P0128 info and help please - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 11 Old 4th February 2016, 03:23 PM Thread Starter
Dave Spalding
Hey folks. A few days go my engine management light came on. No big deal read the code and cleared it. Today the light came back on, same code (P0128).
On both occasions the car had been running for less than 5 mins and had covered less than a mile. Both times from cold start up.
Any ideas on causes? Surely the car wouldn't expect to be warmed up by that point anyway?
Dave Spalding is offline
post #2 of 11 Old 4th February 2016, 03:50 PM
jcolley
jcolley's Avatar
jcolley is offline
post #3 of 11 Old 4th February 2016, 04:02 PM Thread Starter
Dave Spalding
Brilliant mate thanks. So test the switch first then if that's fine replace the thermostat?
post #4 of 11 Old 4th February 2016, 04:02 PM Thread Starter
Dave Spalding
post #5 of 11 Old 5th February 2016, 03:52 AM
rt7085
rt7085's Avatar
rt7085 is offline
post #6 of 11 Old 5th February 2016, 11:33 AM Thread Starter
Dave Spalding
Ok thanks. Replaced the one on my E39 M5. Was going to do this one but the garage a got the car from are doing it under warranty so saves me the hassle.
post #7 of 11 Old 19th July 2017, 10:37 AM
EddieM5CA
EddieM5CA's Avatar
Hi everyone. Got p0128 code.
The thermostat was replaced about 2 months ago and water temperature sensor about 4 days ago along with Auxiliary fan switch just in case. (OEM sensors from trusted BMW shop)
Code came back again after cold start today.
Is there anything else could cause this code?
EddieM5CA is offline
post #8 of 11 Old 25th July 2017, 01:51 AM
rt7085
rt7085's Avatar
Yes, a thermostat that was incorrectly mounted and/or a pre-damaged thermostat housing. The thermostat slides up and down in the housing around 73C and if it was scored or damaged it may not slide properly preventing closure. As a result the coolant temperature is too low. This on its turn can induce the engine to run rich which over a long time will destroy your cats (if you have any).
rt7085 is offline
post #9 of 11 Old 25th July 2017, 05:54 AM
EddieM5CA
EddieM5CA's Avatar
Thank you for your time and help. I'm going to check on thermostat and will replace if needed.
post #10 of 11 Old 9th February 2018, 04:52 AM
javs4
javs4's Avatar
I got the code recently. I'm wondering if the winter temperatures cause this issue. It's been in the 20s and 30s during the day, colder overnight. Any thoughts out there? Should I wait til the spring to see if the code comes back when it's warmer.
javs4 is offline
Increased Emissions, P0128 again Erik G E60 M5 and E61 M5 Touring Discussion 3 16th October 2015 12:35 PM
P0128 bhemi E39 M5 and E52 Z8 Discussion 0 20th September 2015 11:07 PM
P0128 fixed, maybe Greg T E60 M5 and E61 M5 Touring Discussion 3 29th October 2014 05:08 AM
P0128 - Time for a new Thermostat? BoostedE21 E39 M5 and E52 Z8 Discussion 4 18th June 2011 04:17 AM
P0128: Anyone gotten this code before? dc944 E60 M5 and E61 M5 Touring Discussion 0 14th August 2010 10:33 PM
