DIY: Total Engine rebuild and twin plate clutch s85 with pictures - BMW M5 Forum and M6 Forums
 16Likes
post #1 of 61 Old 27th October 2015, 10:43 PM Thread Starter
M5v10man
Here is the rebuild of the new engine and as much info as I get time to add including photos. It will show the assembling of the new engine and the parts needed and any special tools etc.
I will start by adding some parts ordered for the build.
A big thanks to Troy in the USA for his knowlege and help.
First of all the donor engine that has been rebuilt from a 38k miles engine with new shells and de carboned etc.
New vanos post 2005 ordered, new crank drive gear and vanos drive gear with updated teeth ordered.
New Carbon twin clutch ordered
Removed the bed plate to and remove sealant and use proper Loctite resin, whilst bed plate off check for any debress or contamination.
Name:	2015-07-22 18.53.27.jpg
ID:	635553   Click image for larger version
Name:	2015-07-22 18.53.46.jpg
ID:	635561   Click image for larger version
Name:	2015-07-22 18.54.00.jpg
ID:	635569   Click image for larger version
Name:	2015-07-22 18.54.25.jpg
ID:	635577   Click image for larger version
Name:	2015-07-22 18.54.28.jpg
Name:	2015-07-22 18.54.45.jpg
ID:	635593   Click image for larger version
Name:	2015-07-22 18.54.48.jpg
ID:	635601   Click image for larger version
Name:	2015-07-22 18.54.50.jpg
ID:	635609   Click image for larger version
Name:	2015-07-22 18.55.03.jpg
ID:	635617   Click image for larger version
Name:	2015-07-22 18.55.06.jpg
Name:	2015-07-23 15.19.45.jpg
ID:	635633   Click image for larger version
Name:	2015-10-27 20.23.59.jpg
ID:	635641   Click image for larger version
Name:	2015-10-27 20.24.05.jpg
ID:	635649   Click image for larger version
Name:	2015-10-27 20.24.11.jpg
ID:	635657   Click image for larger version
Name:	2015-10-27 20.25.06.jpg
Name:	2015-10-27 20.25.10.jpg
ID:	635673   Click image for larger version
Name:	2015-10-27 20.24.16.jpg
ID:	635681   Click image for larger version
Name:	2015-10-27 20.23.52.jpg
ID:	635689   Click image for larger version
Name:	2015-10-27 20.23.20.jpg
ID:	635697   Click image for larger version
Name:	2015-10-27 20.23.13.jpg
Name:	2015-10-27 20.22.44.jpg
ID:	635737   Click image for larger version
Name:	2015-10-27 20.01.15.jpg
ID:	635745   Click image for larger version
Name:	2015-10-27 20.22.56.jpg
ID:	635753   Click image for larger version
Name:	2015-10-27 14.34.38.jpg
M5v10man is offline
post #2 of 61 Old 27th October 2015, 10:56 PM Thread Starter
M5v10man
Cleaned the bed plate surfaces with scthbrite and solvent as advised by technician at Loctite UK before re assembly and injection of loctite resin.
Took 3 hours to remove the RTV that the engine builder had used and clean all traces of silicone from the groove, s crappy job!
M5v10man is offline
post #3 of 61 Old 27th October 2015, 10:57 PM
leonelm3-m5
leonelm3-m5's Avatar
Lucky you. Can't wait to hear video sound clips once completed
Leonel Aka " Rico"
Current:
2001 E46 Tiag / Imola
Modified HPF Turbo M3
9XX RWHP on E85 & the Gen2 PTE 6870
http://s1170.photobucket.com/albums/...t=53fe8fc9.jpg
2010 BMW X5M
K&N air filter
Megan Racing Exhaust
Decatted downpipes
H&R springs
stage 2 tune
leonelm3-m5 is offline
post #4 of 61 Old 27th October 2015, 11:00 PM Thread Starter
M5v10man
To be honest when I had the new engine delivered I thought ah thats easy three days work and it will be done! 12 weeks later and lots of learning and swearing and I am ready to get it done!! lol
M5v10man is offline
post #5 of 61 Old 28th October 2015, 12:03 PM Thread Starter
M5v10man
Replacing the vanos line with the new one from BMW. Then refitting bed plate to block.
Lightly oiled mains and fit bolts with lucas engine assembly lube to achieve accurate torque setting
Tighten 13mm fit bolts to 15lb ft
tighten m11 mains to 22lb ft, then 130 degrees
re tighten and check 13mm fit bolts to 15 lb ft
torque fit bolts 100 degrees
then tighten small perimiter torx cap head bolts to 10lb ft then addtional 90 degrees
All bolts can be reused.
pictures to follow
M5v10man is offline
post #6 of 61 Old 28th October 2015, 04:07 PM
sijia10358
sijia10358's Avatar
sijia10358 is offline
The Following 2 Users Say Thank You to sijia10358 For This Useful Post:
M5v10man (28th October 2015)
post #7 of 61 Old 28th October 2015, 11:36 PM
DFrankm5
DFrankm5's Avatar
S85 Engine Rebuild
I admire those of you who have the time, space, skill and tools to take on this task. Keep up the great work. You'll derive a real sense of satisfaction and confidence after the build!!
DFrankm5 is online now
The Following 2 Users Say Thank You to DFrankm5 For This Useful Post:
M5v10man (29th October 2015)
post #8 of 61 Old 11th November 2015, 11:42 AM Thread Starter
M5v10man
Some more parts, decided to replace all 10 injectors wirth genuine bosch injectors.
And dont forget to order the o ring with the internal vanos pressure line as it doesnt come with one. Also a new OEM rear crank seal.
Name:	2015-11-10 16.57.46.jpg
ID:	639458   Click image for larger version
Name:	2015-11-10 16.57.36.jpg
ID:	639466   Click image for larger version
Name:	2015-11-10 16.57.59.jpg
ID:	639474   Click image for larger version
Name:	2015-11-10 16.58.11.jpg
ID:	639482   Click image for larger version
Name:	2015-11-10 16.58.28.jpg
Name:	2015-11-10 16.58.24.jpg
ID:	639498   Click image for larger version
Name:	2015-11-10 16.58.36.jpg
M5v10man is offline
post #9 of 61 Old 11th November 2015, 02:22 PM
kotje
kotje's Avatar
kotje is offline
post #10 of 61 Old 11th November 2015, 03:55 PM
dskdan
dskdan's Avatar
Very nice job!
Where did you get your injectors from? Thinking of replacing all mine..
Cheers.
dskdan is offline
The Following User Says Thank You to dskdan For This Useful Post:
5soko (15th July 2016)
S85 total failures tanaysim E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 20 30th August 2013 02:07 PM
E63 M6 For Sale: BMW E63/E60 S85 V10 Engine For Rebuild/Parts Sjuliani Parts / Other For Sale or Wanted 0 9th May 2013 12:19 AM
Dinan S85 Complete Rebuild? Nabio E60 M5 and E61 M5 Touring Discussion 18 16th December 2011 07:30 PM
300k engine rebuild, the pictures! m5osc E28 M5 Discussion 19 8th November 2008 12:30 AM
Dibalo SV Twin Turbo engine pictures Z-1 GTBoard.com: General Sportscars 8 1st February 2003 09:10 PM
