Smg problem - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 15 Old 9th March 2016, 05:40 AM Thread Starter
Mikeshin
Smg problem
Hello evryone I am new to this forum. I have a 2006 m5 85k miles smg. Ever since I bought it it has been having smg issues. 2nd gear is the issue for me because it throws a red cog if I wot going into 2nd or downshifting from 3rd to 2nd. My Indy is telling me to replace whole transmission with a used one. My fault codes are 4f40 and 4f85. I know 4f40 means smg pump undershooting but I don't think my smg pump is bad bc I can hear it prime when I open door. I've had the car for 2 months and all I've been getting are headaches. I talked to Troy and was going to go to his shop but have done so yet. Any help would be appreciated.
Mikeshin is offline
post #2 of 15 Old 9th March 2016, 08:19 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Hasan Shaikh is offline
post #3 of 15 Old 9th March 2016, 06:22 PM
Racer14sl
Racer14sl's Avatar
How long is normal? I can hear mine prime for about 3-4 seconds when I open my driver door before starting the car and I hear it periodically while at idle. Generally only for about 1-2 seconds when warmed up. No issues with my SMG at the moment...
Racer14sl is offline
post #4 of 15 Old 9th March 2016, 06:36 PM
Garfunkgrin
Garfunkgrin's Avatar
There are tests that can be performed on the pump and the accumulator to see if your hydraulics are building and holding pressure correctly. What the best value for your mechanical ability is depends on how much time you're willing to put into troubleshooting.
If you can find someone or are willing to load up the software yourself you should be able to isolate the component that is giving you trouble fairly easily, however if you need to pay someone multiple times to do the diagnosis and isolation trial and error you may be just as well to pick up a good core and have it swapped all at once.
Garfunkgrin is offline
The Following User Says Thank You to Garfunkgrin For This Useful Post:
Aberdeen Diamond Detailing (5th August 2016)
post #5 of 15 Old 9th March 2016, 07:18 PM Thread Starter
Mikeshin
Re
Mine primes for 3-4 secs. I don't think it's pump bc all the other gears work fine at wot. Any suggestions guys?
Mikeshin is offline
post #6 of 15 Old 9th March 2016, 07:23 PM Thread Starter
Mikeshin
Troy just texted back today. I'm going to make my way up to Michigan since I live in Columbus Ohio. It's about 5 hours but I feel every shop I talked to are clueless on this car. Taking it to him seems like it would be the best for me. I was planing on going today but he has another project until tomorrow. Hopefully I'm free on Sunday to make my way up there.
Mikeshin is offline
post #7 of 15 Old 10th March 2016, 06:47 AM
Hasan Shaikh
Upto 8 or 10 seconds of priming is fine. 3 to 4 secs is very good.
post #8 of 15 Old 10th March 2016, 06:51 AM
Hasan Shaikh
If your hydraulic system is fine. I would guess that you have an electrical issue of some kind.
I'm sure Troy would be able to sort it out.
post #9 of 15 Old 6th April 2016, 02:03 PM
VLStu
VLStu's Avatar
Hi - I have a similar issue (red cog every 2-3 weeks) when shifting in low gears (albeit not at WOT). Indy shop replaced accumulator, indicating it was not holding pressure. 2 weeks later - same issue came back. They are now indicating hydraulic unit not pressurizing properly.
As I'm sure you all have dealt with - BMW price for this hydraulic unit (pn 21542282998) is ~$5700. Fast Attack Motorsports (Fast Attack Motorsports) has new OEM units for $3150, and rebuilt units with new pumps for $2150.
I have only seen one other post (positive) for a member using Fast Attack. Does anyone else have experience with them?
VLStu is offline
post #10 of 15 Old 6th April 2016, 05:48 PM
Garfunkgrin
I believe that fast attack is JColley's business. He is a well-known member here with lots of knowledge, particularly about the SMG. I was having troubles with my SMG unit after it was serviced by the dealer (prior to my ownership) and leaking. JColley helped me narrow down common leak spots and I was able to fix my SMG hydraulics for free.
Hopefully you get your issue sorted and back to enjoying your car asap. ONE piece of advice, in case you aren't aware - while your car has this pressure issue DO NOT park it in gear. Park it in neutral with the parking brake engaged, because if your pump decides to take a dirt-nap you can't get the car out of gear for towing and could easily destroy your high-pressure VANOS system if incorrectly moved in gear.
VLStu (6th April 2016)
smg Problem alenas E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 3rd April 2014 04:09 PM
Need help... SMG problem........ Erik E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 25 24th March 2014 05:20 PM
Smg problem! e60m51030 E60 M5 and E61 M5 Touring Discussion 6 20th October 2012 11:20 PM
Do I have an SMG problem? benfmd E60 M5 and E61 M5 Touring Discussion 12 3rd November 2007 05:08 AM
SMG problem.... PitziM5 E60 M5 and E61 M5 Touring Discussion 8 24th June 2007 10:04 PM
