Help with INPA (codes) - BMW M5 Forum and M6 Forums
post #1 of 4 Old 14th February 2014, 09:46 AM Thread Starter
MichaelR
MichaelR's Avatar
Question Help with INPA (codes)
I decided to plug into my 2010 M5 and see what codes are stored in there since I just got it and came up with quite a bit more than I would have liked. I have solved (I think) most of them via searching, but was hoping someone could either solve the remaining ones, or better, point me in the right direction to figure this stuff out myself. I'm not sure If I can find the descriptions while plugged into the car with INPAA, or even after I unplug via some saved file, but any help would be appreciated. I got this list via pulling the error memory while the ignition was on, engine not started. I probably should just clear them all and see what comes back, but I'm curious......
Here is the list (I filtered out all that had no codes stored):
ADR Gen. name Error code Kind of error
00 - ZGM - 93B6 - 21 - Belt tensioner rear right
02 - SZL - A85F - 28 - ???
12 - DME/DDE - 27B0 - A4 - Secondary Air Injection System Insufficient Flow (Bank 1)
18 - EGS - 520A - 08 - ???
20 - RDC - 604E - E0 - Tire Pressure Control-system – all tires
- 6054 - E0 - FL Wheel Electric
- 6055 - E0 - FR Wheel Electric
- 6056 - E0 - RL Wheel Electric
- 6057 - E0 - RR Wheel Electric
60 - KOMBI - A559 - 20 - Clamp 30g_f cutoff - EXPLANATION: Pulled fuse out behind glovebox during tune install
63 - MMI/CCC - E1CD - 20 - ???
78 - KLIMA - 9C55 - 61 - Fogging / Vapor Sensor
- 3714 - 28 - ???
I'm pretty sure all the TPMS stuff is working as intended due to my winter wheels having no sensors (or wrong ones) in them. The rest of the ones I solved doesn't really mean I know what it all means, I just translated the code. If anybody feels like chiming in on what they all mean (yes, I searched), that would be great too.
Thanks in advance.
-Michael
MichaelR is offline
post #2 of 4 Old 14th February 2014, 10:19 AM
anzafin
That looks like an overall fault code list pulled from the car. You need to go and read each module individually to see the full error messages.
- Antti -
anzafin is offline
post #3 of 4 Old 14th February 2014, 10:52 AM Thread Starter
MichaelR
MichaelR's Avatar
- Antti -
I figured there was a way to get more info with INPA, and you are correct, it's the overall fault code list. It's too cold out for me to go check the individual modules for descriptions, but I'll look into it tomorrow. Thanks.
MichaelR is offline
post #4 of 4 Old 6th April 2018, 12:11 AM
Pistik
hello guys, especially Jcollye, i need to messure oil in MSS65, is there any option how to measure oil level ? I have standalone MSS65 ECU management without CAS and IKE.
Pistik is offline
Help with 3 codes from Inpa dance171 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 14th November 2013 02:17 AM
Help with INPA O2 sensor codes please. Minty E39 M5 and E52 Z8 Discussion 17 22nd July 2013 10:18 AM
Interpreting INPA codes Clayton Usher E39 M5 and E52 Z8 Discussion 5 8th October 2012 08:36 PM
Trying to read codes with INPA Fuddy E60 M5 and E61 M5 Touring Discussion 8 10th July 2012 11:58 AM
CEL, have INPA error codes Jfreak E39 M5 and E52 Z8 Discussion 27 2nd October 2011 06:38 PM
