AM
HELP!!! Rear tires are rubbing since new spacers Msizzle E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 26 21st August 2010 02:53 AM
Rubbing with 20" tires...please help ideliver E60 M5 and E61 M5 Touring Discussion 6 26th April 2009 10:41 PM
Rear Tires Rubbing tmlesko E39 M5 and E52 Z8 Discussion 2 25th March 2004 05:05 PM
Any rubbing with 285/30-19 rear tires? AD E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 3 7th February 2002 09:20 PM
