Annoying bmw fault 2738 Fill plausibility bank 2 - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 33 Old 9th August 2014, 04:05 AM Thread Starter
hchome
hchome's Avatar
It's driving me crazy!
I hope you can help with this really annoying problem.
I bought this 2005 M5 3 years ago, all seemd really nice, but the car started rough idle and stalling at lights, losing power when driving at highway since last year. Everything happened rather occassionally, and always when engine was warm and hot weather.
I took it to a garage and dealer had it thoroughly checked. Spark plugs, cables, air and fuel filters etc, though nothing was found.
I also changed the all o2 sensor, maf, throttle actuator, alternator with regulator, etc......
People from the garage now think it is probably the Air Flow Sensor fault, which apparently is very difficult to find the reason.
I'm not an expert and don't really know what the problem is, but I have read a lot on the internet still no finding.
BMW Error code: 2738 Fill plausibility bank 2
I hope somebody with knowledge of this car and experience, can give me some advice please
Thanks in advance.
Howard
E60 M5 Frozen Dark Blue Metallic/Silverstone
Matte Black Kidney and Fender Grills
Carbon Fiber Front Spoiler and Rear Diffuser
RPi RAM Scoops/Block Off Plates/BMC Filters
RPi Sec 1 Straight Pipes/RPi Sec 2 Hybrid X Pipe
Eisenmann Race Oval Exhaust
Eibach Pro Kit Springs/Custom Spacers
Vossen CV3 Matte Graphite Wheels
Michelin PSS Tires
hchome is offline
post #2 of 33 Old 9th August 2014, 07:54 AM
Xeno
Xeno's Avatar
I've had this problem before but it was the MAF sensor. I replaced and it solved the problem. hmm...
Xeno is offline
The Following User Says Thank You to Xeno For This Useful Post:
hchome (11th August 2014)
post #3 of 33 Old 9th August 2014, 05:57 PM
TROY JEUP
Guest
Posts: n/a
Pull the fuses for the fuel tank (there is one in the glovebox and one in the trunk. Put them back in and then turn the car back on. Should do the trick
Sent from AutoGuide.com App
The Following User Says Thank You to For This Useful Post:
post #4 of 33 Old 10th August 2014, 03:14 PM Thread Starter
hchome
hchome's Avatar
Thanks Troy Jeup!!!
Do you mean that have to pull all of the fuses in the glovebox and one in the trunk?
Thanks dude.
Michelin PSS Tires
hchome is offline
post #5 of 33 Old 10th August 2014, 10:55 PM
jcolley
jcolley's Avatar
F30 in the glovebox and F72 in the trunk. I still think you got lucky with this that time Troy, but it's worth a shot.
jcolley is offline
The Following User Says Thank You to jcolley For This Useful Post:
post #6 of 33 Old 11th August 2014, 02:09 AM
TROY JEUP
Guest
Posts: n/a
Luck is all part of the game ;-P
post #7 of 33 Old 12th August 2014, 11:46 PM
lefaslayer
Hey i have same problem. Check maf sensor near secondary air pump. I removed my sec air pump because not working and get this code after that.
http://www.realoem.com/bmw/showparts...11&hg=11&fg=50
lefaslayer is offline
post #8 of 33 Old 13th August 2014, 03:10 AM Thread Starter
hchome
hchome's Avatar
RealOEM.com Â* BMW E60 M5 EMISSION CONTROL-AIR PUMP
thanks dude, I will try to order and replace this part at well.
Michelin PSS Tires
hchome is offline
post #9 of 33 Old 13th August 2014, 03:20 PM
post #10 of 33 Old 13th August 2014, 05:27 PM
TopEnd
TopEnd's Avatar
Did the fuse pull work? Have a bet with señor Colley
I would like to know as well
2013 BMW M6
PERFORMANCE:
-TBD
SUSPENSION
-TBD
EXTERIOR
-TBD
INTERIOR
-TBD
TopEnd is offline
Coolant temperature plausibility darknight E39 M5 and E52 Z8 Discussion 33 22nd June 2017 03:09 AM
2000 M5 E39 Air mass plausibility sensor fault MJsM5 E39 M5 and E52 Z8 Discussion 0 6th August 2013 06:19 PM
3 x BMW M5 F10 spied in fill-HD 1920x1080p Gustav F10 M5 Discussion 1 12th March 2011 01:52 AM
27BE vanos control bank 2 fault?? jamiepeers E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 6th August 2010 01:30 PM
Suggestions/Feedback/Experiences ... CATALYTIC CONVERTER BANK 1 and BANK 2. T0RQUE E39 M5 and E52 Z8 Discussion 3 20th May 2008 01:04 AM
