Another Engine Malfunction Reduced Power - BMW M5 Forum and M6 Forums
 3Likes
  • 3 Post By jcolley
post #1 of 8 Old 4th December 2014, 06:44 PM Thread Starter
precivilization
precivilization's Avatar
Few days ago, I was driving my car and received the dreaded Malfunction Reduced Power fault. Right before the malfunction, I smelled a strong fuel smell. The engine was shaking and sounded very rough. I was close to home so I just drove straight there.
The next day I had the car towed to the dealer, and today I received an email with their findings. Attached is the computer generated error code (I think.. because I asked the service representative to send me a copy of the error code report) along side the cost of fixing the problem, which truned out to be ignition coils, spark plugs, engine mounts, leak between transmission and engine (even though I have no oil drops where I park the car), replacement of underneath covers and a few other nuts and bolts.
Can M5 gurus please take a look and advice? Any thoughts will be greatly appreciated.
08 E60 M5 production 03/07 Euro face-lift.
60k miles on the clock. I bought the car with 54k miles.
No mods except from K&N Intake system installed by PO at the dealer.
PO have done all services at the dealership, at least that's what the records I found with the car suggests.
Note: $1 = 3.65QR
Total estimation to fix all problems is $5590
precivilization is offline
post #2 of 8 Old 4th December 2014, 07:52 PM
jcolley
jcolley's Avatar
You have 26 error codes which are almost all electrically related.
- Test battery under load
- Test alternator output voltage
Once those are resolved and only then, look at every thing else. No other vehicle made is as sensitive to low voltage as the E60.
jcolley is online now
post #3 of 8 Old 4th December 2014, 09:23 PM Thread Starter
precivilization
Thanks jcolley. A bit of info I forgot to mention as i thought perhaps irrelevant. For four of five days prior to the malfunction incident, every time I get in the car in the mornings it takes me sometimes five minutes and lots of trials on the start button to get the car to start. That seem to coincide with the weather cooling off here at the same time. Somehow this seem to support your theory? I will have the dealer check on the battery and alternator and report back.
post #4 of 8 Old 5th December 2014, 02:37 AM
Pezho405
Pezho405's Avatar
Pezho405 is offline
post #5 of 8 Old 9th December 2014, 08:56 PM Thread Starter
precivilization
So the dealer called me today to say that both the battery and the alternator are fine. Jim, would the problem perhaps be bad ignition coils + spark plugs? I mean the car was producing so much unburned fuel. If so, would it be safe to drive the car home to do the coils and plugs work myself?
post #6 of 8 Old 9th December 2014, 09:01 PM
Raptor6702
He says alternator is fine ? What values ? Sorry but I don't trust one cts dealers...
Raptor6702 is offline
post #7 of 8 Old 9th December 2014, 09:06 PM
anzafin
You could ask the shop if there's any mentions about too high voltage in the fault list. It could be a bad voltage regulator inside the alternator.
- Antti -
anzafin is offline
post #8 of 8 Old 9th December 2014, 09:18 PM Thread Starter
precivilization
The service rep told me when I requested that the battery and alternator be checked about the procedure of going about checking them. When he called today I was sleep, he did give me the values of both tests and I'm embarrassed but don't remember them. But if that's any help, I can call tomorrow and inquire about them once again.
Engine malfunction! Reduced power Natdad E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 27 26th November 2017 04:33 PM
Engine Malfunction - Reduced Power Ogjohnsmith E60 M5 and E61 M5 Touring Discussion 8 26th June 2016 03:15 AM
engine malfunction, reduced power jdl92 E60 M5 and E61 M5 Touring Discussion 26 26th June 2016 03:02 AM
2007 BMW M6 Engine Malfunction! Reduced Power! DSC Malfunction scp624 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 26th August 2014 11:22 PM
Engine Malfunction Reduced Power Mbanks2 USA South BMW M Forums 0 8th August 2010 07:34 PM
