Have you rebuilt your own S85? - Page 2 - BMW M5 Forum and M6 Forums
 25Likes
post #11 of 30 Old 6th February 2014, 04:09 AM
ACG
ACG's Avatar
Originally Posted by TROY JEUP View Post
I never said an amateur could do it.. I am just saying it is easy. But at the same time, this is coming from someone who has sold 79 S85 in the past 12-months.
I would not call you a builder but more of a dismantler.......I am good at breaking things up too even when I don't plan to
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #12 of 30 Old 6th February 2014, 12:40 PM Thread Starter
Destructo
Can you leave the engine in the car and do the rod bearing replacement "fairly easily" ?
Destructo is offline
post #13 of 30 Old 6th February 2014, 12:46 PM
leonelm3-m5
leonelm3-m5's Avatar
Damn Troy, Thats almost $80k in S85 Engines alone!
Nice
Leonel Aka " Rico"
Current:
2001 E46 Tiag / Imola
Modified HPF Turbo M3
9XX RWHP on E85 & the Gen2 PTE 6870
http://s1170.photobucket.com/albums/...t=53fe8fc9.jpg
2010 BMW X5M
K&N air filter
Megan Racing Exhaust
Decatted downpipes
H&R springs
stage 2 tune
leonelm3-m5 is offline
post #14 of 30 Old 6th February 2014, 02:55 PM
TROY JEUP
Guest
Posts: n/a
Nice
Math is off a bit. I think it is a little over $500k worth if you figure an average of $7 per motor.
Sent from AutoGuide.com App
post #15 of 30 Old 6th February 2014, 02:57 PM
TROY JEUP
Guest
Posts: n/a
I think it is far easier to do this outside the car. I know Jim made a long post on doing this in the car, but that would be a bear to lay on your back for hours and hours while reaching upwards into an engine. :-/
post #16 of 30 Old 6th February 2014, 09:00 PM
ACG
ACG's Avatar
Troy I will take a spare motor for $7 actually maybe a few at that price
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #17 of 30 Old 6th February 2014, 09:29 PM
m5 deamon
m5 deamon's Avatar
ive done many rod bearing jobs on s62 and s85 its time consuming
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
post #18 of 30 Old 7th February 2014, 07:57 AM
Duschanio
i did over 30 bearing rod replacements on these engines with my friend of the m gmbh And a some more rebuilds )
You can leave the engine in when you replace the rod bearings, i can do the job with my friend in 6-7 hours ..
My Customers bring the car in the morning at 07:00 and can come at 17:00 and drive home with the car.
When people write you should take off the engine , they dont know much or they would like to take your money ))
i think when i post all my pictures we are on page 20 :P haha , here some of it.
here you can do a nice work :
when i rebuild an engine i take it out . (when engine crashed with rods or something else)
here the engine must go out hahaha
here we do an s65 engine works also without problems enough enough space !!!!
Duschanio is offline
post #19 of 30 Old 7th February 2014, 09:40 AM
vantaam5
When I fully rebuild an S85 with perfect bores and crank,I end up with the following minimum:
3k€ for Vanos pump,lines,solenoids,crank sprocket,..
2.5k€ for gaskets,bolts,bearings,chains,chain guides,chain tensioners,water pump,t-stat,...
1k€ for rebuilding the heads(machining the seats,skimming,valve guides and seals),more if new valve springs included
is already 6.5k€ for that alone(including balancing crank,rods,pistons)
Plus labor for disassembling,cleaning,assembling..
Only real special tool out of the regular engine building tools is the quite expensive cam shaft alignment tool.
That being said,it is nice to build/rebuild the S85 as it is overall a quite easy engine to work with(if you are a professional).
vantaam5 is offline
post #20 of 30 Old 7th February 2014, 10:22 PM
TROY JEUP
Guest
Posts: n/a
I agree. This is exactly why most people prefer to purchase a used 08+ motor with new bearings & vanos line from me, as opposed to spending the money for a rebuild that this uses the high-mileage vanos gears, pistons, etc..
I need a Rebuilt Transmission - Help ! rams3y E39 M5 and E52 Z8 Discussion 39 27th July 2013 07:22 PM
E39 Want to buy: Used or Rebuilt Transmission for an 03 M5 rams3y Cars For Sale or Wanted 1 4th June 2012 03:47 PM
Need a new/rebuilt driveshaft XaQ E34 M5 Discussion 6 8th October 2011 06:13 PM
08 M5 with REBUILT title waleed_wales GTBoard.com: General Sportscars 6 26th August 2010 12:54 AM
engine rebuilt bay E34 M5 Discussion 72 11th March 2006 05:19 PM
