06 M5 pre to LCI.... - Page 8 - BMW M5 Forum and M6 Forums
 6Likes
post #71 of 77 Old 29th August 2016, 07:44 PM
Triniboy
Is your car is PRE-LCI Halogen?
Aside from that, try this
Before you swap in the LM2,
Access your Light Control Module(The one the car originally came with, and look at PIN 25 and PIN 40 What color is it?
Then on the PRE-LCI connectors for both sides, Look at PIN 4 . Is it the wire the same color PIN 25 and PIN 40 from the LCM?
If they are the same color, this means you just have to ignore the color code, and use the Circuit diagram. That is what I did for mines, I didn't too much rely on the color code because I heard on a certain release of the pdf, the color codes were incorrect.
Triniboy is offline
post #72 of 77 Old 30th August 2016, 03:34 AM
silvio2001
silvio2001's Avatar
On the Lcm plug I have pin 25 gray/green and pin 40 gray/blue only.
I have gray/green again on pins 42 and 54 if that helps.
On the pre Lci connector for driver side I have gray/green on pin 4 and no blue/gray at all as you can see in the pic.
On the right side on pre Lci connector I have gray/blue on pin 4 as you can see from the pic and no gray/green anywhere else. Also the small plugs next to pre Lci main connectors the colors don't match on either sides. 06 M5 pre to LCI....-imageuploadedbyag-free1472520706.257414.jpg06 M5 pre to LCI....-imageuploadedbyag-free1472520746.627220.jpg06 M5 pre to LCI....-imageuploadedbyag-free1472520766.607032.jpg06 M5 pre to LCI....-imageuploadedbyag-free1472520777.756245.jpg06 M5 pre to LCI....-imageuploadedbyag-free1472520789.333153.jpg06 M5 pre to LCI....-imageuploadedbyag-free1472520803.269902.jpg06 M5 pre to LCI....-imageuploadedbyag-free1472520813.703305.jpg
I've included pics of the pre Lci I took off the car and the Lci I'm planning to use for your information if it helps.
Is there anyway you can help me from here onward?
Thanks,
Sent from AutoGuide.com Free App
silvio2001 is offline
post #73 of 77 Old 30th August 2016, 04:23 AM
Triniboy
Looks like your using the old pdf with the retrofit instructions.
I can't PM,
But this should be the diagram you need.
Triniboy is offline
post #74 of 77 Old 30th August 2016, 05:47 AM
Triniboy
Triniboy is offline
post #75 of 77 Old 1st September 2016, 04:26 AM
old city bimmer
old city bimmer's Avatar
old city bimmer is offline
post #76 of 77 Old 1st February 2018, 07:29 AM
KingKashi
KingKashi is offline
post #77 of 77 Old 9th February 2018, 03:55 AM
stel_i79
stel_i79 is offline
E60 Headlight Retrofit PRE-LCI - LCI Niner49 E60 M5 and E61 M5 Touring Discussion 6 11th August 2015 08:27 AM
E60 M5 Front Bumper Difference pre-LCI vs LCI Johnny Tweak E60 M5 and E61 M5 Touring Discussion 4 26th April 2014 08:54 PM
E60 For Sale: SELLING e60 LCI tail lights US Version red blinker (WITH RETROFIT KIT -> PLUGS INTO PRE LCI 03-07) garom5 Parts / Other For Sale or Wanted 3 1st February 2013 11:36 PM
DIY: Make a bracket to fit your LCI iDrive controller in your pre-LCI Console pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 16th September 2012 11:05 PM
Ventilated / Heated Seat Buttons on LCI and Pre LCI Cars francom82 E60 M5 and E61 M5 Touring Discussion 6 22nd March 2010 02:22 AM
