E60 M5 Evolve or Active Autowerks Alpha N tune - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 16 Old 21st August 2016, 03:24 AM
pinoy1974
pinoy1974's Avatar
E60 M5 MAFless Evolve R Tune Instructions and Review
Ok - so it looks like this review needs a bit of updating. here are my car's stats before I begin:
- 2008 e60 M5
- charcoal delete
- RPI scoops (no block off plates)
- AFE filters (not the BMC cotton filters)
- and a bunch of aesthetic stuff
I've had my car now for about 3 years, and I've always been looking and researching a tune for the e60 beast. it seems the tunes from other reviews seem to enhance the natural abilities of the e60 m5. I narrowed it down to the Dinan, AA, and Evolve.
I finally made a somewhat impulse buy after 3 years of research to the Evolve r Alpha N MAF Delete tune just a week ago.
http://www.evolvetuning.us/bmw/5-ser...a-n.html?sl=EN
$1570 includes the 'coding' capability and shipping (still waiting for the cable almost 2 weeks after the initial shipment of the other equipment).
Initial impression of preparation and difficulty - VERY EASY. I'm kind of computer technical, but not very car technical, and even I can do it.
the package from London looks like this:
- interface USB cable
- ODBC connector
- MAF replacement covers
- thermistor
- replacement cable for thermistor
The first thing I did was install the software from Evolve on my laptop - Simple. Every thing looks exactly as the manual shows upon installation and read of your ECU. the first read and analyzation takes about 45 minutes.
no need to worry about your battery giving out. as long as your laptop has a decent charge, you should be ok to read the car's ECU for 45 mins. again, the instructions are exactly like the manual.
I emailed the file to Evolve Tuning the evening of Thursday EST and I received the 'tuner file' the next morning on Friday. Very FAST! the only problem was that a prerequisite was to delete the MAFs and place the thermistor before implementing the Evolve R Alpha N tune. The kit had absolutely ZERO instructions so Mateen at Evolve Tuning sent me some rather technical questions that had car mechanic vernacular that I didn't quite understand, so I looked in this board and found this link which helped A LOT!
https://www.m5board.com/vbulletin/e60...-easier-2.html
here are some step by step pictures of what I did to supplement the instructions above:
Instead of soldering the wires to the wires under the MAF connector wires, I used the same methodology as the link above:
only problem is that the e60 MAF connector is much smaller than the e39 I believe is what the original instruction was for, so I literally cut the connector in half in order to fit:
then, per Evolve instructions, you simply unscrew the stock MAFs and remove:
MAF unscrewed and removed - do this for both passenger and driver's side MAFs
then remove the MAF Sensor from the connector by depressing the two clips on either side of the MAF connector. pull FIRMLY on the MAF sensor to remove:
Cap the passenger side MAF sensor hole with the cap provided by Evolve:
then secure the MAF connector somewhere out of the way - this is how I did it:
on the driver's side, replace the MAF hole with the cap that has the hole in it and firmly push the new thermistor in the provided hole. you may have to attach the thermistor before you secure the holed cap which is what I did because of the force you have to 'pop' it in the hole:
once secure in the hole, plug the wires from the new wire/thermistor connector into the stock MAF connector into slot 1 and 3 - apparently it doesn't matter which wire goes to which. the wires under the rubber wire connector reveal the wire #s:
locate 1 and 3
then I plugged my newly crimped connectors on the stock MAF side instead of soldering as recommended by Evolve. My way seemed cleaner:
I then zip tie that remaining driver's side cables and newly connected stock (previous) MAF connector cleanly away:
once the physical labor is done, follow the software upload instruction to the tee and viola, ECU program complete! Takes literally about 5 minutes to update the file received from Evolve Tuning as opposed to the 45 mins it takes to read your car's initial data:
Now for the exciting part. The REVIEW of the tune.
