Unique steering issue - need help diagnosing. - BMW M5 Forum and M6 Forums
post #1 of 7 Old 12th August 2015, 05:31 AM Thread Starter
C7mb
C7mb's Avatar
Hey guys,
So a few weeks ago, I started noticing an odd vibration in the steering wheel. It occurs at speeds above 60mph and only when in normal, non M mode. The car tracks straight with no steering wheel vibration, but when I wiggle the steering wheel back and fourth by only a few degrees, I can feel a vibration that gives the steering a notched effect. As if the electronic steering assist is turning on late or turning on and off.
I turned to the usual suspects, wheel balance, alignment, had wheel hubs and bushings checked and replaced brakes/rotors. No cigar.
Has anyone ever had this issue? Do I need to replace my servotronic valve or clean the steering angle sensor? Any help would be appreciated.
Performance: Bren Tuning ECU Tune [456whp] | Bren Tuning Euro SMG Tune | Custom Section 3 [Vibrant Bullet Mufflers & 3.5" Quad Tips] | Polished Throttle Bodies | Carbon Filter Delete | Ultra Racing Upper Front Brace, Lower 4-Point Brace & Rear Trunk Brace
Cosmetic: Interlagos Blue Metallic | 3M Satin Black Vinyl Wrap, 3M Gloss Black Roof & Accents, MotoGP Safety Car Livery | Pedal Haus Aluminum Pedals | LED Interior Lights | LED Reverse Light Bulbs | 1350 Lumen LED Auxiliary Reverse Light | LED Smoked Side-markers | Front & Side Mounted Star SVP Amber Mini-Phantom LED Light Heads | Strobes-N-More Amber Traffic Advisor
Communications/Countermeasures: Escort 9500IX | Uniden Bearcat 980SSB CB Radio + K30 35" Whip Antenna | Two-way Radio Speaker Hardwire
C7mb is offline
post #2 of 7 Old 12th August 2015, 10:49 PM
laomaiv10
laomaiv10's Avatar
Your front wheels have spacers?
Also check your front wheel tire rod assembly. I had the same issue but fixed after replacing tire rod assy on both front wheels. I also had spacers I didnt know were there. So not sure which one fixed it, but no more vibrations /shimmering for me.
laomaiv10 is offline
post #3 of 7 Old 13th August 2015, 08:38 AM
E61M5
The E60 M5 has hydraulically assisted steering, not electrically assisted.
Have you checked the fluid level? It sounds like a pump/rack issue with the assist mechanism.
E61M5 is offline
post #4 of 7 Old 13th August 2015, 01:05 PM
rt7085
rt7085's Avatar
I would look at the fluid as well. Has it been flushed lately? In Feb. of this year, my steering started making noises suddenly. As it turns out, this happened after a severe braking incident. The reservoir burped out a gush of fluid through the reservoir's weep hole just under the cap (and ended up low. A 'dumb' design that has been carrier forward for years! When you steer, the pump pulls the fluid level down in the reservoir and "sucks air" when just too low which led to a sudden change in feel. Why that happens only in non-M mode is a bit mysterious, but I believe the ballistics of this system are altered in M mode which may make it more noticeable in non-M mode as I expect it provide *more* power assist.
rt7085 is offline
post #5 of 7 Old 18th August 2015, 12:30 AM Thread Starter
C7mb
C7mb's Avatar
Nope no spacers. I had everything checked and there were no bushing issues.
I will definitely check the fluid as that is exactly what happened. I braked hard to avoid an accident and noticed the problem after that. Thanks guys I will keep you updated!
C7mb is offline
post #6 of 7 Old 18th August 2015, 02:11 AM
jcolley
jcolley's Avatar
jcolley is online now
post #7 of 7 Old 18th August 2015, 07:47 AM Thread Starter
C7mb
C7mb's Avatar
Originally Posted by jcolley View Post
I know a guy...
You will be the first to know if I am looking for replacement parts
C7mb is offline
Help With Steering Issue rrankin///M5 E39 M5 and E52 Z8 Discussion 3 23rd October 2013 01:52 AM
Help Diagnosing Steering Issue Beasty5 E39 M5 and E52 Z8 Discussion 13 30th July 2011 01:41 AM
Steering issue xxxxxxcallisto E60 M5 and E61 M5 Touring Discussion 4 18th July 2009 03:52 PM
Need help diagnosing issue with Dinan Stage 2 package and Sprint Booster 6pack E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 13th April 2009 02:59 AM
Unique steering wheel? GoneAgain E34 M5 Discussion 3 24th April 2007 03:12 PM
