Have you rebuilt your own S85? - BMW M5 Forum and M6 Forums
 25Likes
post #1 of 30 Old 5th February 2014, 04:45 PM Thread Starter
Destructo
I know we have some handy people on here, but just out of curiosity, whom here has rebuild their own S85 engine? With the rob bearing issue, I know myself I'd rather just do a rebuild in my garage at the same time. Not only would it provide ample cost savings, but i'm a nit-pick for details and know no one else would take care of it like I could.
Anyone else with me? Done the rebuild yourself? Just our of curiosity what did you spend ball park if you don't mind.
Thanks guys!
Destructo is offline
post #2 of 30 Old 5th February 2014, 05:59 PM
Revo
Revo's Avatar
Rod bearings are more or less a "bolt in" deal. A full motor rebuild for an S85 is definitely more invoked. Definitely not impossible cause a motor is a motor in the end, but definitely not something relatively simple like rod bearings.
The M5 is my dad's - but I drive it more than he does!
Sold Sept '16. It was an amazing 7 years.
Revo is offline
post #3 of 30 Old 5th February 2014, 06:06 PM Thread Starter
Destructo
Maybe I'm more anal about these things than others. If i was putting in rod bearings I'd just want to do anything while I had it out and available. But I'm not necessarily right in the head.
post #4 of 30 Old 5th February 2014, 06:09 PM
TROY JEUP
Guest
Posts: n/a
Swapping out rod bearings will cost you around $850 for all the parts from rod bearings to bolts to vanos pump chain tensioners to oil pan gasket. This is a very simple task.
Trying to rebuild an S85, requires cylinder honing by a machine because the cylinders taper like hell at around 60k (not honing by hand).
New vanos pump, oil pump, vanos units on cylidners, cam caps, head gaskets, main bearings, front/rear seal, etc.
All said and done, the typical rebuild costs me $6,000 to have this done in parts and machining. This is aside from having purchased $1500 in BMW oem tools for timing and checking tolerances, etc. I sell the rebuilt motors with 0-miles on them for $10,000 to a customer.
The used motors we sell are from $6000 to $9000 depending on year and mileage. That is the reason 99% of the people who buy motor from us just want a used motor with new bearings & vanos line service that we offer for free with the purchase of a motor. We also warranty them for 2-years or 30k miles.
Rebuilding an S85 "correctly" will run you around $6000, and that is a spun-bearing motor. If the injector locked up, you are back another $2500 for sleeves in the block.
If you just throw it together and go the cheap route and try to flush the metal out of everything, it will probably get your cost down to around $2500 in parts. However, getting that motor to stay out of limp mode will be next to impossible. The motor is too smart and it knows if the motor had metal in the vanos units, solenoids, etc and it will stay in limp mode until you change those parts.
This is a $52000 motor for a reason and people don't rebuild them correctly for a reason, because the parts are too much money. This is no Chevy 350. ;-P
Sent from AutoGuide.com App
The Following 2 Users Say Thank You to For This Useful Post:
leonelm3-m5 (6th February 2014), MKSixer (8th February 2014)
post #5 of 30 Old 5th February 2014, 06:13 PM
TROY JEUP
Guest
Posts: n/a
Forgot one thing~. There is $712 in TTY bolts on this engine. They all stretch upon reaching final spec and need to be replaced with new, just like conrod bolts. If you don't replace these, it's gonna be a bad day.
The Following 3 Users Say Thank You to For This Useful Post:
bmwm51 (6th February 2014), leonelm3-m5 (6th February 2014), MKSixer (8th February 2014)
post #6 of 30 Old 5th February 2014, 06:15 PM Thread Starter
Destructo
Awesome reply Troy. Thanks for the break down and information. Good to see a fellow Michiganer on here. I'm actually in the process of moving back to the West Michigan area. So it looks like I might have found a local resource when I do pull the trigger on an E60. Darn it! LOL!
If you don't mind I'd love to pick your brain sometime. It's always nice to have a local resource.
Thanks again!
post #7 of 30 Old 5th February 2014, 09:16 PM
TROY JEUP
Guest
Posts: n/a
no problem buddy,
Feel free to stop by any time. I can even show you the race shop that builds the S85 motors fro me. :-)
post #8 of 30 Old 6th February 2014, 03:23 AM
Smoorebmw
Smoorebmw's Avatar
so are you guys saying an amateur can do a rod bearing change?? I do the basics now on my beast such as: oil, spark plugs, water pump, pulleys etc….I'm wondering if I could conquer the bearing job myself….
Current:
2013 BMW M5 - B&O Sound - Piano Black trim - 2 toned grey/black interior....(MOD's are coming)
2016 M3 - Fully Loaded - GF's car
Grave Yard:
2014 BMW 640i
2007 BMW 335i
2006 BMW M5
2003 Infinti G35
2002 BMW 740i
2002 CBR 954rr
2000 BMW 540i
2000 BMW 328i
Smoorebmw is offline
post #9 of 30 Old 6th February 2014, 03:44 AM
ACG
ACG's Avatar
I wish I could do rod bearings but I just don't have all the tools, space nor time
Now building your own engine .....that is something I left to a builder who has experience, tools, space and time
The tolerances on these engines are not like my little Japanese engine I once built.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #10 of 30 Old 6th February 2014, 04:02 AM
TROY JEUP
Guest
Posts: n/a
I never said an amateur could do it.. I am just saying it is easy. But at the same time, this is coming from someone who has sold 79 S85 in the past 12-months.
I need a Rebuilt Transmission - Help ! rams3y E39 M5 and E52 Z8 Discussion 39 27th July 2013 07:22 PM
E39 Want to buy: Used or Rebuilt Transmission for an 03 M5 rams3y Cars For Sale or Wanted 1 4th June 2012 03:47 PM
Need a new/rebuilt driveshaft XaQ E34 M5 Discussion 6 8th October 2011 06:13 PM
08 M5 with REBUILT title waleed_wales GTBoard.com: General Sportscars 6 26th August 2010 12:54 AM
engine rebuilt bay E34 M5 Discussion 72 11th March 2006 05:19 PM
