Is RTV ok for engine block and bed plate? - Page 2 - BMW M5 Forum and M6 Forums
 7Likes
post #11 of 20 Old 9th October 2015, 06:17 PM
jcolley
jcolley's Avatar
Also, it's kind of a pain in an engine stand when you remove the bedplate if you used two of its transmission mounting bolt holes for your stand.
You can use a 2x4 cut to correct length from the runner leg of the stand up into the "v" of the engine near the front for support when you unbolt the two rear stand mounting bolts from the bedplate. This way your block is still mobile with the stand.
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
bya8 (4th June 2016), M5v10man (9th October 2015)
post #12 of 20 Old 9th October 2015, 06:40 PM Thread Starter
M5v10man
its all coming apart and getting rebuilt, I agree and for the sake of a couple of weekends labour its not worth checking evrything.
M5v10man is offline
post #13 of 20 Old 9th October 2015, 06:43 PM Thread Starter
M5v10man
yeh, i know, good idea, I have just got it on my engine crain with the straps bolted to the heads underneath and then a chain bolted to the engine mount bolt in the upper block.
M5v10man is offline
post #14 of 20 Old 9th October 2015, 06:48 PM Thread Starter
M5v10man
M5v10man is offline
post #15 of 20 Old 9th October 2015, 06:57 PM Thread Starter
M5v10man
just checked the bolts from the new engine and they have the circlips on , checked the bolts from my old engine and they also have the circlips on. ???
Name:	2015-10-09 17.50.31.jpg
ID:	629210   Click image for larger version
Name:	2015-10-09 17.50.48.jpg
M5v10man is offline
post #16 of 20 Old 9th October 2015, 07:45 PM
jcolley
jcolley's Avatar
How the crap did you get those out?
jcolley is offline
post #17 of 20 Old 9th October 2015, 09:41 PM Thread Starter
M5v10man
I just pulled them out with my fingers. I did the same on my blown engine when i stripped it down they just pulled out. Should then be a permanent fixture?
M5v10man is offline
post #18 of 20 Old 9th October 2015, 09:45 PM
jcolley
jcolley's Avatar
The circlips are supposed to be large enough that you can only loosen the fitment bolt a couple of turns before encountering significant resistance. Once all the main bolts and perimeter bolts are removed, you then loosen the fitment bolts a couple of turns at a time in a back and forth pattern to jack the bedplate apart from the block. If you forced the fitment bolts out using pneumatics, you may not have noticed the additional resistance, but the circlip does look smaller. I'll take a picture when get home of the one I'm rebuilding right now. This is not really spelled out in TIS at all.
jcolley is offline
post #19 of 20 Old 12th October 2015, 12:18 PM Thread Starter
M5v10man
both engines 2005 and 2006 had both the same bolts, so i would presume this maybe a european/usa difference?
M5v10man is offline
post #20 of 20 Old 29th January 2018, 09:59 PM
dranik182
Hello guys. How fast this compound should cure? I used same compound and primer, injected it into the block with same tool 2 days ago and it still doesnt cure( I live in Ca so outside temperature seems perfect.
Any thoughts appreciated!!!
dranik182 is offline
E39 For Sale: 2002 Bare Engine block S62 M5 Engine Block M5MARIO Parts / Other For Sale or Wanted 12 30th May 2015 07:54 AM
rpi scoops block off plate questions Gump E60 M5 and E61 M5 Touring Discussion 23 7th June 2014 06:35 AM
Need advice on bed plate leak Evollep3 E60 M5 and E61 M5 Touring Discussion 11 5th April 2013 12:04 AM
Oil leak from engine block bed pan areas? Anyone else? JamesM3M5 E60 M5 and E61 M5 Touring Discussion 1 11th October 2012 06:10 AM
RPI scoop without Block Off Plate G1M559 E60 M5 and E61 M5 Touring Discussion 77 21st August 2012 04:02 AM
