DIY: 2006 S85+SMGIII swap into a 2004 E46 started - any helpful comments ? - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 18 Old 12th June 2014, 01:28 AM Thread Starter
shopcarpro
Originally Posted by umichchris View Post
ditch the smg and bolt it to a 6MT trans....
Thanx - U r on the money. I know it too - but have no 6spd. in hand.
shopcarpro is offline
post #12 of 18 Old 12th June 2014, 01:58 AM
M5 Jed
M5 Jed's Avatar
subscribed...
M5 Jed
2000 Dinan S4 E39 M5 Touring Anthracite Metallic / Black Extended - The original and one and only...Unicorn!!!
2006 Dinan S2 M5 Silverstone II / Indianapolis Red - The Garage Queen
SOLD - 1993 M5 Schwarz / Black - The Ronin Car!
SOLD - 2001 Dinan S2 540iT M Sport Orient Blue / Sand Beige
SOLD -1995 Dinan 540i M Sport Cosmos Black / Black Leather - #20 of 200 pcs.
PARTED OUT - 2001 BMW M5 Anthracite Metallic / 2-tone Silverstone Extended (R.I.P)
PARTED OUT - 2001 BMW M5 Anthracite Metallic / Carmel Extended (R.I.P.)
SOLD - 1993 BMW Euro M5 3.8 Touring Diamond Schwarz Metallic / Alcantara Suede - Oh how I miss u.
SOLD - 1988 BMW US Spec M5 Schwarz / Natur w/ 77k miles - complete Euro conversion - The Museum Piece.
Viva La Wolfpack!
M5 Jed is offline
post #13 of 18 Old 12th June 2014, 02:17 AM
jcolley
jcolley's Avatar
No.1 piece of advice? Dump the MSS_65 DME and SMG3 control.
There are so many interactions between the DME, DSC, ABS, Idle actuators, SMG, CAS, EWS, PDC (just kidding...maybe) that coding/programming/hacking the DME is challenging enough (although some prior work exists here in the public domain), and modifying the SMG programming for those other modules would likely cost more labor than any aspect of the mechanical work.
The Pectel SQ6 will work nicely with the S85 and they have a standalone transmission controller that can communicate with the SQ6 for smoother operation.
I researched this quite a bit in the last year or so for a potential Ultima GTR build (see here for a build by AutoBionics).
I've also emailed a bit with a gent in Germany from the Pistonheads forum who is working on a an S85 Ultima and one of his challenges is the SQ6 control of the idle and throttle actuators. He is likely using a custom microcontroller in between the SQ6 and the idle/throttle actuators to convert the SQ-6 single throttle output into the two-stage PT-CAN signal for the idle and throttle actuators (remember, the idle actuators open fully before the throttle actuators crack open the butterfly valves.
The SQ6 is also capable of running the S85's ionic current system.
Good luck in your build, please document and post everything here! (we're greedy like that)
-Jim
jcolley is offline
post #14 of 18 Old 12th June 2014, 10:55 AM
liam821
I own a 2005 e46 330i ZHP 6spd 4dr which spends most of the time sitting under a car cover as I drive my M5 most of the time. But every time I get back in the e46 and take it for a spin I'm always amazed at how great of a car it is. It's such a fun little thing. Now if it had the S85 under the hood...oh boy oh boy.
Someday i'd love to swap in a s85 into the ZHP, it would really wake it up.
Please please keep updating this thread with your build, lots of pictures!!
2008 Indianapolis Red ///M5 6spd (sold)
2011 Platinum Gray X5d
2005 e46 zhp sedan
Honda Civic eg track car
liam821 is offline
post #15 of 18 Old 13th June 2014, 12:33 AM Thread Starter
shopcarpro
Arrow
-Jim
 Jim, Thanx sooooooo very much for the input. Not yet decided here, as to the best way to deal with the final coding, programming / electronics. Looking/asking around during the installation/fabrication process to find the best way around. Your expertise/knowledge/experience would be much appreciated in time to come. Greets frm Japan.
post #16 of 18 Old 14th June 2014, 11:57 PM
TROY JEUP
Guest
Posts: n/a
Call/text me. I have been involved in over a dozen swaps of S85 into anything from E21 Bauer to an E92 M3. I can share some contacts with you.
6163043678
Best,
TJ
Sent from AutoGuide.com App
post #17 of 18 Old 2nd October 2014, 05:37 AM Thread Starter
shopcarpro
Taking on your kind offer.
Hi TROY JEUP, Thanx for your offer and I am ready to get your advice/help/contacts/opinion/suggestion, at this stage of my project as per the link below,
https://www.m5board.com/vbulletin/e60...omments-2.html I have installed the S85 and SMGIII in the E46 chassis successfully. Now it is the wiring, programming etc. Could you advise/lead me to do this part successfully and economically pls?? My contact info in www.shopcarpro.com, I remain thankfully in advance. Will call if no response shortly. Cheers.
post #18 of 18 Old 2nd October 2014, 01:59 PM
jcolley
jcolley's Avatar
Have a look at this E46 swap in Australia. Alex is getting along quite well with his build. I just sent him some parts to help out, but I'm not sure if he's doing his own electrical or has someone doing it for him.
jcolley is offline
Tags
e46 , e60 , s85 , smgiii , swap
Whats needed to swap S85 into E39 M5? lehsmann E39 M5 and E52 Z8 Discussion 62 21st June 2012 05:22 PM
e36 S85 Swap bulim5 E60 M5 and E61 M5 Touring Discussion 1 29th August 2011 04:39 PM
S85 swap w manual trans. 0TOVR6T E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 27th April 2011 10:58 PM
Started driving my E46 again... mfizzlee E39 M5 and E52 Z8 Discussion 9 15th October 2010 09:03 AM
Possible to swap S85 with SMG into a different chassis? mattyice E60 M5 and E61 M5 Touring Discussion 16 28th June 2009 06:34 AM
