aux cable location? - BMW M5 Forum and M6 Forums
post #1 of 9 Old 24th July 2014, 08:47 AM Thread Starter
Tho///a5
Tho///a5's Avatar
aux cable location?
So I have a gateway 500 for my iPod and the Bluetooth add on to stream music from my phone, but I also have oem Bluetooth. Sometimes when I'm trying to connect it flip flops back and forth between the two and sometimes it connects to both (ideal, but difficult to accomplish). Sometimes my commute doesn't make it worth all the trouble. I bought a 10' aux cable to run from my glove box to another location near the center console. Anyone else done this or do you have an idea of where to put it?
I originally was only going to ask pre LCI guys due to the aux port location. Any ideas would be greatly appreciated. Thanks.
Tho///a5 is offline
post #2 of 9 Old 24th July 2014, 07:01 PM
methodsound
There is a much better way to stream bluetooth audio with your current setup. I suggest not connecting to/removing the bluetooth add on for the Gateway. In my 545i and in clients cars I have been using the Tune2air 30pin bluetooth adaptor along with the Gateway. The Tune2air emulates an iPod with text and control data. That means that you can use the iDrive controls with the onscreen menu for full control of your bluetooth iPhone devise. Pandora and other streaming services work as well, but you only get track info and can use track up/down. I have tried Androids also, and they still work but with less text function, it's really meant to emulate an iPod. I have a Tune2air in stock if you want to try one.
-Michael
ID:	446850   Click image for larger version
2004 BMW 545i factory options: 6MT, sport/ premium/ cold weather package, Nav, L7, SAT, CDC, active steering, dynamic drive
factory equipment retrofits: ACM, AUX, MP3 activation, front and rear cameras
aftermarket mods: iPod dock ash tray w/ video on screen,USB, DSP sound processor, four 8" subs in rear shelf, Tru-Technology amps, Hybrid Audio speakers...
build logs: https://www.m5board.com/vbulletin/e60...installed.html
url: http://methodsound.com
methodsound is offline
post #3 of 9 Old 24th July 2014, 08:01 PM Thread Starter
Tho///a5
Tho///a5's Avatar
Not at all what I'm asking. My current setup allows for everything I already have. Just looking for a route to run/hide my aux cable. Thanks though.
Tho///a5 is offline
post #4 of 9 Old 25th July 2014, 04:07 AM
methodsound
The first half of your post was complaining about bluetooth connectivity issues. My suggestion would fix that issue, allow you to use iDrive to control your music, and possibly eliminate the need to install the AUX cable. I was thinking outside the box but still trying to help. For a place to run your AUX cable I can't think of a clean way to do it other than run it to the factory location behind the center console. What do you think about the factory AUX position behind the console?
post #5 of 9 Old 25th July 2014, 04:18 AM Thread Starter
Tho///a5
Tho///a5's Avatar
I appreciate your assistance and offer but that's not what I need. I typically set my phone between the e-brake and the center console. Ideally a route that would have the 3.5 cable come out somewhere there. Right now its super ghetto from the glove box across my console. I don't know that running it to the LCI or. Spot would make a difference. I planned on running the 10' cable through the dash and out of the console somewhere. Was hoping someone had done it before. I might undertake this on my upcoming 3day weekend.
Tho///a5 is offline
post #6 of 9 Old 25th July 2014, 07:08 AM
methodsound
How about this idea: E46 AUX retrofit kit BMW and there is always the option of adding/using the factory AUX location.
This could be a stock looking flush mounted AUX plate mounted near the phone. This might look ok in the bottom left area of the plastic radio bezel. Or closer to the phone?
It would have to be soldered with RCA tips to connect to the Gateway. And I think it also has filter/resistors on the wires, which might be useful but could be eliminated.
post #7 of 9 Old 25th July 2014, 07:50 AM Thread Starter
Tho///a5
Tho///a5's Avatar
Lol. I already have that. M5s have this standard. I have thebfirst year it came in the glove box. I can easily pull it and move it somewhere, but I'd rather leave it where it is and just run the 3.5mm cable somewhere near the phone. hence the reasoning behind getting a 10' cable to do this. I'd take a pic but my girl has my car till tomorrow.
Tho///a5 is offline
post #8 of 9 Old 27th July 2014, 11:00 PM
carcus
carcus's Avatar
Not all came with them standard. I have the CD changer in the glove box. Mine is a 2006 M5.
2006 BMW M5, Sapphire Black Metallic, Colorado BMW CCA Member, Colorado ///M Flight member
carcus is offline
post #9 of 9 Old 27th July 2014, 11:15 PM
Lay3r3
Lay3r3's Avatar
I have a 2010 do the dash isn't the same but may be close enough. The route you described is super easy to do other than the last 12" and final mount point determination. Getting from the glovebox to the center console and along the center console is a snap - just a few screws.
Lay3r3 is offline
E60 For Sale: RPI scoops, Y-cable for aux/usb and tune2air adaptor esqyankee Parts / Other For Sale or Wanted 6 13th November 2014 02:09 PM
Aux Option w/DSP for pre-factory-aux cars. dookateh E39 M5 and E52 Z8 Discussion 8 13th April 2013 06:59 PM
Anyone done an AUX cable retrofit for their pre-lci m6?? e///Mpower E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 21st January 2013 01:41 PM
DIY: Make your own Aux input cable with install nixter E39 M5 and E52 Z8 Discussion 63 31st December 2012 06:30 PM
Aux input cable SeanAron E39 M5 and E52 Z8 Discussion 2 6th December 2004 07:41 AM
