E60 m5 rattle noise at certain rpm when engine under load - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 23 Old 7th May 2015, 03:14 AM Thread Starter
Hg1245
I have noticed that when I put the engine under load, either light or heavy load, there is a rattling noise that seems like it comes from the front of the car. It doesn't sound like the rod bearings. It is a light rattling that sounds like something is loose. Has anyone heard anything like this? Your advise is much appreciated.
Hg1245 is offline
post #2 of 23 Old 7th May 2015, 03:15 AM Thread Starter
Hg1245
I should note that the noise is non existent when reving the engine while the car is parked.
Hg1245 is offline
post #3 of 23 Old 7th May 2015, 05:28 AM
1hotm5
1hotm5's Avatar
Could be air in the Vanos. I was getting a slight metallic sounding rattle at 3000 to 4000 rpm. Bled the VANOS and rattle gone. I also have two bad solenoids which are not helping much.
1hotm5 is offline
post #4 of 23 Old 7th May 2015, 02:18 PM Thread Starter
Hg1245
Hg1245 is offline
post #5 of 23 Old 7th May 2015, 02:30 PM
Steve jarvis
Steve jarvis's Avatar
It could be detonating slightly. Our cars have a VERY high compression ratio for a non direct injected motor. The computer will pull timing if you stay in the throttle and the noise will go away. I believe this is happening to cars with higher miles that may be getting some carbon build up in the combustion chamber. This seems to be fairly common on the modern high performance engines like the Audi RS V8's.
You should put in some 100 octane unleaded fuel and see if the noise goes away.
My car has been doing it (wives daily driver) for a little while. I took the car for a few days and ran it very hard (trying to burn off some of the potential deposits) and it appears to be better.
Later, Steve
2006 M5 Sapphire Black Metalic, completely stock for now
2001 M3 Red/Blk 6sp, exhaust, coil-overs, and wheels, 19x9.5" with 275/30R19's front and rear
2006 911TT Black/blk 6sp EVOMS GT610 pkg (525whp & 510wtq)
Steve jarvis is offline
post #6 of 23 Old 19th August 2015, 11:49 AM Thread Starter
Hg1245
I have come to the conclusion that the noise is caused by four bad vanos solenoids. I ran a test and it came back all were out of tolerance. I think it makes sense because the solenoids aren't able to advance/retard the timing like they should. I believe the noise is from the actuating units on the heads.
Hg1245 is offline
post #7 of 23 Old 19th August 2015, 12:29 PM
rt7085
rt7085's Avatar
You should validate that with the experiences of other board members that had their solenoids out of spec. I feels like a stretch to me, but who knows.
rt7085 is offline
post #8 of 23 Old 19th August 2015, 06:37 PM
C7mb
C7mb's Avatar
How do you test the solenoids? I also have a rattle under load that sounds like I didnt tighten my aftermarket pedals (metal on metal vibration/buzzing).
Performance: Bren Tuning ECU Tune [456whp] | Bren Tuning Euro SMG Tune | Custom Section 3 [Vibrant Bullet Mufflers & 3.5" Quad Tips] | Polished Throttle Bodies | Carbon Filter Delete | Ultra Racing Upper Front Brace, Lower 4-Point Brace & Rear Trunk Brace
Cosmetic: Interlagos Blue Metallic | 3M Satin Black Vinyl Wrap, 3M Gloss Black Roof & Accents, MotoGP Safety Car Livery | Pedal Haus Aluminum Pedals | LED Interior Lights | LED Reverse Light Bulbs | 1350 Lumen LED Auxiliary Reverse Light | LED Smoked Side-markers | Front & Side Mounted Star SVP Amber Mini-Phantom LED Light Heads | Strobes-N-More Amber Traffic Advisor
Communications/Countermeasures: Escort 9500IX | Uniden Bearcat 980SSB CB Radio + K30 35" Whip Antenna | Two-way Radio Speaker Hardwire
C7mb is offline
post #9 of 23 Old 19th August 2015, 07:04 PM Thread Starter
Hg1245
You do it through software, I tested mine through DIS and performed the vanos ventilation about five times. Still making noise. If the noise you're describing only occurs at certain rpm and with the engine under load, chances are you have the same problem.
Hg1245 is offline
post #10 of 23 Old 19th August 2015, 07:49 PM
Steve jarvis
Sounds hard to believe all four solenoids would be bad.
Loud engine rattle under WOT / full load mrdop E39 M5 and E52 Z8 Discussion 102 27th January 2019 11:30 PM
Engine feels like it's "chugging" under load at low rpm. Resinears E39 M5 and E52 Z8 Discussion 24 20th October 2011 06:45 PM
Engine feels like it's "chugging" under load at low rpm. Resinears E39 M5 and E52 Z8 Discussion 2 26th August 2011 09:31 PM
Engine making humming noise around 4k rpm.. Rambino E60 M5 and E61 M5 Touring Discussion 0 22nd January 2009 05:36 PM
Engine rattle noise on startup? Laidback E39 M5 and E52 Z8 Discussion 12 11th September 2006 09:19 AM
