BMW M6/M5 E60 - E63 Clutch DIY + Transmission Removal + Pics. - BMW M5 Forum and M6 Forums
 14Likes
post #1 of 19 Old 10th June 2014, 06:10 PM Thread Starter
Q.
I posted this on the M6 side, but since our cars share the same underparts, i thought i'd post it here as well.
After searching up clutch DIY's for the E60 E63 E64 SMG transmissions, and coming up short, I decided to make one of my own. There is a lot I've learned from this forum in just over a year and I think this is a great board, so I wanted to give something back to this community.
Symptoms:
Yellow COG - Drive moderately engine power reduced light for about 5 minutes. It disappeared and didn’t come back... until..
Red COG - A Month later, I get a red COG. This lasted for about 5 minutes then went away.
A few months after, I started to feel the dreaded "clunk" everyone talks about. Every time i shifted gears from 1-2-3, and 3-2-1, I would feel like I got rear ended. I then noticed slipping in 5th-6th. It would take a while to engage the gear, and when it finally does engage, CLUNK". Eventually it became undrivable since 1st gear would bite violently as soon as i touched the pedal, slips then catches and jerks like crazy.
My Diagnosis:
The clutch isn’t being completely depressed in between gear changes. Either the Release bearing or the clutch is damaged. So, I decided to change both.
Note: I take no responsibility for anyone damaging their vehicles following this thread. I am only sharing the experience I had doing this job.
You will need the Special tool to remove and reinstall the clutch. If you know of a way to do it without, please share..
BMW 212300, you can rent it here: http://www.bimmerzone.com/product/PRT-212300.html
BMW 119260.
other than that, you will need a clutch kit.
Jack up the car..
Start by removing the entire exhaust system. I made arrows in the pic below for reference on where to find these bolts. You will need a #13 socket, and a #13 wrench for everything exhaust related on this job.
Change these donuts.
Unbolt the exhaust brace and remove it. Push on these long arms towards the middle of the car to reveal a #8 bolt for the undercarriage.
Remove the undercarriage. Follow the #8 sockets all the way around. Straight forward.
This reveals the Drive Shaft.
Locate the Guibo. Remove and Replace. IIRC #18 socket.
Remove these bolts with a #10 point socket.
Dont forget to mark your parts.... just incase....
Keeping it original.
Remove the support brace.
Take off the Drive Shaft and put it aside.
Meanwhile... we CF'd the rear diffuser
Remove the Skid Plate. IIRC, #18 socket
[url=http://s1095.photobucket.com/user/quangbang123/media/IMG_20140531_132818_zpsaf6d7a4e.jpg.html][IMG][/IMG][/URL]
Unbolt this bracket that’s attached to the transmission harness. #10 socket.
Locate and disconnect the plugs from the transmission on the drivers side of the car. Remove the transmission cooler with the two bolts indicated, and move it to the side. This will reveal the plugs on the passenger side of the tranny along with the twistlock from the engine harness.
IMG]IMG][/IMG][/URL]
[url=http://s1095.photobucket.com/user/quangbang123/media/IMG_20140606_195108_zpsb20110ff.jpg.html][IMG]IMG]IMG]IMG]20Clutch/step12_zpsf94962f6.jpg.html][IMG][/IMG][/URL]
Allen key to remove transmission cooler
Put the transmision cooler back into place. You can now swing the entire harness over to the Passenger side so its completely out of harms way. There should no longer be any contact between the car, and your transmission.
Now with everything out of the way, we are ready to pull out the transmission
Unbolt all visible transmission bolts from the bottom. #10 point socket. Place a wooden board on top of a transmission jack and have two 2x4 short pieces of wood on the sides.
IMG]IMG]
Here’s where the bolts on the top of the transmission are indicated by the red arrow. DO NOT loosen the bolt pointed by the yellow arrow. This bolt serves to secure the starter motor.
Now that the transmission is out, lets take a look at the clutch. Looks like its missing two rivets.
[/IMG][/URL]
Lock the flywheel using the special tool.
[/IMG][/URL]
Here is the special clutch install tool.IMG]
[url=http://s1095.photobucket.com/user/quangbang123/media/IMG_20140608_151654_zps09b6d4dc.jpg.html][IMG][/
Shove it in!
Press the PinIMG][/IMG][/URL]IMG][/IMG][/URL]
Follow this link for loosening sequence. Remember, once you remove the clutch, you will see a mark on the flywheel. This mark should be 180 degrees offset from the mark on the new clutch.
http://pmmonline.co.uk/technical/clutch-removalreplacement-bmw-m5-and-m6IMG][/IMG]IMG]]
New Clutch In!
Remove the Fork, Release bearing. Put grease on these two nipples, Replace the release bearing with a new one, and apply grease behind the fork where it makes contact with the nipples. DON’T grease the release bearing. Just don’t…..[/IMG][/URL]
The rest is pretty straight forward. All the reinstallation steps are in reverse of this thread post. Always put anti seize when reinstalling parts. Save yourself or the next guy the headache. Don’t forget to adapt the new clutch using the adaptation procedure in INPA.
By the way. no more clunking. no more weird jerks. no more shuddering and slipping. just smooooooth as butter.
Get in and Drive happy.
thanks for reading.
