06 M5 pre to LCI.... - Page 3 - BMW M5 Forum and M6 Forums
 6Likes
post #21 of 77 Old 4th November 2015, 10:13 PM
dskdan
dskdan's Avatar
dskdan is offline
post #22 of 77 Old 4th November 2015, 10:18 PM
flyfishing
I have an installer that has the crimp tool! I am going to get some LCIs, angel eyes, and get rid of amber bulb. He's gonna install and code and leave my DEPO lights on. Ahhhhh finally I will have the car that I want (CIC retrofit done too!). Next year, rod bearings as preventive measure.
flyfishing is offline
post #23 of 77 Old 4th November 2015, 10:26 PM
umichchris
umichchris's Avatar
Originally Posted by flyfishing View Post
Thanks for the info, BUT I already have LM2 module installed for a long time (so I could enable angel eyes on pre LCI car) and run them currently with DEPO tails on LM2 modules w/o any issues.
So, I would assume that I can just run LCI headlights with DEPO lights rt?
sounds like you want to do this your own way and tread new water....good luck. you asked how it should be done...im giving you the facts. i cant fathom doing a full LCI upgrade and keeping pre-LCI wired/designed aftermarket tails to save money. you'd have to rewire it all to make it work properly and send the proper signals to avoid errors or burning out the connections as too much voltage would be sent via the wrong wires....sounds like a headache waiting to happen with burnt our modules/bulbs/lights/relays....but good luck....anything is possible given enough time and enough money in the budget.
I do custom headlights & taillights
E46 ///M3 Vert - massive overhaul/rebuild project details here
E60 ///M5 Project #Patina
E36 ///M3 (sold) 5MT sedan
umichchris is offline
post #24 of 77 Old 5th November 2015, 10:44 PM Thread Starter
Fast.M5
Fast.M5's Avatar
ODBC cable ordered
software ready to code
awaiting headlight/tails/LM2 to arrive
From what I read, a battery charger is not required, just run the car, for non ECU code changes...noted this from bimmerfest thread.
2015 Ford F250 Super Duty 6.7l 15k miles Purchased 10.14.16
6" Lift and leveling kit
Fuel 20" rims with 37" tires
Bushwacker Fender Flares
Focal Front / Rear comps / JL Center / JL 13.5" / 500/1v2
SuperSound sealed box
BD Throttle Booster
S&B Intake
Spyder Head lights
Anzo Tail lights
Anzo 3rd brake light
Cold side Turbo pipe
V1 w/front camera
40" LED light bar w/KD brackets
LED High / Low / Fog lights
LED under body Side / Front / Back
Ford Raptor front grill
Coming:
EGR/DPF delete
Ez Lynk w/PPEI Tune and indash iPad Mini for gauges/tuning/shift on fly
5" Flo Pro Exhaust
5" to 6" Flo Pro Exhaust Tip
My Old Show off thread:
https://www.m5board.com/vbulletin/own...ra-inside.html
Fast.M5 is offline
post #25 of 77 Old 7th November 2015, 04:58 PM
harperdarshan
harperdarshan's Avatar
i did lci headlight and tail light conversion on my m5 did not need to switch out my lcm or have any recoding done. I ordered the proper wiring kit for the lci conversion. Once all the wiring was completed I plugged them in and the lights functioned without any issues.
That.M5
harperdarshan is offline
post #26 of 77 Old 7th November 2015, 06:33 PM
umichchris
umichchris's Avatar
Lol there's is much misinformation in this thread. Any hack job can be done for cheap...but when the lights burn out or the lm2 module fries then you're going to spend more money fixing things than you would have spent doing it correctly the first time.
I hope whoever reads this and is thinking about doing the retrofit properly...ignores this thread lol
post #27 of 77 Old 7th November 2015, 08:04 PM
MKhaled
Originally Posted by OzMosis View Post
You will need a new light control module, the LM2, which requires coding to your VIN in order to work properly. BMW also sells an OEM wiring harness kit for the LCI headlights and tail lights that you can install, so that you don't have to waste gobs of time modifying the existing pin connectors. Good luck, it is a good upgrade. I've had it done on my M5 already. The LCI lights look way better than pre-LCI in my opinion.
