4FA0 SMG fault - BMW M5 Forum and M6 Forums
post #1 of 27 Old 29th May 2015, 12:09 AM Thread Starter
canes79
Unhappy 4FA0 SMG fault
Hello Everyone,
I'll try and be as brief as possible without leaving anything important out. I have a 2006 e60 M5, and thanks to info from this forum as well as jcolley, I was able to get it fixed my 4f67 smg fault code last June by replacing the slave cylinder, clutch, and flywheel.
One thing I noticed after getting the car back was when coming to a stop a yellow cog popped up with the message "transmission fail safe, please take to nearest BMW yada yada yada" but would go away shortly after it appeared. And it stopped altogether for about 6 months until last week when it popped up again. Then yesterday the debacle began. I put the car in R, then when I put in 1 gear, the car jolted like Id just been rear ended, and I was unable to get the car back in neutral to do anything. I did get it towed to my house with special wheel dollies and when home
I put the computer on it and went through the test schedule from the fault codes 4FA0, 510e, and 510d. The 510e/d test failed the first time but I did it again and they passed and stated not to replace the PLCD sensor.
Then the 4FA0 test schedule wasted to do transmission and clutch adaptations. The transmission adaptation completed but the clutch did not, stating engagement position outside tolerance, as well as displaying a red cog clutch adaptation active symbol.
Any idea what this could be? The slave cylinder was just replaced a year ago, but I tried to bleed both the slave cylinder and the actuator block with DIS and the slave cylinder failed saying "minimum stroke of slave cylinder not reached" and the actuator block never finished after waiting 30 minutes. Any guidance is greatly appreciated. Sorry if I broke any rules with this post. Its my first one.
canes79 is offline
post #2 of 27 Old 29th May 2015, 01:00 AM
jcolley
jcolley's Avatar
4FA0 was caused by the 510d/510e.
Those codes are caused by an interruption in the signals from/to the PLCD. Nothing else causes those.
No signal from PLCD -> no position information for clutch -> position deviation (4fa0)
Replace the PLCD and the 4fa0 will be gone.
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
canes79 (29th May 2015)
post #3 of 27 Old 29th May 2015, 01:02 AM
jcolley
jcolley's Avatar
Also verify your fluid reservoir is topped off after bleeding. It's not uncommon for the slave or block bleeding to fail the first few times as all the air is being purged. Just make sure it isn't sucking an air bubble now due to low level cavitating the pump suction.
jcolley is offline
post #4 of 27 Old 29th May 2015, 01:19 AM Thread Starter
canes79
Thank you very much jcolley. I was thinking the same thing, but was confused when the software said the plcd sensor was good and not to change it. However, I just ran the test again and it now says "when activated , none of the signals of the PLCD sensor had a position difference of 332...371[increments]! This corresponds to a clutch travel range of 17.5...19.5[mm]" Im not real sure what all that means, but I'd guess it translates to what you said, replace the plcd sensor.
Also, isn't this sensor located on the slave cylinder? Will I need to drop the transmission all the way or will the 6 inches it lowers down be enough to do it? And will I need to replace any dowels by either procedure used to get to the plcd sensor.
Thanks again jcolley. To say you are a great asset to this forum is an understatement. I really appreciate your help.
canes79 is offline
post #5 of 27 Old 29th May 2015, 11:55 AM
B767capt
B767capt's Avatar
Just have to lower the back of the transmission. You will need a 4mm allen on an extension to get the 2 bolts out holding the PLCD. Once loose you'll have to rotate the PLCD 180 degrees to enable it to slide back past the reservior vent.
B767capt is offline
The Following User Says Thank You to B767capt For This Useful Post:
canes79 (30th May 2015)
post #6 of 27 Old 6th June 2015, 09:15 AM Thread Starter
canes79
Just to update my situation, i went ahead and replaced the plcd sensor but unfortunatwly that didnt resolve the problem. I was left no choice but to drop the transmission and i was shocked to find the slave cylinder torn up and also damage to the fork where it connects to the slave, as well as the ball pin crumbled to pieces. I was shocked because i just had this replaced less than a year ago along with the clutch and flywheel kit. Is this normal for the slave to have gone bad in less than a year. I don't do launch controls but i do drive the car like its an m5 with 500 horsepower and not like its a toyota corolla. I almost wonder if i bought a used slave that was advertised as being new .....now i have to buy another one along with fork, ball pin, and whatever else, is there anything else i should get? Thanks in advance. I hate my life. J/k
canes79 is offline
post #7 of 27 Old 7th June 2015, 10:38 AM Thread Starter
canes79
canes79 is offline
post #8 of 27 Old 7th June 2015, 10:40 AM Thread Starter
canes79
canes79 is offline
post #9 of 27 Old 7th June 2015, 10:47 AM Thread Starter
canes79
Fault codes i had along with the error preventing the clutch adaptation to complete (teach-in of clutch valve characteristics was the step failing)
ID:	576041   Click image for larger version
ID:	576049   Click image for larger version
canes79 is offline
post #10 of 27 Old 7th June 2015, 11:03 AM Thread Starter
canes79
Just to update, i got the 4FA0 smg fault code, and the reason was from a faulty slave cylinder, and this was also the cause of the inability to stop/delete the clutch adaptation active red cog along with the continuous beep. Keep in mind, this happened to be the cause for my situation and although your smg's behaviors may be similar to mine, that doesnt guarantee replacing the slave cylinder will remedy the situation. Once i receive the parts and re-install everything, ill update. Is anyone even reading this? Lol. Hope so.
canes79 is offline
Tags
smg failure
SMG Fault codes help Justchill E60 M5 and E61 M5 Touring Discussion 2 4th February 2014 03:20 AM
Another SMG Transmission Fault seif_ossama E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 13 21st May 2013 03:51 PM
A new kind of SMG fault 7 speed SMG E60 M5 and E61 M5 Touring Discussion 15 2nd May 2013 02:04 AM
4fa0 smg code Viper966 E60 M5 and E61 M5 Touring Discussion 6 19th December 2012 02:20 PM
SMG fault? Qs06M5 E60 M5 and E61 M5 Touring Discussion 1 5th October 2007 06:27 PM
