New e60 M5 owner (any tips) - Page 2 - BMW M5 Forum and M6 Forums
 13Likes
post #11 of 34 Old 12th December 2015, 05:55 AM Thread Starter
Vheme78
Now , I kind of have a newbie question..when I drive the car in auto it seems like a long delay to switch gears..is this normal? Seems slow..unless i punch it.
Vheme78 is offline
post #12 of 34 Old 12th December 2015, 01:03 PM
MarkieM5
MarkieM5's Avatar
Yes. In D mode it's almost painful waiting for it to shift. I only use the auto or D mode in bumper to bumper traffic where it's not noticeable. I think most guys are driving the SMG in manual mode. The car is really built to be manually shifted and it really comes alive at high RPM's with your foot in the gas.
Sent from AutoGuide.com Free App
MarkieM5 is offline
post #13 of 34 Old 12th December 2015, 04:27 PM
Lay3r3
Lay3r3's Avatar
Pay attention to your shift settings (button below the shifter) as it applies in D too. 1 is slowest and 5 or 6 (only available without traction control) is the fastest. The problem with D is that for faster shifts you need to be on D5 or D6 but then the shifts happen at a much higher rpm. There doesn't seem to be much balance for cruising normally with faster shifts. Remember too it's going to feel exaggerated because your pulling power from the wheels while the clutch engages so if you're even sightly accelerating it is very noticeable making shifts feel like an eternity.
Personally I don't use D. It's a good crutch for someone that doesn't know how to drive a manual though. (I.e. My wife!)
Lay3r3 is offline
post #14 of 34 Old 15th December 2015, 05:04 AM
thefleshrocket
thefleshrocket's Avatar
Originally Posted by RPIpower View Post
Welcome! As mentioned by another member, make sure your car is FULLY warmed up before you start driving.
This seems... excessive. Surely you don't mean that people should let their M5s idle for 10-15 minutes before driving them?!
I take a minute or two to get situated after firing up my M5, and then I drive gently (very light throttle and shift at under 3000rpm) until the oil temp is close to the 210 mark and the tach redline is all the way up. Then I drive it as I see fit.
So far I only have about a thousand miles on my M5 since getting it home and doing its first oil change, but the oil level indicator still shows at the full mark. I assume it'll drop somewhat before I get to the 5K mile oil change interval, but probably not enough to need the spare quart in the trunk. Of course, that might not be indicative of the level of consumption of other S85s.
--'08 M5 - 38K miles, 6-speed, Interlagos Blue, muffler delete, RPI scoops, charcoal delete
--'04 Mustang Cobra, bolt-ons, ~460rwhp (blower upgrade and 600rwhp coming soon)
--'08 Buell 1125R, '14 Yamaha Vmax, '05 Triumph Speed Triple, '03 Suzuki DRZ-400E
thefleshrocket is offline
post #15 of 34 Old 15th December 2015, 05:52 AM
ykjones
ykjones's Avatar
Welcome and congrats on your new beast. I definitely echo the comments mentioned previously. Stay on top on all of your maintenance. Find a trusted INDY shop. Every few oil changes, I would suggest getting a Blackstone report done on your oil. It's like a blood test for your engine. It's not the tell all on everything but can be a very good indicator on the health of your engine. Take your time to get to you know your beast. It's a powerful, powerful animal and can get you in a lot of trouble real fast in terms of the law or an accident. Try to get enrolled in some HPDE driving events at a track or the 2 day BMW ///M school.
2013 F10 M5 Singapore Gray: VF Engineering HEX Stage 1, RPI GTM Black Edition exhaust, KW HAS, Dinan Sway Bars, IND Black Chrome, Sprint booster, Matt Schnell competition spacers, ESS stainless steel brake lines, EBC Red stuff ceramic pads, M Performance carbon fiber rear spoiler, RKP front lip spoiler, BMC air filters, charcoal filter delete, sprint booster, V1 w/Blendmount, BIM coding all options, Pedaul Haus pedals
Gone but never forgotten:
Dinan/RPi E60 M5. Silver Gray
ykjones is offline
post #16 of 34 Old 15th December 2015, 06:33 AM
ACG
ACG's Avatar
My oil indicator would start to drop once I got to around 1300 miles, I would get around 2400 miles before it needed a quart added.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #17 of 34 Old 15th December 2015, 04:39 PM
Lay3r3
Lay3r3's Avatar
I do just what you described on warm up. Just don't push her till she's warm. As for oil, every car is different... I don't add any oil between 6,000 mile or so oil changes.
Lay3r3 is offline
post #18 of 34 Old 16th December 2015, 03:44 AM Thread Starter
Vheme78
Thanks guys..and lately I've notice that I have to reset my clock and date almost every time I get in the car..can someone help or send a link to this thread..
Vheme78 is offline
post #19 of 34 Old 16th December 2015, 01:11 PM
rt7085
rt7085's Avatar
First indications of a weak battery or a failing regulator. Observe batter voltage...... Make sure it charges when runs (~14V) and is just above 12V when sitting. Make sure it does not dip excessivly.
rt7085 is offline
post #20 of 34 Old 16th December 2015, 01:48 PM Thread Starter
Vheme78
Vheme78 is offline
E60 For Sale: E60 M5 Eisenmann Race (oval tips) trade for Sport version(oval tips) michael33 Exhaust Discussion, For Sale, or Wanted 12 27th February 2014 04:08 AM
E60 For Sale: E60 M5 Eisenmann Race (oval tips) trade for Sport version(oval tips) michael33 Cars For Sale or Wanted 0 9th January 2014 03:48 PM
Any tips from a 430 Scuderia Owner? fumando GTBoard.com: General Sportscars 0 20th January 2011 01:18 AM
Any Tips for a New Owner? matty747 E39 M5 and E52 Z8 Discussion 31 11th April 2008 05:59 PM
Tips to a new M5 owner (soon) ??? Corleone E39 M5 and E52 Z8 Discussion 11 15th December 2004 03:26 PM
