Fault Code 2B57 - BMW M5 Forum and M6 Forums
 3Likes
  • 1 Post By MKhaled
  • 1 Post By jcolley
  • 1 Post By MKhaled
post #1 of 8 Old 28th July 2015, 11:27 AM Thread Starter
MKhaled
Angry Fault Code 2B57
dear all
Hope all well.
I was driving normally and I got 2B57 fault code. Dealership said its mass air flow sensor or secondary air pump (changed both) no cure. I am sure now dealership doesn't know what they are doing.
Can some please help me, I am in trouble with this code the cluster says engine fault reduced power.
Many thanks...
Best regards !!
MKhaled is offline
post #2 of 8 Old 28th July 2015, 12:39 PM
jcolley
jcolley's Avatar
2b57 means motor emergency program and is never found by itself. There has to be another code stores which causes that one.
jcolley is offline
post #3 of 8 Old 28th July 2015, 01:13 PM Thread Starter
MKhaled
Thanks for your reply.
in addition to 2B57 the other ones are:
1. The activation of the DM-TL Heating Code 27D9
Best regards !!
MKhaled is offline
post #4 of 8 Old 28th July 2015, 05:19 PM
jcolley
jcolley's Avatar
Your problem is with your DMTL (Diagnostic Monitoring-Tank Leakage) pump which draws a vacuum on the gas tank. It's a cheap component to replace. Left rear wheel well.
jcolley is offline
post #5 of 8 Old 28th July 2015, 09:13 PM Thread Starter
MKhaled
Thanks jcolley.. you been a great help I will definitely try and get this sorted. Thanks again !!! ing:
MKhaled is offline
post #6 of 8 Old 29th July 2015, 01:05 AM
CHARIOT
CHARIOT is offline
post #7 of 8 Old 7th October 2016, 02:14 PM
gmak
gmak is offline
post #8 of 8 Old 8th October 2016, 12:16 AM
CHARIOT
Are there more codes? Strange that a DMTL issue would cause the emergency programm. Maybe since its an emissions issue....
CHARIOT is offline
Codes 2b07 and 2b57 dave_1 E60 M5 and E61 M5 Touring Discussion 3 4th April 2014 06:39 PM
M5 Fault Code Help gmpolan E60 M5 and E61 M5 Touring Discussion 3 5th October 2012 09:35 PM
Fault Code Help! Please! umran9 E39 M5 and E52 Z8 Discussion 9 20th October 2009 03:33 PM
Fault code 50 Hawkwind E39 M5 and E52 Z8 Discussion 0 17th February 2007 02:10 AM
Feedback on fault code "TEV Fault"? AWBoy E39 M5 and E52 Z8 Discussion 2 3rd August 2006 12:52 AM