Q. is offline
The Following 9 Users Say Thank You to Q. For This Useful Post:
5soko (11th June 2015), Blendercloud (12th June 2014), elmar (14th June 2014), gride (11th June 2014), Jahangeer (10th June 2014), maddios (11th June 2014), petesamprs (12th June 2014), TiM6 (21st August 2017), warmachne (21st November 2016)
post #2 of 19 Old 12th June 2014, 12:33 PM
petesamprs
petesamprs's Avatar
Much better than the DIY we already have. thanks.
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
petesamprs is offline
post #3 of 19 Old 12th June 2014, 06:57 PM
seif_ossama
seif_ossama's Avatar
This will be really helpful for me when I reassemble the transmission as I am working on the pilot bearing and the SMG pump.
Thanks.
Seif
seif_ossama is offline
post #4 of 19 Old 21st November 2016, 05:44 PM
Dick Fidd
Dick Fidd's Avatar
Hey guys I just started the job this weekend. Doing it on jackstands! Tranny is dropped, clutch and flywheel are out. Vincent @ Bimmerzone sent me a new pilot bearing, but I don't have a puller that fits, nor do any of the local auto parts stores. How have you guys gotten the old one out?
Some observations:
1. Flywheel is perfect with the slightest amount of wear. Have a new one so I'll put it in, but for others doing the job, suggest having your old one resurfaced instead, or even going 2 clutches before resurfacing.
2. Clutch looks pretty good - estimate 10-20% left versus new clutch and hoping it was indeed the culprit (slipping). About 40K miles on this clutch (1st one done under warranty).
3. Clutch tool wouldn't lock in on old clutch. Doesn't matter since not planning on reusing, but I did waste about 30 mins trying to get it to lock out. Tool is a loaner - will advise if I can't get it to lock on the new clutch.
4. If on jackstands (2 ton), tranny will have to stay in the tunnel for the job (not so bad). Need another ~6 inches of lift to be able to slide the tranny out (using motorcycle jack with approx. 4 in. "tare" height.).
5. Flywheel bolts are off-center, so the BMW tool is recommended. I bought a long T60 and had the shaft ground down at a machine shop. Works fine this way, but won't grab the bolts unless shaft is ground.
Any Q's feel free while the job is fresh in my mind!
Dick Fidd is offline
post #5 of 19 Old 21st November 2016, 06:27 PM
warmachne
warmachne is offline
post #6 of 19 Old 22nd November 2016, 01:23 PM
B767capt
B767capt's Avatar
I bought a blind hole puller. Easy to find or rent from auto part stores. Put the new bearing in the freezer before installing.
B767capt is offline
The Following 2 Users Say Thank You to B767capt For This Useful Post:
Dick Fidd (22nd November 2016)
post #7 of 19 Old 27th November 2016, 12:38 AM
Dick Fidd
Dick Fidd's Avatar
Here's what I used to pull the pilot bearing. Put some grease in the hole to stabilize wingnut, insert the wingnut, use a screwdriver to line up the threads, screw the bolt onto the wingnut, tighten washers down until bearing breaks free. Back it off and use spacers under the washers (I used sockets) and tighten until bearing is out.
New flywheel and clutch in - put tranny back in tomorrow.
post #8 of 19 Old 27th November 2016, 01:08 AM
lexustbs
lexustbs's Avatar
Doing it on jack stands? You sir, are my hero
Sent from my XT1585 using Tapatalk
2009 BMW M5 STOCK
Looking for a Dinan Exhaust! PM Me.
lexustbs is offline
post #9 of 19 Old 27th November 2016, 07:46 PM
Dick Fidd
Dick Fidd's Avatar
Question re: programming/adaptation for new clutch/flywheel - I'm going to have my indy shop do it, which is a few miles away. Can I drive the car over there? I had planned on getting a flatbed to bring me over, but thinking it might be a pain for no reason.
post #10 of 19 Old 18th July 2017, 02:12 PM
sjsuM5
sjsuM5's Avatar
Anyone know the part number for the clutch kit? Any other recommended options besides the OEM?
__________________________________________________ _____________________________________
M5
Exterior -- Space Gray
Interior -- Silverstone leather, Aluminum trim
Mods -- Charcoal Filters Removed, RPI Scoops with BMC Filters, Breyton 21" Race GTP Gun Metal Gray Wheels,
Eibach Pro-kit Springs, CF Front Lip Spoiler, Tinted Windows, "M" Aluminum Pedals, M Sprint Booster
sjsuM5 is offline
Rear Main Seal / Cluch / Transmission removal & install with PICTURES and VIDEO (not full DIY but informative). Terabass E39 M5 and E52 Z8 Discussion 46 6th February 2015 03:59 AM
THE BMW M6 Clutch DIY, Transmission Removal + Pics Q. E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 11th June 2014 03:19 PM
E63 M6 For Sale: BMW E63 & E64 M6 Clutch Kit & Flywheel (2006-2010) SMG Transmission Only OrlandoM6 Parts / Other For Sale or Wanted 5 6th June 2014 02:00 AM
DIY: Cowl Removal and replacement (lots of pics) tmaschm E39 M5 and E52 Z8 Discussion 1 15th March 2014 08:05 PM
E60 For Sale: OEM 06-10 BMW E60 E63 M5 M6 SMG Hydraulic Pump & Clutch Transmission S85 V10 5.0 STS-V Parts / Other For Sale or Wanted 1 7th December 2013 06:52 AM