- you definitely do have to drive the car around for at least 35-50 miles in order for the ECU to adapt to road conditions, driving style, and air flow, etc
- I'm now 84 miles into the tune and the difference is pretty phenomenal
- at 400 and conservative shift settings, when you floor the pedal, the downshift is much swifter, with kind of a extra 'kick' into the lower gear launching you forward much faster than stock
- at 500 and ///M mode, the response is even crisper especially when in manual mode
- ///M mode is INSANELY faster than stock - ludicrously fast but stable. very quick to reach the PREVIOUS limit which was 155 mph. I was in ///M mode entering a freeway here in Florida in 1st gear going 45-50 MPH with the new high rev RPM of 8500 (this scared me, as the engine was screaming to shift)
- once I shifted into 2nd at nearly 60 mph, my rear tires "SQUEEKED" into second (never happened before), then hauled *** to a quick 155-->160 MPH and left behind a stock Panama S in my dust who tried to keep up
- all of the shifts seem so much smoother and natural for the car in all modes
- it is true from the other reviews that the tune really makes the car a much better 'driver's car' without all the jerkiness of stock
NEXT STEPS:
- Dyno
- secondary CATs delete - reprogram of Evolve software for CATless setup ($150 I think)
- tempted to muffler delete or RPI exhaust, but like being a "sleeper car" with my 19 month old daughter's Recaro car seat in the back ;-)
Jax E60 M5
AFE Dry Filters
Roof Spoiler
Carbon and white roundels
WeissLicht LED License Plate Illumination Upgrade (best on the market in my opinion)
RPI ram air funnels
carbon air filter deleted
front reflectors deleted
Lux H8 v4 Angel Eye bulbs (set to blue hue)
WeissLicht LED Side Lenses
20x9/20x10.5 Avant Garde M359 Rims
working on:
Exhaust
Software remap upgrade (possibly Evo/AA)
Last edited by pinoy1974; 22nd August 2016 at 12:32 AM. Reason: pictures didnt post for some reason
pinoy1974 is offline
post #12 of 16 Old 21st August 2016, 09:07 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Originally Posted by Allwheeldrive View Post
Well, I have visited several shops in Denver and by the time you purchase headers, get them installed and a tune, you are over 6k easily. I figure since I only drive my car on Sunday, its not worth it. 30hp and 6k doesn't make sense to me. besides, I am getting tired of shifting gears and may just sell this one next year and find a 2010 SMG.
All you need is this mate
https://www.turnermotorsport.com/p-1...s-in-manifold/
No need to spend 6k on headers.
Hasan Shaikh is offline
post #13 of 16 Old 22nd August 2016, 02:36 PM
Guest
Posts: n/a
- 2008 e60 M5
- charcoal delete
BMW M5 E60 ECU Tune Stage 1 including Evolver remote flash tuning tool
- ODBC connector
- thermistor
locate 1 and 3
NEXT STEPS:
- Dyno
Thanks for the detailed feedback and glad you are enjoying it.
post #14 of 16 Old 22nd August 2016, 02:40 PM
Guest
Posts: n/a
Our long tune headers are currently $3500 shipped due to the Strong USD to GBP exchange rate.
https://www.m5board.com/vbulletin/m5-...ml#post6762498
post #15 of 16 Old 22nd August 2016, 11:33 PM
[email protected]
m5board.com Site Sponsors
Mark@Evolve's Avatar
- 2008 e60 M5
- charcoal delete
- ODBC connector
- thermistor
locate 1 and 3
NEXT STEPS:
- Dyno
Glad you are happy with your tune, if you need anything let me know and we have our evolve etronic exhaust that would be perfect for you!
post #16 of 16 Old 10th April 2018, 10:06 AM
Ayrton Del Mazo
I just want mere kick out of my car and have given up on headers at this point. Anyone have any experience with the Evolve or Active Autowerks Alpha N tunes. Thinking about pulling the trigger next week when Im off. I live in colorado so worried about alpha N and the altitude.
Did you ever get around to doing a tune? Also in Colorado and in need of a tune ASAP as I have aftermarket tubular cat-less headers
Ayrton Del Mazo is offline
Evolve's Alpha-N tune and the Evolve-R cable "initial' review. timmay77 E39 M5 and E52 Z8 Discussion 114 19th May 2016 09:02 PM
Evolve Alpha-N Stage 2 Tune DocsV10 E60 M5 and E61 M5 Touring Discussion 25 8th May 2014 12:20 PM
E60 For Sale: Evolve-R Cable E39/E43/E60/E63 Evolve Alpha Tune jmauro Parts / Other For Sale or Wanted 5 28th March 2014 12:05 AM
Video: evolve headers, SS mids with SS cats, SS street muffler, evolve alpha N tune Obioban E39 M5 and E52 Z8 Discussion 37 22nd October 2013 02:08 AM
Evolve Alpha N Tune Review kevinsford E60 M5 and E61 M5 Touring Discussion 10 27th November 2012 06:54 PM
