Metal flakes in oil. Horrible or not so bad? - BMW M5 Forum and M6 Forums
 2Likes
LinkBack Thread Tools Rate Thread
Old 31st January 2016, 11:35 PM Thread Starter
Bonzinmotion
My 2006 m5 e60 with 70k miles started making a knocking noise from passenger side lifter closest to windshield. Reduced power. Garaged and shut down. Independent Bmw mechanic gave a quick look. Suggested engine replacement, but did not pull anything open. Metal flakes of copper/brass color in oil. Options seem like crankshaft wore out,or rod bearings. I am having the oil pan pulled to inspect further. It seems that I mostly read to just replace the engine. I'm hoping someone hear might give their experience that it is not complete engine failure (potentially) if the crankshaft, rod bearings, etc can be replaced and the system flushed. I understand that these are general problems and no specific answers are rock solid without more info, but I'm looking for a ray of hope here. I have ordered a test kit from blackstone also
Bonzinmotion is offline
Old 1st February 2016, 12:50 AM
cleoent
cleoent's Avatar
I'm fairly convinced that the answers in this thread wont be what you're hoping for.
-Leo
2006 M5 (SOLD)
2016 Camaro SS - MURICA!!!!
cleoent is offline
Old 1st February 2016, 01:54 AM
jcolley
jcolley's Avatar
I would agree, that doesn't look good.
Cut open the filter and see how much is trapped in it.
Concur pulling the oil pan as exploratory, but I have a feeling it won't be going back on.
Where are you located?
jcolley is online now
Old 1st February 2016, 02:46 AM
de Witt
de Witt's Avatar
Did the knocking frequency have any correlation to rpms? Ie increase rpms, more frequent knocking.
de Witt is offline
Old 1st February 2016, 04:18 AM
Ident
Ident's Avatar
Ident is offline
Old 1st February 2016, 05:32 AM Thread Starter
Bonzinmotion
Actually it only does it at idle. When I rev, it stops. The tapping is the same speed, but also intermittent even when idling.
I did get the camshaft position error. Over retarded in two banks. I forgot to add that earlier
Old 1st February 2016, 05:35 AM Thread Starter
Bonzinmotion
I'm in Oregon. When budget allows, if I need a new engine, I've spoken with Troy Jeup and he will hook me up. I'm just hoping for something less. I have an independent Bmw mechanic coming by to look at it also.
Old 1st February 2016, 06:21 AM Thread Starter
Bonzinmotion
Old 1st February 2016, 03:10 PM
Ident
Ident's Avatar
Ident is offline
Old 1st February 2016, 03:27 PM
jcolley
jcolley's Avatar
Agreed. That's no bueno.
On a side note, not sure if you did it intentionally, but if you did...kudos. You're a calmer man than I. Your video is in the "comedy" category on YouTube.
Rate This Thread
Changed oil, found some metal flakes in filter torque E60 M5 and E61 M5 Touring Discussion 14 18th February 2016 04:39 AM
Oh dear.. metal flakes in oil filter housing paulclaude E60 M5 and E61 M5 Touring Discussion 74 25th June 2015 01:44 PM
Metal flakes in oil filter Hg1245 E60 M5 and E61 M5 Touring Discussion 18 7th May 2015 06:47 AM
Oil Change Results: 2 Flakes in filter cover. The Engineer E60 M5 and E61 M5 Touring Discussion 10 23rd February 2015 03:08 AM
Feedback on metal flakes in oil filter.... Normal? mottati E39 M5 and E52 Z8 Discussion 30 16th July 2006 11:54 PM