Hello OzMosis
Thanks for the post.
I am also planning to upgrade my 06 to LCI headlights, I have found the headlights, but was concerned about the LCM, I read somewhere (5series.net) if you car 06 and above move the LCM doesn't need replacement? Any how if I replace it with 09 M5 LCM, (its been removed from a working 09 m5) would it still need programming to my VIN? - Also if you could let me know where is the LCM located on the car?
Many thanks
Best regards !!
MKhaled is offline
post #28 of 77 Old 7th November 2015, 08:06 PM
MKhaled
Hi OzMosis
The post is insightful. I am also planning to upgrade my 06 to LCI headlights, I have found the headlights, but was concerned about the LCM, I read somewhere (5series.net) if you car 06 and above move the LCM doesn't need replacement? Any how if I replace it with 09 M5 LCM, (its been removed from a working 09 m5) would it still need programming to my VIN? - where can I get this programming, I don't want to go to the dealer, Also if you could let me know where is the LCM located on the car?
Many thanks
MKhaled is offline
post #29 of 77 Old 7th November 2015, 08:13 PM
SuckaGDog
SuckaGDog's Avatar
According to the install guide posted earlier in this thread it showed the only new harness available in the upgrade kit was for the taillights. The kit included new connectors for the headlights that you still had to swap the original harness pins into. Is that not correct?
Evolve Stage #3 E60 M5
Performance
-Evolve Stage 3 Header Tune
-De-cat Stock Headers
-Eurocharged Pulley
-RPi GT Exhaust Sec 1-3
-RPi Scoops, BMC Filters, Block Off Plates
-RPi SV1 Oil Cooler
Handling
-Dinan Stage 1 Suspension
-Carbotech Bobcat 1521 Brake Pads
-RDSport Sway Bars
-StopTech SS brake lines
Exterior/Interior
-Weisslicht LED License Plate lights and White LED Side Markers
-Republic Wrap Custom Headlights with Orion V4s
-Color Matched Kidney Grills, Matte Black Side Vents
-Sprint Booster V2
-Trinty Autosport Interior LED's
-iND Painted ///M5 Badge
-LCI Tailights w/ Bruce Miranda V6.0
-BSW Center Speaker Upgrade
-Pedal Haus Black Anodized Pedals
-DCT Motorsports CF Steering Wheel
-HRE P40S Brushed Tinted Clear, Wrapped in PSS.
Front: 20X9 (255/35/20)
Rear: 20X10.5 (295/30/20)
-Custom Coding by [email protected]
Countermeasures
-Blinder M47 Laser Jammers
-V1 Hardwire
Pictures
2014 Photos
2015 Photos
SuckaGDog is offline
post #30 of 77 Old 7th November 2015, 08:44 PM
MKhaled
Hi, Please if you M5 is 06 model.. Thanks
Best regards !!
MKhaled is offline
E60 Headlight Retrofit PRE-LCI - LCI Niner49 E60 M5 and E61 M5 Touring Discussion 6 11th August 2015 08:27 AM
E60 M5 Front Bumper Difference pre-LCI vs LCI Johnny Tweak E60 M5 and E61 M5 Touring Discussion 4 26th April 2014 08:54 PM
E60 For Sale: SELLING e60 LCI tail lights US Version red blinker (WITH RETROFIT KIT -> PLUGS INTO PRE LCI 03-07) garom5 Parts / Other For Sale or Wanted 3 1st February 2013 11:36 PM
DIY: Make a bracket to fit your LCI iDrive controller in your pre-LCI Console pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 16th September 2012 11:05 PM
Ventilated / Heated Seat Buttons on LCI and Pre LCI Cars francom82 E60 M5 and E61 M5 Touring Discussion 6 22nd March 2010 02:22 AM
