1st gear stationary thud SMG - Page 2 - BMW M5 Forum and M6 Forums
 5Likes
post #11 of 13 Old 16th October 2015, 03:30 AM Thread Starter
///Mike M
///Mike M's Avatar
Originally Posted by 2Live4 View Post
^What software did you use for the SMG adaptation? Thanks.
I belive my shop used the INPA. He uses a basic laptop w/ the GT1 on there so it was nothing fancy. It wasn't AutoLogic or anything else inaccessible like that
2008 (06/08 "v. 3.0 S85")
Black Sapphire Metallic
Extended Portland Brown
///Mike M is offline
post #12 of 13 Old 17th October 2015, 03:00 AM
CHARIOT
Shifting to N in SMG is useless. SMG still holds clutch disengaged if engine running in N. At least with the Euro DME SW it does....
CHARIOT is offline
post #13 of 13 Old 17th October 2015, 05:10 AM
georstan
georstan's Avatar
Op...Mike M...
No need for the worry, I also have an 08 and experience the same issues. The thud is from clutch thinking you are stomping on gas after complete stop when your foot is off brake, or you are in N.
Just tap into 1st before moving off, or step on brake just before hitting gas to engage clutch. You can actually hear the clutch and gearbox egage with a slight clunk., then gently pull away as usual.
georstan is offline
Sometimes starting in 1st gear, sometimes in 2nd gear Roy46 F12 BMW M6 Coupe and BMW M6 Convertible | m6board.com 11 9th June 2013 03:50 PM
SMG- Loud thud when going into gear D_Iceman E60 M5 and E61 M5 Touring Discussion 7 5th November 2010 08:09 AM
1st gear pokerjunkie E60 M5 and E61 M5 Touring Discussion 3 19th March 2010 03:22 AM
My solution the the SMG thud.... BMWNTHZST E60 M5 and E61 M5 Touring Discussion 13 29th October 2008 05:01 PM
SMG hesitation in 1st gear - Update from BMW M CRISIS E60 M5 and E61 M5 Touring Discussion 42 29th October 2008 12:22 AM
