SMG Pump Part? (Yeah, another SMG thread) - BMW M5 Forum and M6 Forums
post #1 of 12 Old 1st July 2015, 03:24 AM Thread Starter
anatoly14
Ok guys, I just purchased 2006 BMW M5 3 a month ago and I've been reading up on this whole SMG pump failure issue and I'm a little bit confused.
So, the part that fails is the SMG Pump.
Is this the part:
ecstuning.com/BMW-E60-M5-S85_5.0L/Drivetrain/SMG_Transmission/ES42124/
Or is there 2 pumps, one "SMG pump" that costs an arm and a leg and one SMG Electric Pump? Or it's just one pump?
So, if there is only one pump, I assume this one:
Why the parts cost is 3k+? Or you can't just replace the pump, you have to replace the whole hydraulic unit?
anatoly14 is offline
post #2 of 12 Old 1st July 2015, 03:44 AM
5soko
5soko's Avatar
Is this the part:
Yes that is the electric motor that drives the hydraulic pump in the smg hydraulic block..
What fails is this electric motor you have linked. B767CAPT has an amazing DIY for this pump aswell.
You dont need to replace the whole hydraulic unit...
Most common failures ive seen within the hydraulic system on this board is the slave, electric motor, clutch control solenoid aka the directional control valve above the electric motor (which seems to be rare as well). Everything else doesn't seem to fail often at all.
BMW set up its repair instructions to make it easy on its dealers and techs to just replace the whole hydraulic system that includes the clutch slave, PLCD, e-motor, etc in the wise words of Jcolley; at a shotgun attempt to resolve a issue instead of troubleshooting the wrong items since almost all techs arent aware of how a SMG works.
5soko is offline
post #3 of 12 Old 1st July 2015, 02:07 PM
Cinder
This is the part # for the electric motor - 23017841032.
'12 F10 M5 Singapore Grey with Sakhir Orange interior
Current Mods:
- LED Headlights retrofit
- LCI steering wheel
- KW HAS springs
- Rennen R10 wheels
Cinder is offline
post #4 of 12 Old 2nd July 2015, 12:35 AM Thread Starter
anatoly14
Got it! Thanks for clarification!
post #5 of 12 Old 8th June 2016, 07:47 PM
Racer14sl
Racer14sl's Avatar
Any early warning signs of a failing motor before it goes out? Is this issue linked to any specific E60 Model year with SMG? 2006 - 2010? Replacing this pump motor sounds like a good PM item to add to the list...
Racer14sl is offline
post #6 of 12 Old 16th June 2016, 04:49 PM
Cinder
You may get yellow/red cogs and undershooting pressure errors logged. The pump may also prime more often due to being unable to maintain stable pressure. It's a good item to change preemptively.
Current Mods:
- KW HAS springs
- Rennen R10 wheels
Cinder is offline
post #7 of 12 Old 17th June 2016, 04:49 AM
marioasoler
marioasoler is offline
post #8 of 12 Old 7th July 2016, 06:18 AM
dr_dirtg
dr_dirtg's Avatar
How often does the hydraulic pump run? Is there a way to measure this or compare to good hydraulic systems?
Mine comes up with a pump runs too frequent fault. I think its a leak rather than the motor?
dr_dirtg is offline
post #9 of 12 Old 7th July 2016, 12:56 PM
jcolley
jcolley's Avatar
Motor brushes wear, carbon dust builds up, motor torque decreases, motor runs longer to build same pressure. Inherent characteristic of brushed DC motors.
Replace the motor on the pump and problem solved.
I am pursuing some options for these including a brushless replacement setup, but still in planning stages.
jcolley is online now
The Following User Says Thank You to jcolley For This Useful Post:
AZ Beast (30th March 2019)
post #10 of 12 Old 7th July 2016, 01:13 PM
dr_dirtg
dr_dirtg's Avatar
Thank you for the insight - Is there any way to check the motor or run a test in rheingold to check the motor?
I did a test in rheingold for the pressure build up, it goes up to 65 (bar i think) and during the test it seems to bleed off rather quickly down, down, down all the way to 20 bar before i stoped it because i don't like not knowing what is going on lol.
dr_dirtg is offline
Anyone have the part number on the smg hydraulic pump relay? deebom3 E60 M5 and E61 M5 Touring Discussion 29 3rd August 2018 04:19 AM
SMG Hydraulic Pump Part # Phorte E60 M5 and E61 M5 Touring Discussion 20 10th May 2017 12:05 PM
E60 For Sale: COMPLETE SMG HYDRAULIC ASSEMBLY l SLAVE CYLINDER l PLCD SENSOR l SMG PUMP MOTOR l FREE SHIPPING deebom3 Parts / Other For Sale or Wanted 2 19th August 2014 10:14 PM
SMG Pump Rebuild V8haha E60 M5 and E61 M5 Touring Discussion 0 20th October 2011 07:26 PM
SMG pump? DriveWFO E60 M5 and E61 M5 Touring Discussion 3 16th March 2009 09:44 PM
