Engine reduced power - new engine @43k miles? - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 14 Old 20th June 2015, 04:22 PM Thread Starter
Hotsauce
Hotsauce's Avatar
I started having a problem 3 weeks ago and searched the form and found some helpful posts. I now am reaching out for thoughts and opinions. Here is the story:
Engine reduced power after pulling into my garage. Really rough on restart, I shut it off and it smelled like gas. Towed to Dealer 1. Cyl misfire on cyl 1-10 fault codes. Diagnosed fuel injector stuck open on cyl8. Recommended replace all 10. Oil changed too. I approved total bill $4k. Drove it home, still not running perfectly smooth, but I was told the cats may be compromised from the fuel problem. (Read the hydro locked injector thread closely)...oh boy.
Tried to start the next day, immediately went into reduced power fault again! Towed back to dealer 1. They swap injector and coil to other cylinder. Error on cyl 5 misfire - but that wasn't the location of the swapped parts. Codes cleared and haven't reappeared but still not running smoothly. After another week of them not sorting it out, I picked it up and took to dealer 2, where I've had work done before. They pull out a plug and stick a scope in the cylinder and say - get this... "It looks like a wolverine was in there, it's all tore up". .????Recommend new motor - $30k installed.
Now I'm freaking out... What do you guys think? I don't know if it could be throttle actuators, ionic unit, or other. I just don't feel I can trust anyone of these dealers. I appreciate your comments and recommendations.
Hotsauce is offline
The Following 2 Users Say Thank You to Hotsauce For This Useful Post:
F1DNA (13th June 2018)
post #2 of 14 Old 20th June 2015, 07:45 PM
TROY JEUP
Guest
Posts: n/a
I would say the replacement cost should be about $12,500 to $13,500 all-in depending on the install rate, but yes ~ if you have wolverine cylinder then the engine is toast.
post #3 of 14 Old 20th June 2015, 08:39 PM
ACG
ACG's Avatar
Scored cylinder walls means rebuild unfortunately.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #4 of 14 Old 20th June 2015, 08:46 PM Thread Starter
Hotsauce
Hotsauce's Avatar
Hotsauce is offline
post #5 of 14 Old 20th June 2015, 11:58 PM
jcolley
jcolley's Avatar
Failed open injector. Fuel washes down cylinder walls of oil film and no lubrication. That's why on mine I scoped the cylinder walls first. It's also possible that the hydrolock bent a rod, that's why I dropped my oil pan and inspected the bottom end. When dealers try to shortcut the repairs/inspections, it gets expensive quick.
jcolley is offline
post #6 of 14 Old 21st June 2015, 12:22 AM Thread Starter
Hotsauce
Hotsauce's Avatar
Thanks jcolley and ACG, you guys have provided great insights to all the members here. Today I purchased an M3...
Hotsauce is offline
post #7 of 14 Old 21st June 2015, 12:51 AM
jcolley
jcolley's Avatar
What year M3? The S65 shares many of the design "concerns" of the the S85 as they share connecting rods, pistons and bearings.
Hope your M5 gets sorted out soon.
jcolley is offline
post #8 of 14 Old 21st June 2015, 01:29 AM Thread Starter
Hotsauce
Hotsauce's Avatar
Thank you!
2012 white coupe, fun but I kinda miss that v10 sound when I mash the gas! Honestly, I should have researched more but 3weeks no car I needed to get something and stumbled across it and I really like that coupe look.
Hotsauce is offline
post #9 of 14 Old 21st June 2015, 03:43 AM
Cortinas78
Cortinas78's Avatar
Cortinas78 is offline
post #10 of 14 Old 21st June 2015, 04:08 AM
ticat928
ticat928's Avatar
Thank you!
Based on owners of e92 m3's I know you made a good choice, much more reliable than the m5
ticat928 is offline
Engine malfunction! Reduced power Natdad E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 27 26th November 2017 04:33 PM
Engine Malfunction - Reduced Power Ogjohnsmith E60 M5 and E61 M5 Touring Discussion 8 26th June 2016 03:15 AM
Engine Malfunction reduced power :( Sigm6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 18th August 2014 04:40 AM
Reduced engine power ror600 E60 M5 and E61 M5 Touring Discussion 11 20th June 2013 04:39 PM
Engine Malfunction Reduced Power 5K bowtie17 E60 M5 and E61 M5 Touring Discussion 5 23rd May 2013 08:09 AM
