True Equal Length Headers (Long Tube) -BMW S85 for E60/E61/E63/E64 - Page 32 - BMW M5 Forum and M6 Forums
 284Likes
post #311 of 320 Old 26th November 2018, 06:14 PM
flacoramos
Originally Posted by Garfunkgrin View Post
Sure thing - I wouldn't mind the data either. That said, 55 hp from headers alone is impressive in my book - whether its 50 or 60 I'm OK with it
-EDIT:
Out of curiosity, do you think 15% is high or low?
No idea, that's what I'd like to know. Each car (and dyno) is different so...
flacoramos is offline
post #312 of 320 Old 26th November 2018, 09:51 PM
ticat928
ticat928's Avatar
10 to 12% with warm differential, tires at 36 psi, 75-90 amsoil differential oil, run trans in gear that is 1:1, 6th in SMG, 5-30 amsoil syncromesh trans fluid.
There is a reason this car has 200 mph top speed with only 507 hp
ticat928 is offline
post #313 of 320 Old 27th November 2018, 03:14 AM
jcolley
jcolley's Avatar
Soon.
This engine wasn't running when it came in, so no way to do a test.
I did get a pre-header dyno from a local guy, but we weren't able to schedule the post-header dyno in time for him to pick up and he honestly didn't care about the numbers, so it was hard to convince him.
I have another here from MN that is finally going under the knife. It will be 100% before and after. The goal on that one is:
- as arrive dyno
- headers installed dyno
- headers and eventuri
- headers, eventuri, tune
The dyno I use is a Land and Sea hub dyno and to truly calibrate the mss65 for this one, we are looking at about 20 hours on the dyno.
- disable MAFs and run as alphaN
- reenable EGT probes (they were disused and abandoned in place on early cars)
- disable closed loop fueling (lambda sensor fuel trim)
- map every single cell of the VE tables to the correct fuel values
- map lambda targets for optimal power above cruise, optimal economy in cruise
- map all ignition advance cells for MBT
- re-enable closed loop fueling
Results to follow.
jcolley is offline
post #314 of 320 Old 28th November 2018, 02:52 AM
gary92
Originally Posted by jcolley View Post
Soon.
- as arrive dyno
Results to follow.
can you get a video from behind the car while its running on the dyno? the videos posted of that i've found so far are from inside the car, i'm very curious as to how it sounds outside
gary92 is offline
post #315 of 320 Old 28th November 2018, 03:22 AM
jcolley
jcolley's Avatar
The last video is filmed using a GoPro with Behringer ECM-8000 Studio reference Mic on the trunk with a wind guard. It's about 18"from the exhaust tips. It was obnoxious on a straight piped car. If it sounded that loud inside, I wouldn't have managed highway runs.
jcolley is offline
post #316 of 320 Old 30th November 2018, 04:17 PM
jcolley
jcolley's Avatar
One set in stock, not spoken for. Arrived this morning, customer backed out at the last minute. Test fitting today to make sure everything is good and will be ready to ship by Monday.
jcolley is offline
post #317 of 320 Old 8th May 2019, 08:18 PM
Saabretooth
Too many posts on the headers for me to catch up on.
Is there a difference between the RHD and LHD headers?
Saabretooth is offline
post #318 of 320 Old 8th May 2019, 09:25 PM Thread Starter
InfinityDesign
InfinityDesign is offline
The Following User Says Thank You to InfinityDesign For This Useful Post:
Saabretooth (9th May 2019)
post #319 of 320 Old 8th May 2019, 09:27 PM Thread Starter
InfinityDesign
post #320 of 320 Old 9th May 2019, 12:41 PM
Craze
Craze is online now
Are there any equal length headers available for the E60 M5? ernie E60 M5 and E61 M5 Touring Discussion 9 17th August 2014 08:31 PM
E60 For Sale: e60 e61 e63 e64 OEM headers for sale eddiejb Parts / Other For Sale or Wanted 1 3rd June 2013 04:59 AM
E60 For Sale: Clutch Kit+Flywheel E60/E61/E63/E64 M5 M6 S85 V10 SMG race_pilot Parts / Other For Sale or Wanted 11 25th January 2013 11:15 PM
E60 For Sale: Clutch Kit+Flywheel E60/E61/E63/E64 M5 M6 S85 V10 race_pilot Cars For Sale or Wanted 1 24th December 2012 11:43 PM
Evolve Equal Length Headers - Member offer evolve automotive M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 61 7th June 2011 05:41 PM
