Metal flakes in oil. Horrible or not so bad? - Page 2 - BMW M5 Forum and M6 Forums
 2Likes
post #11 of 24 Old 1st February 2016, 05:57 PM
TJM5
TJM5's Avatar
No Hope for you drop the oil pan and replace the bearing
you'll need this
BMW E60 M5 Rod Bearings DIY
and this
BMW S85 - Lang Racing Development
since we are on this topic has anyone used the WPC bearings yet I'm going to use my M5 as a track day car this year and at the end of the season I plan on replacing the rod bearings with these mentioned above.. anyone running them?
'17 Raptor, Lightening Blue
'06 M5, Alpine White
'90 325i, Turbo
TJM5 is offline
post #12 of 24 Old 1st February 2016, 09:14 PM
warrenatc
warrenatc's Avatar
I had same thing. A botched vanos line replacement from Bimmer Motor Werks (Dec 2013) destroyed my engine. Did they same thing, low oil pressure spun the bearings and put all the metal shavings in the vanos banks and throughout engine. BMW recommended replacement. You might be able to get BMW to keep filtering the oil but it only last's 100-miles or so before the Vanos system (solenoids) gets jammed as tight clearances. I called Troy. Will cost you about $8-10K for motor, $2K core charge comes back to you. Look to around $4-$6K for install. He sent me a great motor with new bearings, vanos lines etc. Been running smooth as silk. Good luck.
2006 E60 M5 Indy-red, Sepang Bronze, 35% tint, RPI Intake system, SS Sport (Race) Mufflers, SS X-Pipe, Hardwired V1
1972 Chevrolet El-Camino 350
warrenatc is offline
The Following User Says Thank You to warrenatc For This Useful Post:
Bonzinmotion (2nd February 2016)
post #13 of 24 Old 1st February 2016, 09:21 PM
Bucky
Bucky is offline
post #14 of 24 Old 1st February 2016, 10:07 PM
jcolley
jcolley's Avatar
Yep. Put them in at 68K, pulled them 14k later. Religious about warm-up and a taking care of it. When I pulled them they looked like a set of 30-40k bearings. I don't attribute it to the WPC treatment as much as the 702/703 bearings they start with. @B767capt had almost identical experience with much lower mileage. He posted pics here somewhere.
jcolley is offline
post #15 of 24 Old 2nd February 2016, 01:00 AM
B767capt
B767capt's Avatar
B767capt is offline
post #16 of 24 Old 2nd February 2016, 01:44 AM Thread Starter
Bonzinmotion
I will eventually get the engine from Troy but hoping to run it this summer with a bearing change and thorough flushing
Bonzinmotion is offline
post #17 of 24 Old 2nd February 2016, 04:46 PM
auditobmw
Man talk about tough luck!! I'm sorry for your loss. I'm sure troy will have you back on your feet before summer! I pray I never have to hear that noise unless im still under warranty then im all for it ...
2000 M5 - new toy
ESS Supercharger
CNS Clutch
3.45dinan
2007 M5 Saphire Black 6MT - sold
RPi scoops&blockoff plates
Removed charcoal filters
Evolve tune
Dinan sect 1,2&3 race exhaust
2010 Audi S4 6MT - sold
Stage 2 APR software
AWE resonated catback exhaust
o34 Test pipes
Stage 2 clutch
Upgraded supercharger pulley
1/4 mile: 11.91 , 0-60: 3.9sec
auditobmw is offline
post #18 of 24 Old 2nd February 2016, 06:52 PM
ACG
ACG's Avatar
Man that sounds just like my engine in the VR4 did just before the engine blew.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #19 of 24 Old 2nd February 2016, 10:50 PM
Jetpilot718
Jetpilot718's Avatar
From the video, the ticking sounds very very frequent and hollow, sounds high up. Again, hard to diagnose from a video, but almost sounds to me like a valve spring has "shuffled itself off the mortal coil", pun very intended. Interested to see the outcome... but my gut is telling me to start with the head.
Jetpilot718 is offline
post #20 of 24 Old 3rd February 2016, 08:26 PM
Dacan23
Dacan23's Avatar
I'm not expert, but this was my first thought too when I saw the vid, wasnt going to chime in as the first, but I agree the sound seemed like it was on the top end vs bottom.
2008 M5 6 Speed - Black on Black
RPI GTS Exhaust (Sec 1+2+3), Eurocharged, TMS 12.5mm Spacers, AFE Pro Dry S Drop in Filters, RPI Like Air Scoops, Black Side Vents, Smoke Side Markers, Color Matched Bumper Reflectors, Black Kidneys, Black Aluminum Pedals, Stock Wheels (Until Spring) & M6 Replicas for Winters.
2017 X5 35d MSport - Loaded no more 3rd row
2013 135i Cabrio MSport & DCT
1995 540 6 Speed
2017 i3 REX
Past Cars
2012 X5 35d Sport - Loaded
2000 Z3 2.8 Roadster M Sport 5 Speed
2011 X3 2.8i M Sport - Alpine White on Black
1995 530i Auto
1986 635CSi 5 Speed
1998 323is 5 Speed
1992 535 5 Speed
Dacan23 is offline
Changed oil, found some metal flakes in filter torque E60 M5 and E61 M5 Touring Discussion 14 18th February 2016 04:39 AM
Oh dear.. metal flakes in oil filter housing paulclaude E60 M5 and E61 M5 Touring Discussion 74 25th June 2015 01:44 PM
Metal flakes in oil filter Hg1245 E60 M5 and E61 M5 Touring Discussion 18 7th May 2015 06:47 AM
Oil Change Results: 2 Flakes in filter cover. The Engineer E60 M5 and E61 M5 Touring Discussion 10 23rd February 2015 03:08 AM
Feedback on metal flakes in oil filter.... Normal? mottati E39 M5 and E52 Z8 Discussion 30 16th July 2006 11:54 PM
