Transmission Malfunction | Please Help - Page 4 - BMW M5 Forum and M6 Forums
 7Likes
post #31 of 41 Old 23rd November 2014, 01:54 AM Thread Starter
laomaiv10
laomaiv10's Avatar
I don't know exactly. Could have been low hydraulic fluid level, could be failing smg motor. The only faults it threw were for not enough pressure in SMG (points to a failing motor or low fluid) and clutch activation/position deviation that usually accompanies the other fault code most time . No other fault codes. The PLCD was relatively new, as it was replaced before. But I went to delete the codes and they were gone. I will check from time to time. Also, I did the transmission/clutch adaptation and it improved the whole usability of the SMGIII. So far, I drove more for more than 2 weeks and did not see the red cog again.
But there are also 2 things that are different: the weather is cooler and I drive only in S 5 P500. Don't know if the temperature have any effect on the SMG functioning.
And yes, I also put in a new SMG motor and new hydraulic fluid.
laomaiv10 is offline
post #32 of 41 Old 6th December 2014, 07:41 PM Thread Starter
laomaiv10
laomaiv10's Avatar
This morning the red cog came back. The Only fault code is 4FA0. No more pressure undershooting codes after motor replacement. The car drives fine, a little bang sound on gear changes, but if I change them on 2.5-3 RPMs, it's smooth. With just 4FA0 code, what else can I check? What else can this be? Thanks!
post #33 of 41 Old 16th December 2014, 09:01 PM Thread Starter
laomaiv10
laomaiv10's Avatar
red cog back again
Another red cog on start. New SMG motor, did clutch adaptations, new battery, refilled the smg reservoir, noticed a little sweat from fluid on the surface.
Red cog happens only on start when I press the brake pedal first. This morning noticed the brake pedal is hard to press.
Same codes: pressure undershooting and clutch position deviation. There was also another random code in DME: oxygen sensor-restart diagnostics.
Do you guys think it is still the electrical issue?
post #34 of 41 Old 17th December 2014, 02:35 AM Thread Starter
laomaiv10
laomaiv10's Avatar
post #35 of 41 Old 17th December 2014, 09:29 PM Thread Starter
laomaiv10
laomaiv10's Avatar
I have done SMG reset and upon start this morning: another red cog for several seconds and gone.
Checked faults: only 1 smg fault this time: 4FA0.
What shall I do now? Replace the whole smg unit? What if it's a worn clutch? Or shall I wait until it completely breaks down/throws more faults?
If someone was in a similar situation, please help with the advise.
post #36 of 41 Old 20th January 2016, 03:10 AM
moe00
moe00's Avatar
moe00 is offline
post #37 of 41 Old 20th January 2016, 06:28 AM Thread Starter
laomaiv10
laomaiv10's Avatar
QUOTE=moe00;6420906]i have same issues, no help yet?!?!?!?[/QUOTE]
I ended up changing clutch assembly.
But man, these cars need a new clutch every 6 months. Prepare at least $US3500 every half a year for a new clutch. I know this shouldn't happen, but it happened to me, and I always drive in manual S5 mode, never push or abuse it.
post #38 of 41 Old 23rd August 2017, 07:42 PM
Eleetpro
Eleetpro is offline
post #39 of 41 Old 23rd August 2017, 07:46 PM
gmak
Since this thread has come back from the dead.... Dude, either your clutch isn't being installed properly, or you're being way to aggressive on the shifts.
My M5 Thread: Tire tracks on my soul
Starring: The Perfect B.itch [TM]
gmak is offline
post #40 of 41 Old 23rd August 2017, 11:39 PM
M V10 Power
M V10 Power's Avatar
But man, these cars need a new clutch every 6 months. Prepare at least $US3500 every half a year for a new clutch. I know this shouldn't happen, but it happened to me, and I always drive in manual S5 mode, never push or abuse it.[/QUOTE]
Did you change the PCLD sensor with a new one when you Changed clutch?
M V10 Power is offline
pls help...transmission failure notice m5stealth E60 M5 and E61 M5 Touring Discussion 5 28th April 2009 10:24 PM
B8 ECU problem,help pls chrislux ALPINABoard.com | BMW Alpina Discussion 10 7th March 2009 05:17 PM
trying to find pics of interlagos blue M5, help pls (mods pls move to E39 forum, sry) psiggy Owners Gallery 1 4th July 2008 12:23 AM
oem m5 side view mirror problem..help pls??? aw/ir02smg E39 M5 and E52 Z8 Discussion 4 4th May 2006 05:24 PM
CARBON PROBLEM-update & draft letter to BMWNA: US members PLS READ wilsodh E39 M5 and E52 Z8 Discussion 18 1st December 2005 06:14 AM
