Race: G-power SK2 Mono Supercharge vs Tuned M6 - Page 3 - BMW M5 Forum and M6 Forums
 5Likes
post #21 of 27 Old 26th January 2016, 07:35 PM
tjav8b
I may be wrong but I don't think the Vanos has anything to do with WOT peak horsepower.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #22 of 27 Old 26th January 2016, 09:07 PM Thread Starter
maxspeed
some dyno they give you high WHP and some less even if they are same brand
also the dyno is so difficult to measure Supercharged as in 5th gear the blower not spins like its in the road
max Boost in dyno i got 6.9 PSI while in the road i am getting 7.5 in the same gears
with regards to ESS you can check their website ( i have attached for you the photo for your reference )
you also cannot compare middle east weather with US
the car feel in the road totally different then the dyno numbers
Originally Posted by ACG View Post
Not sure why you get such a low output as I managed 570 on a MAHA dyno and that reads much lower than a dynojet. Not only that but the majority of the members on here an pushing 600rwhp with the VT2 so your numbers do not add up.
maxspeed is offline
post #23 of 27 Old 26th January 2016, 09:28 PM Thread Starter
maxspeed
this video could show you how strong they are in europe
https://www.youtube.com/watch?v=1FCWc7C1tHE
Originally Posted by RedRum5 View Post
Interesting video against a stock S85. Do you have any vs. S85s with mods, particularly other S/C cars?
Also just curious, is G-Power's name really that strong in Europe? I don't see why anyone would pay this kind of premium for the similar output.
maxspeed is offline
post #24 of 27 Old 26th January 2016, 10:04 PM
ACG
ACG's Avatar
Per AJ, the numbers on the website are just from bolting on the SC kit and nothing else. You already noted high flow cats and pulley etc..
And only pushing 6psi of boost.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #25 of 27 Old 26th January 2016, 10:09 PM
tjav8b
Weather is not a factor as your numbers should be SAE corrected.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #26 of 27 Old 18th February 2016, 08:27 PM
tjav8b
our company sell both Supercharge, ESS & G-power and both are great products..
with regards to the Vanos oil pressure for sure its big effect for performance and even if you did't assume its effecting or not .. in Vt2 ESS Achived 561WHP in dynojet and the result in the website.. so for sure they are not same power at the end of the day you get what you pay for..
i have video for My car before the supercharge (NA) it was having BMC Airfilter , Decat and ESS Tune Vs ESS m5 + Methanol + Cat-less Headers
please find below video and compare both length
i have tested also full bolt on m5 with ESS Tune & Airscoop , filters, Headers VS m5 ESS Vt2 with Methanol +Cat-less Headers ( same car )
https://www.youtube.com/watch?v=HQCBtCtyT20
https://www.youtube.com/watch?v=tzgAFIQ502o
https://www.youtube.com/watch?v=B7MVWAqXVg8
i can assure you in G-power 2rd gear is so aggressive pushing and you never had good traction ..
I missed this post. I would like to see more data on the ESS VT-2 car with methanol. Before and after methanol dynos? Type of system? Since there has not been a successful S85 methanol application and only a couple of successful S65 applications to date, you probably lost power.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #27 of 27 Old 20th February 2016, 12:03 AM Thread Starter
maxspeed
its aquamist methanol system.. very noticeable with the methanol. the rpm faster while the acceleration
Gintani they have devlop stage 2 supercharge with methanol system and as per what i know they have gain good numbers..
i did't see car losing power with methanol unless its more then the required
specially with our bad fuel 91 AKI it will boost the octane.
maxspeed is offline
G-power First Mono SK2 Supercharge maxspeed E60 M5 and E61 M5 Touring Discussion 37 23rd January 2016 04:53 PM
E60 For Sale: G-Power BMW M5/M6 V10 SK2 Supercharger System Technik Parts / Other For Sale or Wanted 13 25th May 2010 04:16 PM
E63 M6 For Sale: G-Power SK2 M5/M6 V10 "Bi-Kompressor" Supercharger Kit Technik Parts / Other For Sale or Wanted 14 6th May 2010 08:10 PM
Tuned McLaren SLR vs tuned ZR1 vs tuned GTR GEORGEV6V24 GTBoard.com: General Sportscars 0 29th June 2009 03:57 PM
Supercharge the M5 with G-Power lasseoe E39 M5 and E52 Z8 Discussion 5 23rd May 2003 08:25 PM
