Check engine reduced power code 2788 - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By jcolley
post #1 of 8 Old 27th September 2014, 10:40 PM Thread Starter
Kazem
Hi guys,
I am facing the same issue when pushing the car very hard i get check engine reduced power
The fault code is 2788
I tried almost every thing i changed the fuel pump and fuel filter
The fuel sensor that comes next to the front tyre on the left
Fuel computer
Flow meters
I fully reprogramed the car
Nothing did work
I am only having the 2788 fault code
Please any help would really be apreciated
Thank you
Kazem is offline
post #2 of 8 Old 28th September 2014, 03:39 AM
TROY JEUP
Guest
Posts: n/a
post #3 of 8 Old 25th February 2016, 04:16 PM
moe00
moe00's Avatar
moe00 is offline
post #4 of 8 Old 25th February 2016, 07:11 PM
torque
torque's Avatar
On my (now sold) 335i, the same symptoms were caused by a faulty injector. Ended up replacing all... Good luck.
DME
Fault code 2788 - P2288
Fault text Fuel pressure, setpoint/actual-value comparison at maximum pressure
Fault description Injector Control Pressure Too High
Condition for fault identification Test condition: Fuel pressure too high at maximum pressure. Deviation between specified/actual pressure > 20 % (K_PKS_OBD_Q_MAX)
Terminal condition: Engine running
Voltage condition: Battery voltage > 10.9V (k_pks_obd_ub_min)
Condition for fault memory entry 4000 ms
Action in service 1. Carry out test routine
2. Check plug and wiring harness at fuel-pressure sensor, replace sensor as indicated
3. Check plug and wiring harness at the fuel pump
4. Check fuel filter and pump, replace as indicated
Fault effect and breakdown warning CC message
Engine speed limited
Reduced power
MIL after engine runs 2x
Driver information Warning light: MIL, EML, CC message, backup program
Service instruction None
_______________________________________________
BMW M5 E60 6 speed manual - /RPi intake scoops/Agency Power pulley/Fast Attack 93 tune
Audi A4 2007 6 Speed manual/JHM stage1 software 93 octane/Cobb Intake/New Audi sport suspensoin - the old lady
2001 VW Golf GTI VR6/intake/GIAC/Exhaust- the small one
torque is offline
post #5 of 8 Old 6th March 2016, 01:18 AM
moe00
moe00's Avatar
They told me that fuel pump is not handling the tune .. And it is making this fault so what i m suppose to do!?
Is it the fuel pump? .. Is the fuel pump mostly done? I think was never replaced..
They told me also if i need to change it i need to replace fuel regulator also.
I have evolve tune some other suggest that i change the fuel pump with another bigger that handle high fuel capacity bar or something..
If i replaced the original oem fuel pump with another new oem does it clear this fault?
What we are 100% sure that the tune is making the fuel pump not to handle the fuel pressure.
Please help me what to do..
moe00 is offline
post #6 of 8 Old 6th March 2016, 01:55 AM
jcolley
jcolley's Avatar
While the tune might be related, it certainly is *not* possible that the fuel pump can't keep up with the demand of the tune. The stock fuel pumps (there are no aftermarket pumps for the S85) will push a 6.0 stroker on stock injectors to over 700HP. It absolutely will handle a stock displacement engine with any possible tune you can throw at it.
Now, it is possible the tune could have a parameter that isn't adjusted correctly and cause the fault, but not very likely. If your'e on the original pump, it may be worth replacing and definitely the filter.
jcolley is offline
post #7 of 8 Old 6th March 2016, 03:58 PM
moe00
moe00's Avatar
ah bro, but i kept doing my research and i found an owner of an m5 e60 that had the same problem.
he said do the following l should go to our dealer of BMW here in lebanon beirut " Bassoul- hneine" and buy a fuel pump and fuel regulator, the fault will disappear and the car should run fine and more powerful than befor, he suggested as they told me before to replace both cause one could cause damage to the other if not replaced both. don't know reason he said that but he said he already replaced one and leaved the other and the fault kept showing.
i m going to change then soon they cost here 650 USD both.
moe00 is offline
post #8 of 8 Old 7th March 2016, 04:40 AM
The moth
The moth's Avatar
Please update us once completed
The moth is offline
Intermittent Check engine light-Loss of power-Misfire code- Tarek307 E39 M5 and E52 Z8 Discussion 45 5th March 2014 09:14 AM
Engine Malfunction Reduced Power / Increased Emissions Need Help With Code S6 E60 M5 and E61 M5 Touring Discussion 14 3rd July 2013 09:25 PM
Reduced engine power ror600 E60 M5 and E61 M5 Touring Discussion 11 20th June 2013 04:39 PM
code help please... engine malfunction reduced power savvibmw E60 M5 and E61 M5 Touring Discussion 11 18th February 2013 06:41 PM
Engine Malfunction, reduced power jram E60 M5 and E61 M5 Touring Discussion 1 28th December 2012 03:28 AM
